Visitor Agreement.
Anyone have any opinions on this?
can someone throw out the site(s) where the wood grain dash kits are available? thanks.
-johnskev
IF 44 is max and 26 is the minimum and they both will wear out your tires faster, why not split the middle at 35psi and get the benefit of both? Seems like that would work well. My 40,000 mile tires on my 99 Silverado had 45,000 on them and could have gone a few thousand more by running 35psi.
This is what these boards are for, I am glad to have everyone adding their points of view because it has helped me!
Dano
Steve
Dano
Steve
Where is this located? I have an SE with manual transmission. Maybe I don't have this feature? Can someone describe to me where this thing is in their vehicle?
thanks,
Howie
Without actually looking at the tube you're talking about (I've never bothered to follow it back), I'd guess that it is the breather tube for the crank case (having something to do with the PCV valve...maybe indirectly). What you've done with the sealant should work fine, provided the seal holds.
I look forward to seeing your pictures and descriptions. I'm looking forward to upgrading my exhaust and I'm starting to look into different options.
It's like Christmas.
Howie
The owner's manual recommends changing the oil at 3,750 miles or 3 months whichever come first
During the earlier days, metal shavings in the engine are experienced for the first few thousand miles during what we refer to as the break in period. That is the reason why during those days it is always a good idea to change your oil earlier than the recommended interval
New engines built with better technologies do not experience metal shavings anymore and if any can be very minimal
I am not very technical on this so maybe someone who knows better can share their idea
I will be changing my oil at 3,000 miles
Steve
-johnskev
ikroskin@kdgpc.com
Then I had a little trouble finding the right drain plug...I didn't want to drain the diff and the pics weren't great. The owners manual pic was pretty poor...even the pic in the service manual wasn't great but I figured it out (stop laughing...really...I've always changed my oil but I'm not used to so many drain points!). It was a pleasure, however, to be able to get under the car and see everything without getting it up on blocks (with my Integra, a cat had trouble fitting under there).
Then...although I had bought a filter wrench that fit the new filter...the OEM filter 65F01 was too small. So I used the 'drive the screwdriver thru the filter and turn' method. A bit messy, but effective.
Can anyone tell me where the L14610 filter can be found?
Tom
Dano
Please tell me more about your system.
Thanks in advance.
full5.
being nissan owners.....thought you might car
240HP 3.5L 0-60 6.3 (stick shift)
looks sweeeeeeeeeeeeeeeeeet
www.freshalloy.com
and www.nissandriven.com
www.nissannews.com ( i think)
CAI:
I really think that if we petition Hotshot performance (http://www.hotshot.com), John would build a CAI for us. Hey jmtreetop, who makes the Max's CAI that you modded? Was it a PlaceRacing piece, HS or Stillen?
-Cheers!
Try to visit www.intellichoice.com and click the standard feature of the car you want to look at
Some vehicles I know of with dual climate control are the Cadillac Deville, Lexus 430 and the 2002 Escalade SUV
Anyone had anyproblems with it yet?
joe
That's the only answer that matters. Everything else is personal experience and specualtion.
Your approach is interesting, but actually...you will have an alternating 67/33 mix after the first few fill-ups (I checked in a spreadsheet). I don't know how you would get a 50/50 split, but you'd have to use small fill-ups. You could do it more easily by filling with half of each. Not that I think it's worth it to do this for a few pennies, just an exercise.
In any case, I never got an answer to my post.
Tom
That's the only answer that matters. Eveything else is personal experience and specualtion.
WRT to the gas octane, you might want to read the Gasoline FAQ, section 6.15
TC
We know what the manual requires...the question is, whether a mix could satisfy it.
Tom
