Seriously, short stop-and-go trips are much worse than short non-stop-and-go trips, which are worse than long non-stop-and-go trips. If you drive hard, everything is worse.
I expect about 12-13 MPG with my commute. On the highway, at 65, I expect about 22 MPG. On the other hand, the mileage is only a little better in my wife's Sienna in this kind of driving. It's rated 22/26, I think. Even my old 4 cyl Ford Ranger only got about 17 in these conditions, but over 30 on the highway.
This is how rumors get started by something being slightly mistyped and/or taken out of context.
Moody's and freerlove's problems were admittedly caused by having little or no oil in the engine. It could still be that the 2 reported #1 cylinder problems have the same cause. What about it tek182, what did your dealer tell you caused the #1 bearing problem? Did any of the other bearings, or other engine areas for that matter, show unusual wear? Was your engine losing oil and did you properly refill it in a timely manner? Or were you like freerlove and never checked going 6000+ miles between oil changes?
The conclusion I am still left with is that a high percentage of these engines (Paisan's 25% figure sounds about right to me) use oil. If you don't watch this and replace the lost oil you will be needing a new engine.
Just my $.02.
Also, with my 98 Trooper S automatic (with 96,000 miles on it - bought new) I have been recording every drop of gas I put in it since day one. Overall average is 17.1 mpg with the 3.5 v-6. During the course of the winter I notice a drop in overall mpg (went down to 16.8 by last April) then it picks up again as the warmer weather comes and now stands at the 17.1. My Excel spreadsheet shows overall lifetime mpg and "since last fill-up" mpg. The latter ocassionally drops to 11 mpg and sometimes hits 22mpg depending on when and what I'm doing.
Your mileage is better than mine by a long shot. Clearly, though, if you've put 96K on it - I put 8K on mine in a year - you drive a lot more than I do. Mostly highway?
If you care to, please email to tle_port@hotmail.com
Yes, my driving is a lot highway. Mon - Fri I have a suburban highway roundtrip of 25 miles and virtually every weekend I have been putting on 300 miles going up to my weekend house (hence the high odometer mileage in just over 4 years). I recently purchased a 2002 Altima 2.5 S automatic which is relieving the Trooper during the warmer months. But come the snow season the Trooper will probably be back in action quite a bit.
To tle_port:
I will be happy to send you the spreadsheet I have been using on the Trooper, but cannot do that until next Tuesday since I'll be away upstate until then (I,m at work now).
It sounds like you did all you could to properly maintain your vehicle. (Note: I had since reviewed the old posts and found that you started having the oil usage problem at 50k mis. Thus, you no doubt had good reason to be deligently checking for the proper level.) Something must have changed within the last 500mis. causing a dramatic decrease in the oil level and the damaged engine.
Be sure to continue to save all your maintenace records. While I certainly hope you don't have any future problems, it does make me wonder if the dealer really knows what he is doing (screwed up engine block work, you take it in with engine noises they find a rattling muffler shield and shortly thereafter the engine dies). In fact, once he is done it might not be a bad idea to have another dealer check the work. For example, I might trot it right over to another dealer or at least pay another one to do the next few oil changes and tell them to look for any engine problems while they are at it.
I have had mine for 2 weeks today and it looks like I am at around 16MPG with mostly city driving.
Is everyone using regular unleaded at 87 octane?
Anyone getting better results with higher?
Sorry for the confusion, if there was an '01 in there I was wrong. '98-'02 should be roughly the same weight.
-mike
Sounds like Trooper users are getting a wide range of mpg numbers. I don't consider myself to be a 'leadfoot' by any means, and I am disappointed in my mileage. I've driven this Trooper much like all other Troopers I've had, it just isn't matching up mpg-wise. It's really a downer to get mileage that you would expect in a Suburban, or Yukon, or Full size truck. Guess ISUZU just missed something in quality control when some engines use oil as much as theirs do, and others seem to use no oil. Oh well, you have to give it to em' on overall durability for the long haul. They do seem to be dependable.
I think it would be excellent for the Trooper to get 31 MPG like the diesel version does in the UK, but USA diesel fuel has too much sulfur to let the Trooper diesel pass emissions here.
My 1995.5 Trooper has spark plug wires and benefitted a lot from the www.directhits.com product especially when driven very hard like towing (9.9 vs 11.2 MPG), but it only helps a tiny bit in MPG in light MPG conscious driving.
There was once a rumor that the Suburban would get the Duramax diesel. That would be one to take a good look at if you have a need for a lot of seats.
I have the K&N drop in replacement air filter which made a very noticeable difference compared to the dirty Isuzu filter it replaced. I bought, installed, and removed a Calmini cone filter that replaces the normal airbox. I removed it without even driving the car because I could see that any particles that might hit the fan would be slamed right into the cone filter. The K&N filter material looks like a well worn tee shirt, and IMHO it would not hold up to fan debris.
I looked into a replacement exhaust system. Found an outfit in the UK that makes them out of stainless. I asked if the engine performance increase would be noticeable, he said the Isuzu exhaust is already optimized, that his new system might be better, but only very slightly. It was expensive and there would also be a large shipping charge.
The Australian outback racers claim that intake and exhaust are the biggest places for improvement. I think they may be right, but you have to be willing to be as loud as a pack of Harley motorcycles to get the improvment.
Sorry for not remembering - I must have killed a few too many brain cells last night.
