Ryan
WOOHOO also he does have insurance which is good
? bad knock sensor or other. Thanks for any help!
Looks like we may be stuck with it.Doesn't appear that GM has any intention of a fix. Anyone else have any further info or solutions?
Also, I have a cold start knock from the engine when I accelerate from around 1300 to 3000 rpms. Once the engine warms up there is no knock at all. One cold morning when started the engine after it sat for a few days the knock was very loud, like a stuck lifter. It went away too when the engine warmed up. Any ideas?
Any suggestions would be appreciated. Also, hasn't the Blazer pretty much remained the same from '01 to '02? Do you think I would be safe purchasing the '01's?
would crank but not start. Used the wife's Hair dryer for about 5 min on wires-distributer then it started. Have you encountered such a prob.??
I had to replace the front wheel bearing on my '99 blazer a month ago. Price range anywhere from $152 to $450 ( just for part ), depending on where you buy it. Part is $452 from Chevrolet dealer. I think all parts on this vehicle must be made of 24k gold.
Everything I have to replace is High dollar. I expect to pay inflated prices for the parts for my '56 Coupe De Ville, but even after you find out the problem, ( Hopefully you don't have to go to a shop ) the part price is ridiculous!
Manuel Tipton
anyone know it?
I stopped in today because of the wiper problem many of us have had for ages but GM would never recall. Well, today I got a letter (G02054)from GM to tell me that it may be covered beyond the warranty period. Due to a cracked solder joint on the controller circuit board the wipers sometimes won't work, as has been mentioned here before. The letter stressed that this is NOT a recall in bold underlined letters. Hope this helps some of the rest of you.
The colorado will offer a Z71 offroad pkg.
1) I am getting a ticking sound that seems to be coming from the engine. It is only noticable at idle. Engine runs fine otherwise. I do know that I have a new, slight exhaust leak up front somewhere. Could this be the culprit? The exhaust muffles that much?
2) Next noise is one that sounds like a teapot that is just beginning to whistle. Did it when it was upper 60's here, quit when it dipped back down into the 40's, now it is back since the temps are in the 70's. It isn't effected by the A/C, acceleration, shifting, but today I noticed that the noise gets interrupted if I try to put the power windows up when they are already up. I have a feeling that it may be the fuel pump. Any other opinions? If so, what should I expect to pay for a repair?
Thanks to all for your advice!
Exhast leak is way up near the engine, so your theory could very well be right on. Thanks spoom. Going to wait until it gets worse before I worry about it. Everyone says I'm being too nitpicky anyways.
BALL JOINTS: What is the deal with getting these replaced on GM's dime? Just found out mine were bad. After calling the dealer, he said it was not a recall but a special program where GM "may" pay for replacement. Sounds shady. What do I need to do in order to make sure they pay?
Thanks everyone.
with the auto4x4.This is due to the fact that the front drive shaft is always turning even though it is not engaged. At speeds of about 65mph and higher the vehicle shakes and you can hear it also. They have already replaced the tires at no charge and this has not solved the problem. Now they are giving me the story about the unbalanced drive shaft that is a "common" problem. Have looked and asked around and know one has heard of this.
Since having the lower ball joints replaced it has not been nearly as prominent for me, but does seem to come and go. As I get more drive-time on these ball joints I should know more. Also, I will be doing maintenance on the differentials, drivetrain, and brakes this weekend. Should get a good long view underneath to spot any problems.
It is going back in the shop an monday and I will mention the ball joints to them.I will let you know what happens
Thanks agian
am going to invetigate the campaign bulletins mentioned in post #678
