Visitor Agreement.
tt66
Our Diamond Plan will cover the power sliding door on your vehicle. The Diamond Plan is our Bumper-To-bumper Plus plan. If you are interested, give us a call or contact us via email (info@warrantygold.com) and we can tell you more about it. Also, if you purchase an extended warranty from us or from anyone else before your 3year/36k factory plan expires, you will save money.
Take care,
Vanessa Lee
Technical Marketing Manager
Warranty Gold
I have seen a multitude of claims as to how the claims process works in theory,and what each plan covers( or doesn't cover) but there is a glaring absence of testimonials once the warranty is purchased...
Also, am I correct in assuming that the refund of premium is based on the greater ratio...i.e.miles driven per miles covered vs.years owned vs.year covered?
Sincerely,
Tony Rossi
It's actually several monthes till I'll need the timing belt and water pump. This is what I've expected when I purchased WG 2 years ago. If I encounter any problems, I'll e-mail you.
Tony
Please keep us posted, Oleg.
If you read my previous statement closely, you will notice that I said the timing belt needs to be replaced according to the manufacturer's warranty. However, if the timing belt goes out before the recommended time of 60,000 miles, we will replace it. Also, if you replace your timing belt at 60,000 miles and it goes out in a few thousand more, we will gladly replace it.
Thank you,
Anthony J. Rossi
Warranty Gold.com
If the belt breaks at 50,000 miles, does WG cover the whole cost, or just a pro-rated amount?
But when replacing the belt, the mechanic will always highly recommend replacing the waterpump. Even if there's nothing wrong with it.
If someone chooses not to replace the waterpump and it fails at let say 80k miles. It does not say in the maintenance booklet to replace the waterpump at anytime.
Does WG cover the replacement of the waterpump?
Also one more thing, does WG cover valve adjusting?
I own a 98 spyder, and my valves are starting to tick really loud.
Will WG cover the expense?
It does not say in the book, that this is a maintenance item.
I currently own a 5year/150k diamond plan.
thanks...Rob
60,000 Miles or 48 Months
• Replace engine oil and oil filter
• Rotate tires
• Replace engine coolant
• Replace engine air filter
• Repack rear wheel bearings (Paseo, Tercel)
• Replace spark plugs (maintenance service required under the Emission Control Warranty)
• Replace limited-slip differential oil (Supra)
Inspect the following:
• Valves (audible inspection), adjust if necessary
• Drive belts
• Fuel lines and connections, fuel tank vapor vent system hoses, fuel tank band
• Fuel tank cap gasket
• Charcoal canister (72 months) -- Non-maintenance item except for CA, MA, NY
• Exhaust pipes and mountings
• Brake: linings, discs/drums, lines, hoses
• Ball joints and dust covers
• Drive shaft boots (re-torque flange bolts)
• Steering linkages
• Automatic transmission and differential oil
• Rack and pinion assembly for leakage
Additional Maintenance items for Special Operating Conditions:
• Replace timing belt -- only required for extensive idling or low-speed driving for long distances as in heavy commercial use, such as delivery, taxi, or patrol car
• Replace transmission and differential oil
• Inspect body/chassis nuts and bolts
I'm not using my car for deliveries, patrolling streets or towing motor home. So, I guess, WG should cover the timing belt. Where is that Tony guy from WG? Is he going to do his job and dismiss any customers' concerns?
There is not one mention of valves in my maintenance schedule.
Warranty Gold gladly covers the water pump in all of our coverages. We also cover your valve jobs, SPYDER, under our definition of FAILURE-when a covered part has worn beyond the manufacturer's tolerances allowed for the particular Vehicle at the mileage when the problem occurs. As for you, OgelPhil, I apologize for any previous statements but can assure you that I will not lead you astray.
Until I think of something else...
As you can see, Toyota requires timing belt replacement only for Special Operating Conditions. So, will WG cover it if my mechanic still recommends to replace it?
If I decline replacement, given there is nothing special about my vehicle operating conditions, and timing belt fail, say, at 90K, will WG cover it?
If the manual says to change belts, air filter, etc at 30,000 miles, then you have to do it! However, if a belt breaks before that - say at 28,000 miles and causes some damage to other components, then the extended warranty should cover all resulting damages. If you wait til 40,000 miles and it breaks causing damage, the warranty company may or may not (and probably won't) cover any failed component because you were supposed to change it at 30,000 miles or whatever the interval is. I am not speaking for Warranty Gold on this issue, but it has been my experience that virtually all of the extended warranties work this way.
I have a question, Does WG require that the normal maintenance work ie: oil change, belt adjustments, filter replacements, brake pad & shoe replacement etc, work be performed by "Authorized" service personel or can I do the work myself? Will doing the work myself void coverage?
Planning on purchasing a 2k neon for da wife and will definitely be shopping for ESP.
