Visitor Agreement.
I have made it a habit of switching into 4WD when I drive on the dirt roads at our lake cabin, and of course I use 4WD quite a bit during the winter, so hopefully I won't have the same problem...of course with the road salt and corrosion, who knows.
Great write-up of your testing, by the way. I'm curious, when you 1st tested that suspect solenoid, could you hear it SNAP when you applied voltage to it? I could never get mine un-stuck enough to get any movement or a snapping sound. You are right about all those hoses coming to the SOFT. Its quite tricky to figure out what ISUZU was doing, much like a spiderweb.
Happy Trooping !!!
For those that haven't inspected their SOTF unit. (say that with a straight face) you'll find that such vacuum solenoid switches actually have air passing through them at all times. In theory this keeps them from gunking up. When power is supplied to the solenoid, it snaps open access to what must be a very tiny internal hole that puts vacuum on the shift mechanism diaphram through the third outlet on the switch. It's that tiny hole that got clogged on my 99 unit. Just doing the gentle reaming and the carb cleaner job on it did make the resulting 'snap' a bit louder, so it was definitely getting sticky. On first install it inconsistently brought the truck into 4WD. That's when we decided to try the carb cleaner and that seems to have done the trick, opening the hole up to spec, I theorize.
Craig
I didn't notice any particular break-in period with the very supple Michelins but can certainly believe that there can be such a period with certain tire models.
I have the Bridgestone Dueler tires on the Trooper because of their softer rubber underneath feature which attempts to maintain traction as the tread wears by exposing grippier rubber. I have had a set of Dueler H/L and now have a set of Dueler AT Revo because I like the idea of deaper tread for not getting stuck. My Firestone dealer recommends rotating the Revos every 3000 miles to be extra careful about keeping them quiet.
-mike
My extended warranty has already paid for 1/2 it's value and I only have 513 miles into that warranty!
-mike
ISUZU
Isuzu will make three announcements. The first is expected to be the unveiling of the Rodeo replacement, which will debut as a 2004 model. The company also will introduce engine technology that will be available for the 2004 model year and discuss an SUV that will bow for the 2006 model year.
That last sentence is interesting. I hope it's the big one we heard about and not a small SUV.
Jim
What we'll see is:
1) Rodeo 2004 = Trailblazer SWB
2) Diesel Engines Available
3) Trooper 2006 = http://motioncars.com/autobuzz/articles30/2003_isuzu_adventure_ma- ster.html
-mike
Sigh. Another GM clone. The Rodeo chassis has got to be easyand cheap to build. Why another clone? Why why why?
My wrap around service plan from warrantydirect.com is covering the SOTF and seal problem.
ARGGGGGGG.
-mike
and want to see a TV article on the 2002 ARB project Trooper, it's in the first 10 min. of the show.
I have called the 800 number to review issues and have gotten the same thing...I think the guys name is Derek? He told me "Don't call here everytime you have a problem with a repair, go back to the dealer first."
I love my truck, but will almost be happier when the warranty is gone and I have to just "live with" some of the minor things.
How far are you from flemington Isuzu? They have an awsome rep, you might try them. I use Open Road in Edison.
-mike
I only have one annoyance right now...There is slack in the steering that I can feel when I turn left or right. I had the steering column replaced last year because there was wear in the column coupling, but they didn't replace the worm gear. I am going to get it up on jacks this weekend and check tie rods etc and then try the steering gear adjustment listed on planetisuzoo.
They tell me play/slop is "normal"...normal or not I want it fixed, so I am going to try to adjust it myself and then if that doesn't work ask to have the steering gearbox replaced...they said they would if I kept having trouble...the main issue is going back and forth, so an attempt to do it myself seems warranted.
http://www.planetisuzoo.com/articles.htm/88
-mike
After reading the article and doing some research it seems like I have slack in the ball bearings in the steering gear, not a problem with gear contact. I am not sure, but I think the adjustment just pushes the gears together or apart depending on the adjustment, not any slack in the bearings? But it seems like an easy thing to try first.
I may get a stabilizer shock when I go with the 285-75/ 33" tires.
-mike
What is on your short list(top three)as a replacement for your Trooper when the time comes?
When the time comes, I'll replace it with something smaller that gets better gas mileage that's still 4WD. Subaru Outback or Forester is high on my list.
And I don't like the feeling on this board over the last week or so... like someone gut-punched everyone. Is it just the realization that Isuzu is not treating an orphan vehicle as well as they might? And that the Isuzu dealerships are disappearing and selling mostly Chevys?