Thanks, Dave
The upgrade is worth about $1800AUS fitted. This includes a completely new exhaust and a modified air box. The extent of modifications done to the air box depend on the trucks's usage. If you are staying on hardtop with little dust, then the most modifications are done and the greatest gains are achieved.
Also the standard exhaust is far from optimised. I've experienced the results of the upgrade and you can't achieve those increases in power and torque by simply changing the breathing of the motor, if the standard setup is already optimal.
The only problem is, more performance....more throttle....more fuel! You can get consumption savings with this upgrade if you drive easily. But face it, you've just installed more horses, the temptation will be to use them!
How do I know? I was servicing the air filter and forgot to reconnect the air flow sensor afterwards. 15 minutes of driving later the CEL came on. I realised what I did and reconnected the airflow sensor, but the CEL wouldn't go out for the next 30 minutes of driving. This included two stops where the engine was off for more than 10 minutes. So I pulled the fuse for a couple of minutes and away it went.
I'm in the market for a used my2000 trooper and hope someone can help me with the following question: Is the privacy glass standard on all my2000 troopers, S included, or only on the LS and higher models? Edmunds calls out the privacy glass as a standard feature on the LS but makes no note on the S for my2000 yet notes privacy glass as standard on the my2002 S model. I prefer how the Troopers with the privacy glass look over those without but only have the budget for the S. thanks for your help
LS
Limited
S (Fleet Sales ONLY)
So pretty much the S model does not have Privacy Glass. I believe in 02 the S model does have privacy glass std, but don't quote me on that.
-mike
I admit their strength is the medium and heavy truck markets. But I don't believe they can take another hit in any truck segment and survive it. They are cash-strapped and very vulnerable.
As for shock info, yes any shocks that fit on '98-'99 will fit on '00->'02 as well, most parts places haven't updated their books for the Troopers.
-mike
Thanks for the info.
MWWST
What's the latest consensus on tires? I have 45K miles on my 99 Trooper. My girlfriend just ran over a nail with my Trooper. The tires were starting to look pretty bad anyway, so I figure I should replace them now. I don't go off-road, just maybe a few dirt roads and one in a blue moon over sand at the beach. I was thinking about something a little "beefer" looking like 265/70. I know the speedometer will be off...and I won't be able to use my spare. Should I consider 75s? Any brands you guys would recommend? Pirelli? Goodyear?
All comments are appreciated.
Regards.
Phil
I have a stock 99 trooper (no lift, std shocks).
What do you guys recommend for someone that stays on-road except for an annual camping trip with the kids?
Phil
We replaced the Bridgestone Dueler 684s on our 98 Troop around 52k miles with P245/70R16 Michelin LTX M/S. Got a real good price at Discount Tire (they matched Sam's Club / Costco). You really can't go wrong with Michelins.
I've read good things about the Cooper Discoverers, which is a pretty attractively priced tire.
Check tires.com (Discount Tire Direct).
Have you read the tire reviews on tirerack.com?
Will you be doing any snow driving?
I live in New England, so snow driving will occur often.
I have a *silly* question. Are the Duelers that came stock on my trooper (684s) an "all terrain" tire?
or
Yokohama Geolander AT II+
All are around $100 give or take a few. The ATs might be good for the snow, but the STs will be nice on the pavement.
-mike
Sometimes, those designations don't mean much, as there aren't universally accepted definitions for each term. I think the Dueler 684 is meant to be an all-season tire, for primarily on-road use. I thought the 684s were fairly quiet and decent overall, but I don't tend to be very picky when it comes to tires.
Another source of info/reviews is Consumer Reports. They do SUV tires periodically. If you aren't a subscriber, you can sign up to the web site and access all back issues for $2.95/month, I think.
-mike
The Teflon Don aka John Gotti didn't die in prison, he's been release to the custody of Ford PR!
-mike
I had issues getting the 693's balanced, with a less expensive tire, there is more chance that there will be "heavy spots". I had to go to a second place and pay to have them balanced, the firestone place that I got them at could not get the job done.
I would also get your spare replaced. This will mean losing tire cover. I found a place that gave me full credit for my unused spare dueler 684. I got about $80 towards a new tire. Before you buy anything, I would spend a few Saturdays visiting tire shops, ask a lot of quesitons, sneak a peak at the work area...are the workers paying attention? are they treating the customer's car well, etc.
Don't worry about size. 265/70 or 265/75 will fit no problem, and will not bottom out. The 265/70 fits so well it looks stock. I had my truck loaded down to the bump stops with 2" to spare to the top of the wheel well. When the suspension is flexed offroading the angle of the tire changes, going into the deepest part of the wheel well, thus providing lots of space for extra tire.
-mike
Michelin Cross Terrain seems like a great tire, but much more expensive than most other road-purpose tires.
Michelin LTX M/S is a good choice. Not real cheap, but can be had in stock size for apx $90-100 apiece + balancing/mounting/etc.
I never had any complaints with the stock Dueler 684s. Got 52k miles out of them. Currently running Mich LTX M/S and hope to get 60-80k miles out of them.
Michelin just annoys me because they are generally super expensive for no apparent reason.
-mike
OK, now on to another subject, or back to a former subject, actually. Those of you who are using the K/N air filters. Where did you get them, how expensive were they, and did they help you any on your fuel mileage. I'll go 'off air' for the answers. Happy Trooping!!!
-mike
