Do the bars bolt on or are they only horizontal welds?
-mike
-mike
-mike
Pulled a trailer from Colorado to Nebraska with a weight of 3500lbs with no problem at all. Sometimes I had to look to see if the trailer was still back there. The Trooper is a ok in my book.
Philip
I checked with Isuzu and they said that as long as I have receipts for the parts and record the date and mileage of any service I perform, I should be ok. One last thing, the previous owner had the ultimate protection plus coverage so I'm not sure if that coverage will be extended if I do my own service.
I think that all will be clear when you remove the grill. The entire job, including cleaning and waxing the grill took less than thirty minutes.
Philip
Philip
I don't think GL-5 means it has the anti-chatter additive, but I am not sure. I think it is just an SAE spec or something, like they have for motor oil.
Regarding the transfer case, be careful. If you have a TOD transfer case you use AT fluid, not gear oil or motor oil.
For the tranny, I just took it to Jiffy Lube and they did the fluid swap machine. That way you get all the fluid exchanged, and save a lot of hassle IMO.
Agree that the "works in limited slip diffys" statement from Mobil 1 does NOT mean there's already an LSD additive in there.
A 4 fl. oz. bottle of LSD additive isn't real expensive, but you might try the rear diffy without it as it may not be necessary. I'm pretty sure the GM LSD additive is the same formula as the Isuzu-branded version. So you might find it cheaper or more easily at a GM dealer.
96_i30_5sp, are you an Infiniti fan? It doesn't surprise me that the Trooper's quality would be appreciated by someone with a fondness for Infinitis.
You check it kinda like a differential. When the fluid runs out the fill hole, it's full. The tranny should be checked while the engine is running, in neutral I believe.
-mike
Anyway, this is a great list and I very much enjoyed the advice and people found here. If you have another off-road gathering in the East, please let me know directly at sreid@sover.net I'd enjoy meeting up.
Cheers,
Sean
To fix the cover, including sanding, repainting, and replacing the lettering is going to run $177+tax. Replacing the letters alone was $45 of it! I think being the Isuzu dealer shop, they'll nail the paint color and the composite mix they need to make the paint flexible.
Oh well, small crap like this is why I carry a $500 deductible on my insurance and keep a cash emergency fund!
The lesson here is to watch where you park, and when in a lot, pull as far in as you can to keep your rear out of the line of fire, or pull through when possible, if you won't need to open the rear door.
Drew
Good luck with the avalanche!
-mike
Jim
S
-mike
P.S. Sorry for all the questions, I want to do it right. :-)
-mike
The diffys and transfer case don't take much fluid, and they aren't hard to drain and fill. So the parts costs there should be pretty minimal.
If you don't mind doing some of the stuff yourself, I'd say have Jiffy Lube do the A/T exchange and swap out the t-case and diffy fluids yourself. You'd save probably $50 or a bit more and gain some confidence in your ability to maintain your Trooper yourself.
The last part of the article says GM would trade most of its ownership in Isuzu for a majority share in the profitable diesel engine part of Isuzu. Does that mean a majority share in just the one new Duramax factory in the USA? Or all of Isuzu diesels? If it means all of Isuzu diesels then this could be the end of Isuzu, not just the end of Isuzu SUVs in the USA. GM will wipe out the Isuzu name or make it a GM truck brand and start the deep cost cutting which will take away from the long term reliability that Isuzu is known for.
-mike