Bruce
Scenario:
What if,
My car was experiencing intermittent hesitation problems under full throttle. The car is still drivable. Except when the peddle is put to the floor.
I take it to the shop, they experience the problem, but find nothing wrong.
They say we need the car for a week to troubleshoot the problem.
Will WG provide a rental car while the car is in the shop getting looked at?
thanks...
Reason why I ask this is that when I purchased my vehicle new, I notice the tire size on the door panel was different then the actual size tires on the vehicle. When I brought it to the dealers attention, he said this vehicle has custom wheeels and tires and was still covered under the factory warranty even though there was a slight difference other then stock in tire size. Does this hold true under Warranty Gold? Meaning does Warranty Gold still cover this vehicle bumper to bumper,or does it void the warranty on this. vehicle?
We appreciate your continued interest and can assure you that you are in good hands.
Sincerely,
Warranty Gold
I still haven't made up my mind although I am
definately leaning to a manufacturer backed plan.
Let's see if Warranty Gold can change my mind by
actually answering a few questions raised before
for months in this forum:
A few UN-ANSWERED questions for Warranty Gold:
1. What is warranty gold's cancellation policy.
For instance if I pay $1000 for a policy and cancel 5 years into a 7 year contract how much do I get back? Is it the rule of "78"?
2. At what point do you send an investigator out
to check a questionable repair? Is it a certain
dollar amount? Is it a certain type of failure?
3. How long does it take your investigators to
arrive on the seen? Is there a guaranteed response time?
4. If a car is out of service for an extended time
is a rental car provided? For how much per day?
For how long maximum?
5. Concerning "Good as Gold" do I get my original
warranty cost back as well as the extra "Good as
Gold" enrollement fee if I don't make a claim
during the term? How long does that refund take?
6. What happens if a repair shop doesn't accept
your payment system? Do I have to come up with
payment? How long until I get reimbursed? Is there a guaranteed minimum timeframe? Will you without question pay the repair bill in full?
7. Do you authorize original factory parts or do
you authorize generics if avaliable.
That's enough for now. Lets see how warranty gold
does with some focused questions which I am sure
everyone would like to know the answers to. Will
Warranty Gold step up to the plate or continue to
"bob and weave"?
Diesel Driver
P.S. Edmunds please don't hide my post I feel it
is well within my rights to ask Warranty Gold these questions as a consumer. Thank You.
I find it hard to believe there isn't one! I'm not going to pay for a call that should be free for consumers.
Please provide a toll-free # because I will definately check you out before risking any money. Thanks.
Management group ( from the BBB Ceco website)
Internet Addresses:
http://www.cecoh.com
http://www.warrantygold.com
http://www.auto4u.com
http://www.goldtravel.com
http://www.sentrygold.com
http://www.edmund.com
http://www.edmunds.com
http://edmunds.com
http://www.igs.net/carsecrets/warranty
http://www.cartips.com/warranty
Makes you kinda think doesn't it.
Guru
Why does Edmund's recommend Warranty Gold vehicle service contracts?
Edmund's reviewed OUR programs and determined that they are superior to others in terms of coverage, price, and customer service. Below, we highlight some items which set Warranty Gold apart from other service contract providers.
With Warranty Gold, you can select between four different levels of coverage for new and two levels for used vehicles, choosing the plan which will best meet the coverage needs for your particular vehicle, driving, budgeting, and ‘peace of mind’ requirements. We seek to provide great value for our customers!
Continues on with infomecial type statements.
Guru
I do need a little more clarification on some of your answers though.
Re: Question 1.
So the amount I would get back on a $1000 at the end of year 5 in a 7 year contract is 29% of the original $ 1000 or $290 refund. Is this correct?
If I find that the first time I have the opportunity to make a claim (year 3 or later) and Warranty Gold doesn't work for me do I get my entire $1000 back or just the prorated amount (ie 58% or $580 at the start of year 3)
If I get a claim paid by WG and decide to cancel later does this affect the pro-rated refund amount? Can I cancel at that point? Even if you paid a claim?
Do I get any portion I put into your "Good as Gold" provision back if I cancel ? Is that $100 or so prorated as well if you do refund that back?
Thanks for answering my questions. If I decide to buy I'll be sure to keep your answers in a file so I (and others) can use your answers should "issues" arise down the road.
So am I to understand that only in cases in which the repair amount is going to exceed the going rate by twice will you send out an investigator?
Or do you reserve the right to investigate any repair even if it doesn't exceed the going rates by much?
Investigations are based soley on exeeding the going rates by a great amount? Is it true that types of failures don't trigger an investigation?
You did not respond (I'm sure this was an oversight)
I'll repeat it here for and wait for your answer:
How long does it take your investigators to arrive on the scene? Is there a guaranteed response time?
