Visitor Agreement.
$100 Throttle Body Cleaning
Apperently the tranny fluid looked like motor oil. And that's in 20K miles as I had it flushed at 50K, and now turned 70K miles. So after that we'll see if anything improves, if not then they'll do the tranny on it....
-mike
Interesting that other shops didn't notice when checking levels...since when you get an oil change at a dealer they should also check the transmission fluid level...brown fluid should get noticed...then again not every shop performs what they list on their invoices.
-mike
-mike
-mike
The CD changer broke down last fall, and it is hard to find an in-dash CD changer sold outside the car dealer network. I bought a Nakamichi MB-75 unit 6 months ago from electronicsbonanza.com. Now I can report on it in detail.
Overall, I am quite impressed with it. My old Fujitsu sometimes skipped over major potholes, and I learned to live with it, until I drove over the same potholes with Nakamichi. Not a skip so far. Simply amazing. My other car has a high-end Bose unit, and I know a stretch on a country road where I can make the Bose skip, but not Nakamichi!
Sound clarity and bass richness for Nakamichi is far better than the head unit that it replaced; used it with the same speakers.
A CD changer and AM/FM radio is a bit too much for a single DIN slot, so don’t expect a lot in terms of ease of control. Buttons are tiny, and they have multiple functions. Also, Nakamichi has detachable plate, which is perhaps why volume control is not rotary.
However, given the constraints that they had to have a single-DIN unit (for all Mini Coopers and Jettas out there) with a detachable face plate, Nakamichi engineers still worked out a nice compromise in terms of ease of use.
The power, volume and track navigation buttons that are used most frequently are located at the driver’s side of the unit. Volume buttons have a distinct tactile feel, so it is fairly easy to learn to perform the basic functions without looking at the unit. Bass, treble, balance and fade adjustments are all done with the same volume buttons. The tiny button that toggles bass, treble, balance and fade adjustment regime is also nearby, and with some practice all those basic adjustments can be done fairly easily.
Power button is somewhat annoying, because it toggles between CD, radio and two AUX inputs, so to switch from CD to radio you need to push it 4 times.
The LCD display on the unit has all the necessary information, but the characters are too thin and may be hard to read in direct sunlight.
CDs change somewhat slowly, but this matters only in the full random play mode that I never use.
Overall, I would recommend this unit to anyone who needs to replace their stock in-dash 6 CD changer. The only other alternative seems to be ordering a replacement unit through your dealer, and it is typically 1.5X the price of Nakamichi unit, and maybe inferior quality, too.
-mike
If you have a CEL and rough idle it could be the start of an Intake Manifold Gasket Problem. My 1999 started with slightly rough running, then bouncing idle/stalling. The shop couldn't "figure it out" until it got so bad that it caused a code to be generated, so it took 5 trips to the dealer over 2 weeks while the problem got worse and worse to get it fixed...even though I pointed them to that problem the first trip in.
I would think if there is a problem it is either of those 2. The dealer spent time checking my idle air control valve, EGR, basically everything but what the problem was.
As for the cleaning, I asked just how they do the passage way cleaning. The service guy said they use a small bottle brush and some carb cleaner or break line cleaner and blow it out afterward. Then they reset the code in the computer. They did not clean the EGR, they replaced it in my case. He said the diaphram was stuck. Thats what I want to check out for myself. The cost of running the diagnostic, new EGR, and cleaning of tubes was $389 and change. Seems like a lot, but if it performs very well and the mileage improves like SGCOOKE, I'll be very happy with that!!
I plan to see if it has an impact on my oil consumption as well. Oil consumption seemed to have gotten excessive recently. I had just added a quart last week after only about 800-900 miles. Thats a lot more consumption than I typically see. Usually get about 1500-2000 miles before adding a quart of oil.
Now I need to get the spark plugs changed and the serpentine belt replaced. Oh, the dealer wanted $90 to replace the belt. I'll do that myself at home.
pat "Ask the Town Hall Hosts" Feb 26, 2004 10:42pm
Has anyone replaced the rear pinion seal or does anyone know what the procedure is from the Helms manual; torque specs, etc. I need to replace mine pronto for a trip across country at weeks end and I really don't have confidence in the local dealer. The last time I had the truck in for repairs, they replaced everything but didn't fix the problem , the I'm getting the seal from St. Charles Isuzu.
carl
Here is an overview:
http://www.gomog.com/allmorgan/seals.htm
Did you get the seal and (most have) crush washer/spacer as well?