To the extent that people feel pain, a combination of events have caused many Isuzu loyalists to doubt their loyalty. To begin with, many Isuzu owners have various issues with Isuzu dealers and their response to the owner's complaints. This is probably typical of most dealerships independent of the manufacturer, but nonetheless it is taken personally. Secondly, many Isuzu dealerships, perceiving a slipping fate to Isuzu in North America are dropping the Isuzu nameplate and/or rejecting warranty claims based on a probability that Isuzu may not reimburse them for the claims. Third, many folks have been die-hard long term Isuzu loyalists based on Isuzu's quality from the late 80's to mid 90's. During this time period, sales and profits were strong for Isuzu. When sales and profits drop off, one of the first manufacturing attributes to go is quality control. As a result, I too question the long term durability of the more recent Isuzu's. The only fact that attempts to restore my confidence is the fact that Troopers are made in Japan where quality control is intregrated in the foundation of all manufacturing systems. Fourth, the recent economic down turn along with major incentives for new vehicles have substantially impacted used car values. Therefore, Troopers have suffered major depreciation. In conclusion, many Trooper owners are not able to appreciate the long warranty because either there is no dealer reasonably available or the dealer will not recognize the warranty claim and without the dealer support, the Trooper owners want to unload the vehicle, but since the depreciation has hit the vehicle so hard, the owners can't afford to unload the vehicle. This results in Trooper owners who are tense and sometimes express this tension on this board.
I personally have been lucky. My 99 Trooper S model here in Georgia has treated me well.
Replacement Vehicle, Next Vehicle(Actually, I do not intend to replace the Trooper, I plan to keep it.):
2001~2002 Chevy Suburban 3/4 ton 4wd
2001~2002 GMC Yukon XL 3/4 ton 4wd
maybe 2001~2002 Chevy Suburban 1/2 ton 4wd
Chad
I'm not planning on relying on the dealer body, since I have an excellent independent mechanic who can work on anything.
Question for you guys: I want to put a roofrack on. What do you recommend? I like to kayak, so I have the H20 system from Thule, but I need new crossbars and feet. Looks like it will only go in the doors, which don't thrill me because the cross bars would be so far forward on the vehicle. I noticed that a few troopers have had racks, are they built into the plastic rain gutters? Are they made by Yakima?
Any help is appreciated.
Tim
Thanks sdc2 for your input on TOD and diff oil changes. This is a wonderful forum!
Several people here have created mounting points for other rack systems by utilizing a four (?) nuts that are welded into the roof underneath the plastic strips that run the length of the roof on each side. I think they fabricated their own brackets. I didn't do a search, but you might, and see if anything jumps out at you, otherwise someone with chime in soon, I'm sure.
Congrats on the purchase. I have a 1998 4WD S, and am always keeping my eye out for a Limited.
Jim
I use an aftermarket Thule Rack and am very happy with it.
There are holes along the roof rails of the truck under the rubber weatherstripping (theory is that these holes are what are used to move the body into position during manufacturing). There are sets of 2 in the front, 2 in the middle and 2 in the back. I have not seen them but apparently they are small threaded bolt holes covered with masking tape. Someone on this forum posted attaching rack braces into these and then 3 Thule bars across. This would be one way to create a super strong permanent rack.
I prefer the options of the removable Thule system. I have no issues with it. I added a fairing which decreases noise, but also seems to drop the mileage about 1 MPG on the highway.
#7382 of 7600 Here is a nice rack by paisan Mar 17, 2003 (6:27 pm)
http://planetisuzoo.com/articles.htm/98
-mike
Roof Rack my 2nd generation Thule - Overlander by boxtrooper Mar 18, 2003 (10:11 am)
In the next few weeks I am going to change from my 3 Thule crossbars bolted directly on 3 pairs of Overlander brackets to a new system that lets me adjust the cross bar length and spacing. Here is what I will do:
1.) Remove all 3 existing Thule crossbars
2.) Get two 78 inch Thule crossbars
3.) drill holes in one side of the 78 inch bars that allow it to be bolted down to 3 overlander brackets front to back direction on the Trooper.
4.) get some stainless spring back slot track 5/16 nuts and slide them down inside the 78 inch cross bars such that the springs hold them in place above each hole. These are available at www.mcmaster.com or any industrial supply.
5.) shorten two of my old Thule crossbars to fit under and inside the rear two Overlander brackets and drill the current one side holes all the way through for the rear two Overlander brackets.
6.) get some black 3M 5200 sealant
7.) get some fender washers
8.) get some 1.5 inch long stainless high strength bolts
9.) bolt through the shortenned under crossbars and into the nuts inside the 78 inch lenghtwise bars.