Do I need to purchase damage insurance for the rental? Is that part of the $30 a day?
Is the rental coverage good on any covered repair and for multiple times during the contract?
What hours and days is an administrator availiable to authorize claims?
I pay the repair shop directly correct and get reimbursed? What if I don't have the money or forgot my wallet am I just out of luck?
Is there a guaranteed timeframe?
So for your convienence I'll post it here:
Does Warranty Gold authoriz original factory parts or do you authorize generic parts for repairs?
and I'll add:
Can a WG customer insist the repair be done with only factory parts and will WG approve that factory parts be used even though cheaper generic parts were availiable as well?
I along with many other consumers find your lack of response to this forum in the past, well disturbing especially when tough questions were being asked. I do appriciate the renewed commitment from both Edmunds and Warranty Gold to address questions and issues raised in this forum in a timely manner.
Remember your answers are being saved and printed out and as a representitive of warranty gold these documents will be evidence of what warranty gold presented as fact before I bought the contract should any dispute between WG and I arise years down the road.
Thanks again for your time and honesty.
Diesel Driver
I still think I've made up my mind. Well let's wait and see what Warranty Gold has to say.
Thanks Guru
Warranty Gold sent me and E-Mail a while back that was very in-depth to bad it was their exclusion list for their Diamond plans!!! It was in depth allright consisting of 675 words !!!
Here it is for all to read for those who don't know how to use e-mail attachments. I'll save Warranty Gold the trouble of having to e-mail it to you all. They should just post this on their website in the first place.
DIAMOND COVERAGE:
We will pay your selected repair facility for the reasonable
cost to repair or replace any failure of all parts of your
vehicle, except for those items listed in the Exclusions section.
*Again if it is not excluded it IS covered*
EXCLUSIONS:
THIS VEHICLE SERVICE CONTRACT PROVIDES NO COVERAGE OR
BENEFITS FOR THE FOLLOWING:
A. THE FOLLOWING PARTS: CARBURETOR; BATTERY; SHOCK ABSORBERS;
MANUAL TRANSMISSION CLUTCH ASSEMBLY; FRICTION CLUTCH DISC AND
PRESSURE PLATE; THROWOUT BEARING; MANUAL AND HYDRAULIC LINKAGES;
DISTRIBUTOR CAP AND ROTOR; SAFETY RESTRAINT SYSTEMS (INCLUDING
AIR BAGS); GLASS; LENSES; SEALED BEAMS; LIGHT BULBS; BRAKE ROTORS
AND DRUMS; EXHAUST AND EMISSION SYSTEMS; WEATHER STRIPS; TRIM;
MOLDINGS; BRIGHT METAL; CHROME; UPHOLSTERY AND CARPET; PAINT;
OUTSIDE ORNAMENTATION; BUMPERS; BODY SHEET METAL AND PANELS;
TIRES; AND WHEELS/RIMS.
B. MAINTENANCE SERVICES AND PARTS DESCRIBED IN YOUR VEHICLE'S
OWNER'S MANUAL AS SUPPLIED BY THE MANUFACTURER AND OTHER NORMAL
MAINTENANCE SERVICES AND PARTS INCLUDING, BUT NOT LIMITED TO:
ALIGNMENTS; WHEEL BALANCING; TUNEUPS; SPARK PLUGS AND SPARK
PLUG WIRES; GLOW PLUGS; HOSES; DRIVE BELTS; BRAKE PADS;
LININGS AND SHOES; AND WIPER BLADE. NOTE: FILTERS; LUBRICANTS;
COOLANTS; FLUIDS AND REFRIGERANTS WILL BE COVERED ONLY IF
REPLACEMENT IS REQUIRED DUE TO A COVERED FAILURE.
C. ANY FAILURE RESULTING FROM COLLISION; FIRE; THEFT;
VANDALISM; RIOT; EXPLOSION; LIGHTNING; EARTHQUAKE; FREEZING;
RUST OR CORROSION; WINDSTORM; HAIL; WATER OR FLOOD; ACTS OF
GOD; SALT; ENVIRONMENTAL DAMAGE; CONTAMINATION OR LOSS OF
FLUIDS, FUELS, COOLANTS OR LUBRICANTS.
D. ANY FAILURE CAUSED BY MISUSE; ABUSE; NEGLIGENCE; LACK OF
NORMAL MAINTENANCE REQUIRED BY THE MANUFACTURER'S MAINTENANCE
SCHEDULE FOR YOUR VEHICLE; IMPROPER SERVICING BY YOU AFTER
THE EFFECTIVE DATE OF THIS CONTRACT; SLUDGE BUILD-UP OR NOT
MAINTAINING PROPER LEVELS OF LUBRICANTS AND/OR COOLANTS; OR
NOT PROTECTING THE VEHICLE FROM FURTHER DAMAGE WHEN A FAILURE
HAS OCCURRED.