See:
http://www.web-masters.com/gms/rear_axle.html
#'s 27-33 and 42-44.
Hope this helps.
Just a little FYI, +98 Isuzu have a solenoid to activate the sprung pintel in the EGR. The pintel is what gets carboned up, and needs to be cleaned. Diaphram EGR's, are actuated by vacuum lines to the EGR. Many mechanics are not use to this new solenoid activated EGR and assume that when there is a fault code, it is a bad diaphram.
As for Oil useage, I was reading my CD manual last night, and it stated the following reasons for increased oil consumption:
1. Dirty EGR (system)
2. Dirty PCV
3. Carbon up piston rings
4. Long highway trip
5. Towing
S-Belt:
Yup it is a 5 minute job and the belt cost like 17 bucks from St. Charles.
If you check the rodeo board here there is an Isuzu FAQ link I put together for Rodeo's and Troopers.
-Ryan
-mike
-mike
So it will be another trip back since last time they couldn't do anythind due to no CEL. It will be 2 trips back cause only Bank 1 is showing now, they'll have to wait til the CEL for Bank 2 comes on in order to replace that one.
-mike
1 : Remove the EGR valve there are 2 holes the larger one is the one that supplies exhaust, flow don’t worry about it. The other is a vacuum port this is where exhaust gases are directed when the EGR valve opens, carbon deposits stick to the walls of the vacuum port and in time will restrict flow normally about 30,000 miles.
2: Check your local dealer for Intake cleaner ask about BG products all you will need is the intake cleaner (spray can), or head to your local parts place and pick up a can or carb cleaner that is safe for O2 sensors, find something to plug the larger hole make sure it will not vibrate and fall out there will be slight exhaust pressure on it but not much just be sure it is plugged real well because if not you may be surprised by a flame. Once plugged start the vehicle, spray intake cleaner into the vacuum port you may have to raise the idle to do or just open the throttle by hand spray until the can is empty.
3 : check your EGR valve push the pintle on the bottom be sure it moves in and out freely if not clean it don’t replace the valve once the pintle moves as it should reinstall the EGR valve disconnect battery for a few minutes or have code cleared.
Here is my own write up:
First I disconnected the Neg terminal on the battery.
I loosened the two screws on the intake, removed the tube that goes to the vavle cover, and then tried
to remove the one sensor plug. Which didn't happen, but there was enough slack in it to move the intake
and place it above the TB.
So I take a look at the butterfly valve and it doesn't look half bad. I open it and there is a bit of
carbon build up. So I sprayed that area, and wiped it out with a shop towl. Then I sprayed into the intake
and washed that down a bit too (.25 of the can). Next I saw the tube that Keith mentioned that cools cly #1,
and I ran a Test Tube brush about 4-5 inches down it with little problems. After that I put a shop towl in
the butterfly to let it air out.
Next I removed the egr, 2 bolts and one plug. And then remove the egr itself. I sprayed down the inside of
the egr and lots of flaky carbon washed out. I also, sprayed some down the egr tube and the hole next to it,
and ran the test tube brush down it a bit. Then I let the egr sit out and air out for about 30-40 minutes
before I installed it. Then I put everything back together.
Then the fun started. I turned the key for about 5 seconds and it would crank and crank and crank but nothing.
I tried again and the same thing happened. One more time, and it turned overed and stummbled for about 7-10
seconds. Then I started to give it a bit of gas and then it happened! The dreaded Flashing Check engine light!
NO! At this point it was running just fine so I took it for a spin around the block. Everytime I accelerated
the CE would flash. Hmmmmm, what is going on here? Luckly I live about 2 miles away from my dealership, I pulled
in told them that I had a CE flashing and they checked the gas cap, and asked if I had tried to restart the car
yet. Nope, so I did that, reved it a bit and NO CE. Yippy! So I drove home and the CE never flashed once!
-mike
Dave
Major PITA on the front ones, had to use the torch on mine.
-mike
-mike
-mike