10.) get a Thule bar to OEM roof rack adapter set which is very strong and another set of top crossbars and clamp them on when needed.
The results: The shortenned Thule cross bars under the Overlander brackets make the roof rack very sturdy side to side even when no top cross bars are used, so I can use the 78 inch front to back bars as a handle when climbing up on the tire to get to stuff on the roof. The top cross vars can be any length over 50 inches and can be removed or positioned anywhere. The front set of Overlander brackets does not get an under Thule cross bar so no wind noise. The rear two under cross bars can support a basket without any additional top cross bars.
As a final touch, and I would like some opinions on this please, I am thinking about bolting stainless 4 inch stainless yacht cleats on the outer vertical surface of the Overlander brackets. These are available from www.WestMarine.com and would provide a very sturdy way to tie things down with regular rope. What do you think? Would cleats look bad up there? The cleats are nice and smooth and would make good handholds as well. Thank You, BoxTrooper
List? WRX, Lexus IS, TL Type-S?
http://isuzu-suvs.com/howto/Yakima-Overlander.html
By the way, does anyone know how I can find Overlander brackets. I tried their website:
http://www.overlander.com/
but as you can see, it didn't go through as I ended up at Webstar!
Can't wait to test the Trooper out on the beaches of the outer banks this June!
Tim
They told me definitively that the Thailand truck will be back and be sold as a trooper here. The Assender was/is just a stop gap measure cause the plant in Japan was sold due to the real estate being worth a ton of cash.
The troopers are still being built and sold as the Big Horn and Jackaroo out of the thailand plant.
So things actually look pretty good for the Isuzus IMHO.
-mike
The ideal 2006 Trooper would have diesel hybrid power and get 20 mpg city and 30+ mpg highway with good acceleration because of the hybrid power. Of course the hybrid should be one option the other options should be larger diesel and gasoline engines for heavy duty towing. The diesel hybrid part of the 2006 Trooper should have a home backup power mode whereby the engine could idle quietly and provide 10KW 220VAC 50/60Hz or more for powering your home or tools on the road.
Hopfully in 2006 Isuzu can find the wisdom to market the Trooper as a low cost of ownership very high practicality vehicle for people who want to reliably go anywhere with all their stuff for many years. Troopers strong points are that they just keep on working year after year for hundreds of thousands of miles and they are small enough to park while able to carry a lot more stuff than the competition. Trooper is not a sexy "spur of the moment, got to have this year's model" thing it is a lifestyle "don't care what anybody else thinks and I'll drive it till it dies" choice. Trooper more than any other SUV holds its quality over time and miles.
-mike
Just after passing 100K (the point at which my extended warranty ran out) the CEL came on and the same thing: diagnosed by Isuzu dealer as IMG. This cost me almost exactly $400. The belt also started squeaking loudly again but the dealer says it looks fine.
Anyone have a serpentine that looks good but makes outrageous noises?
Also, be aware that the IMG thing can come up again after the original "defect" is taken care of under warranty. And, the Isuzu customer service rep told me that if the CEL light came on after 100K it's my responsibility. I argued that the problem doesn't just instantly pop up, that it had obviously been developing pre-100K.
They even sent me a letter saying basically "claim denied - over extended warranty term."
Keep trucking.
I also doubt that Isuzu's quality control has dropped off since the mid 90's. If anything quality may have improved. The latest trooper models do not share the same problems mentioned by owners of older models on this board. Problems are corrected, horsepower is increased, and alot of luxury options are now stock. Remember that Isuzu sells trucks worldwide, and auto engineers are paid to improve designs.
The problem for Isuzu USA has been and will be competition. Very few competitors existed in 1986. But I have a hard time keeping up with all the SUV names these days.
In my most humble opinion...of course.
As far as getting a roof rack installed. You may find the same overlander roof mounts, from the Surco safari rack set up. They have the same model #, and they should work about the same.
Oh and the new Toyota 4 runner looks nice!
But next year I will replace my Subaru with....
another Subaru. Best damn car for the $$ IMHO
Love my '92 SVX.
-mike
If Isuzu fails to use high MPG diesels and reliability and long term low cost of ownership to their advantage in marketing the 2006 Trooper I think that will be the end of Isuzu brand personal sized vehicles in the USA. Then Isuzu will live on in the USA only as an automotive components supplier industrial diesel engine supplier and medium size truck supplier.
Isuzu cannot compete with GM and Ford and Toyota and Nissan for yet another marketed same as the rest sexy new high power high luxery SUV. Isuzu needs to define its own nitch. Like Subaru has done, there are small cars and then there are Subarus. Isuzu needs that.