E. ANY REPAIR OR REPLACEMENT OF A COVERED PART IF A FAILURE
HAS NOT OCCURRED OR IF THE WEAR ON THAT PART HAS NOT EXCEEDED
THE FIELD TOLERANCES PERMITTED BY THE MANUFACTURER.
F. IF ANY ALTERATIONS HAVE BEEN MADE TO YOUR VEHICLE OR YOU
ARE USING, OR HAVE USED, YOUR VEHICLE IN MANNER NOT RECOMMENDED
BY THE MANUFACTURER. THIS WILL INCLUDE, BUT NOT BE LIMITED TO,
THE BREAKDOWN OF ANY CUSTOM OR ADD-ON PART; ANY FRAME OR
SUSPENSION MODIFICATIONS; LIFT KITS; OVERSIZED/ UNDERSIZED
TIRES OR WHEELS; TRAILER HITCHES; AND/OR MODIFICATIONS TO THE
ENGINE, EMISSIONS OR EXHAUST SYSTEMS.
G. IF YOUR ODOMETER HAS CEASED TO WORK AND REPAIRS HAVE NOT
BEEN IMMEDIATELY MADE; THE ODOMETER HAS BEEN ALTERED IN ANY
WAY SUBSEQUENT TO PURCHASE; OR IF VEHICLE'S TRUE MILEAGE
CANNOT BE DETERMINED.
H. ANY LIABILITY FOR PROPERTY DAMAGE, OR FOR INJURY TO OR
DEATH OF ANY PERSONS ARISING OUT OF THE OPERATION, TENDANCE
OR USE OF YOUR VEHICLE, WHETHER OR NOT RELATED TO THE PARTS
COVERED. LOSS OF TIME, PROFIT, INCONVENIENCE, OR ANY OTHER
LOSS THAT RESULTS FROM A FAILURE (EXCEPT AS PROVIDED UNDER
THE BENEFITS OR COVERAGES HEREIN.)
I. REPAIRS TO SEIZED OR DAMAGED ENGINES DUE TO CONTINUED
OPERATION WITHOUT SUFFICIENT LUBRICANTS OR COOLANT. YOU ARE
RESPONSIBLE FOR MAKING CERTAIN THAT THE OIL AND TEMPERATURE
WARNING LIGHTS/GAUGES ARE FUNCTIONING PROPERLY. YOU MUST PULL
OFF THE ROAD IMMEDIATELY AND DISCONTINUE VEHICLE OPERATION
WHEN EITHER OF THESE LIGHTS/ GAUGES INDICATES INADEQUATE
PROTECTION OR PERFORMANCE.
J. WHEN RESPONSIBILITY FOR A REPAIR IS COVERED BY AN
INSURANCE POLICY; WARRANTY FROM THE MANUFACTURER INCLUDING
EXTENDED DRIVE TRAIN, MAJOR COMPONENT OR FULL COVERAGE
WARRANTIES; A REPAIRER'S GUARANTY/ WARRANTY; OR FAILURES
FOR WHICH THE MANUFACTURER HAS ANNOUNCED ITS RESPONSIBILITY
THROUGH ANY MEANS, INCLUDING RECALL CAMPAIGNS AND FACTORY
SERVICE BULLETINS.
K. IF YOUR VEHICLE IS USED FOR TOWING A TRAILER OR OTHER
OBJECT OR VEHICLE WITHOUT BEING EQUIPPED WITH A FACTORY
INSTALLED OR AUTHORIZED TOW PACKAGE; OR IS USED FOR
COMMERCIAL PURPOSES INCLUDING, BUT NOT LIMITED TO, RENTAL,
TAXI, LIMOUSINE, LIVERY OR SHUTTLE, DELIVERY, TOWING OR ROAD
REPAIR, CONSTRUCTION, JOB SITE ACTIVITIES, HAULING, POLICE
OR EMERGENCY SERVICES, PRINCIPAL OFF ROAD USE, RACING,
COMPETITIVE DRIVING, SNOW REMOVAL, ROUTE-WORK, SERVICE OR
REPAIR.
L. ANY FAILURE OCCURRING PRIOR TO THE CONTRACT PURCHASE DATE,
OR IF INFORMATION PROVIDED BY YOU OR A REPAIR FACILITY CANNOT BE
VERIFIED AS ACCURATE OR IS FOUND TO BE DECEPTIVELY INACCURATE.
M. ANY FAILURE OCCURRING OUTSIDE OF THE UNITED STATES OF
AMERICA OR CANADA.
N. ANY COSTS IN EXCESS OF THE ACTUAL CASH VALUE OF THE VEHICLE
AT THE TIME OF THE REPAIR OR FAILURE.
