Visitor Agreement.
-mike
Could anyone please advice whether it's OK to clean the engine with those off-the-shelf engine degreases. It sounds like I just need to spray and wash it off with water. Is there anything that I should pay attention to such as electrical issues?
-Dan
Good idea?
Good deals?
Better SUV out there?
Thanks for any ideas!
I would also look at Mitsubishi Montero Sports. They currently have a $3000 rebate (hopefully, they can up it soon), much more compliant ride, good though thirsty 3.5l 197HP engine, better reliability than the Rodeo and a great powertrain warranty with free 3-year maintenance but... who knows who'll die in the market first.. Isuzu or Mitsubishi :-)
As far as spark plugs being dirty from oil, that's something that I wouldn't consider normal. If Isuzu thinks that their engines are supposed to consume oil for better lubrication, that's fine with me. It will result in cleaner oil anyways as you basically add a quarter or two of fresh oil every oil change period. However, oil on the spark plugs is a different story and i'd have them check on it as it might result in some serious engine problems.
Any input?
Also, I've noticed that often times, dealer will fix something and won't tell you that they did. I guess they are trying to hide some flaws that they know but the don't feel the consumers need to know.
As far as CE light, whenever it goes off, take it to Autozone or any other parts store that might have a code readers. It takes couple of minutes (you don't need any appointments) and doesn't cost anything. I was glad I did, as my fuel sending unit has failed and whenever I'm next to the dealer, the damn light wouldn't go off. They read the code and when I took it to the dealer, I was able to tell them what the problem was.
-mike
are they fairly good trucks? someone mentioned the Montero Sport. to me, the Montero seems a little....delicate.....compared to the Isuzu. i guess both makers do really well in commmercial truck sales.
so which is the better vehicle? i personally like the interior of the Rodeo better. but on either one of them, resale has got to be just awful....right?
also, why does the Rodeo have such a low tow rating?
I have a 2003 Rodeo 2wd V6, I got it 09/2003 with 8 miles on it (I now have 34,055 miles) I do drive a lot. { see my old post under the prizm page. }
My first problem is the bad gas mileage, I only get about 16 mpg ( no matter if its city or hwy ). anything I can do to increase the mileage?
2nd issue, the ABS light came on I noticed that a lot of others have had this problem, what could cause this?, show the dealer fix this ( at no cost to me?)
3rd, anything I can do to keep this Rodeo running well?
*** ( I'm upset that the cost has gone way down on the 2004's I paid a lot for this 2003 )***
Thanks for all the information.
Squeak...
1. Where would i find the A/C compressor to locate the fittings?
2. How would i know if its R-12 or R-134?
3. If it is still R-12 what is the best method of doing the conversion from R-12 to R-134 (draining old..installing new) myself?
Thx..Jerzy
When I finally sold the vehicle it had about 110,000 miles on it. The interior was a bit scratched up and dirty but the engine was still clean as a whistle....
The manual says that when I drain the coolant, I need to do that by using the valve on the radiator as well as through the valve on the cylinder body. I spent a good 20 min under the car, but couldn't find any more valves anywhere. Also, I've never seen a car that required several valves to drain the coolant.
I can understand a little difference in what I drained vs. what I put back in due to the air "plugs" somewhere in the system, but my concern now is that I only drained half of the coolant.
I did run a car for about 5-7 min to make sure there is no more air in the system, but I could only fit a "tea spoon" of water after that.
Actually I don't think Isuzu has ever manufactured an interference type V6.
-mike
starter on driver side. I never try to open it.
I usually disconnect small hose from heat exchager where you oil filter screw on. It will
get you another 3/4 gal of coolant from engine block and heater unit. V6 engine sometime have
one drain on radiator and two drains on engine block(one for each bank).
That's almost what I ended up doing, except I didn't notice any drain hoses next to the filter (I wasn't really expecting to see anything over there, so I didn't look too careful).
I ended up unpluging a hose from the heat exchanger on the left side of the engine (if you are looking at it). There are two hoses, and I disconnected the top one - it was just easier to get too. After that, I started filling the whole system with water from the garden hose until clean water started flowing from the disconnected hose. When that happened, it meant that the system was free of antifreeze (hopefully) and full with water. After that, I put in about 1.25 gal of antifreeze through the radiator, which pushed 1.25 gal of water out of the system through the disconnected hose. As the result, I should have (theoretically) about 50/50 mix in the system.
I guess the main problem with this approach is that you will have antifreeze on the ground no matter what you do. There is absolutely no way to capture what's draining from the hose on the hood level.
I'll look at the drain hose next to the filter next time.
He does not have any engine problems, just traction problems, which makes me think he has poor rear tires.
I have a 98 2WD V6 Rodeo, can anyone recommend any good shocks? I have almost 109k on it and I think I'm still riding on OEM's. If you have any recommendations that would be great.
What do you all think of buying a ROdeo for 17 K vs a Camry for 18 K?
If you really need an SUV, a car is not an option. Needing an SUV means you tow or have a need to go off road, which are two things a car will not do. If you are only concerned with cargo capability, get a wagon or a crossover. The bottom line is that if you are asking this question, you really do not need an SUV, so get a Camry, or an Accord, Mazda 6, or some other car.
I got a set for my Trooper and love them.
I'd get the Rodeo for 16K. Any other full-size wagon or crossover would be in a different (much higher) price category. You get the decent 3.2 V6 engine, auto, ABS, tires and suspension that will outlast those on any regular car. Plus you can load it up to the roof if you need to.
Some of us are flexible about what we drive and it mostly comes down to price. I'm actually eyeing a red Camry SE-V6 to replace my old compact... pickup truck. I also am tempted by a loaded Mazda6 wagon for $21K but it's a Ford though it looks nice... If GM sends me that additional $2,000 rebate like they did last December then I might even get the Aztec - that's how flexible I am :-)
-mike
Depends on how long you want to keep it. In the long run the Camary is gonna cost more to keep up than a 2wd Rodeo due to the fact that it's not going to take abuse nearly as well, which is fine for 50-100k but once you push past that 100K mark, the rodeo will withstand harsh roads.
Just my take on it, long term the Rodeo will cost less and hold up better IMHO.
-mike
I know that my brakes are somewhat worn - it shakes when I brake at high speed - but they are silent when I brake. It's when I accelerate backwards is when that noise comes up.
Somebody suggested that it could still be brakes since when I back up, the wheels turn in to different direction and if the pads are not worn evenly, they'd start squeaking. This doesn't make too much sense to me as the sound never comes up when I brake.
I am planning to take it to the brake inspection in a week or so, but I'll need to replace the pads and machine the rotors soon anyways (61K+ miles on original brakes). However, this doesn't sound right.
oh, also, at first, the sound would come when it was wet outside. Now, it is mostly noticeable when its dry and not very cold. Go figure...
I kind of thought of brakes (even though I wasn't blaming it on rears), as the sound is very similar to brakes sounds when they are worn. However, the sound never comes up when I brake. It is only there when I back up with the wheels turn and disappear when I slow down after backing up.
I'll definitely have them checked, but I'm just curious about the physics of the problem.
