Visitor Agreement.
Brian
Whereabouts are you in Canada and which PF do you have? Did you get special Nissan fainancing? 2.8% ?
I just returned from a 1900 mile trip to Colorado (funeral, not planned) with my 2001 PF LE. I tracked the mileage (started with about 1680) and drove mostly 75-80 across Kansas and eastern Colorado. One leg returning I actually got 20.6 mpg but the average for the whole trip was 18.6 which I thought was pretty good. Now have about 3850 miles and most of my day to day driving is in a rural area with lots of hills and stop and go. Mileage has been averaging 15 to 17. I do believe it improves as the engine breaks in.
As far as tire pressure, I called the dealer last night to get their recommendation. I have the Bridgestone Duelers. He said if the side of the tire shows maximum of 44 psi that they inflate to 35. If maximum shows 35, they inflate to 32. When I bought the vehicle it had 32 psi and I thought the ride was beautiful. When serviced, they inflated to 35 and ride is somewhat bumpier. Think I will go back to 32. (26-28 seems a little underinflated to me) Anyway, vehicle performed flawlessly for trip and I am yet another very satisfied Pathfinder owner!
Steve
2001 Burnt Cherry PF LE
Personally I always run between 32psi and 35psi in my vehicles (32 for the Pathy). IF I had something with low profiles tires I'd have them 40+ as spec'd for the tire. 26psi seems low. Guess this is personal preference and everyone should try out different pressures to see what works best for you.
Dano
At least the Xterra has more space and is a good off-road truck, but I envy you all for buying the better vehicle!
I am one of those buyers not as knowledgeable as you.
Before we even try to make this an unfriendly board, one should skip the topic if he or she is not interested in it.
I agree with bob_path that assuming you are right that Nissan inflates the tire 40 psi for shipping, the dealer should at least correct the pressure before they sell it. That to me is common sense.
There will be new participants in this forum and it will always be nice to share experiences with them.
We will always see topics on pricing, oil filter change, the location of the micro filter, and tire pressure already discussed in the past. I do not see any problem with this and if current owners want to share, it is up to them to do so. If not, they can always ignore and skip.
Like bimmer4me I stick with Nissan's recommendations. (I know you are enjoying driving your PF in Palm Srpings)
I for one as a silent reader in the past and continue to do so, have enjoyed immensely from this forum from both the pros and the cons. and I will hate to see it stop now.
I just enjoy coming home from a hard days work to read what these fine people on this forum have to say for the day. Irrespective of the subject. As you should be aware by now, I am a proud owner of a 2001 Pf. SE 5spd. And I owe my thanks to these unselfish people on this forum.
Folks keep up the great work.
full5
"Cabin air filter & install". Yesterday, I removed the trim piece with the hidden screw behind it. Remove the two screws in the glove-box that are on the black "tabs" (they really are tabs). Then you just have to rotate the trim piece up and it comes right off. I fixed my dash "gap" that was left because the top right screw was not seated into the upper dash piece.
So, for those wishing to intall or replace the cabin air filters, these are the steps I use to remove the glove box and lower dash assembly:
1. Remove glove box hinge "pins" and remove glove box.
2. Remove the two screws holding the "Pathfinder" logo'd trim piece and remove the trim piece.
3. Remove the three screws holding the dash lower panel (one on bottom left, one on bottom right, one on top right), then with the top left part pulled open/down remove the glove box lamp from its' holder on the dash lower panel (rotate it 90 deg).
You can now remove the lower dash panel and have at the filter install or replacement.
It's very easy once you know how to actually do it (new instructions please Nissan).
Now I just have to figure out how to install antenna fittings for a cell and amateur antenna in the roof (sigh).
This is a very fine SUV and I hope BMW solve it quick. We do not want another Explorer sindrom on again.
full5.
How long dose it take for the clear coat on the 2001 pf. to cure before waxing?. And where do I find these fine Zaino polish to buy?.
Thank you all in advance.
fUll5.
Do you love or hate this product???
Other than perceived financial advantages of not having to replace the air filter everytime, is there better performance outputs???
I'm not sure I should pick one up here locally for $60.00 Cdn ???
TIA
K & N Air Filters - Bolt on Power?
Steve
Visit their web site where you can read more about the product and where you can buy them
http://www.zainobros.com
I will also be interested to know when you can start applying polish in a new PF with clear coat
Steve_host
Thanks Steve. I have already posted before I saw your posting. I will visit the sites you have suggested
The reason I'm writing is because I then looked at the Pre-Delivery Inspection sheet that was in the glove box. There in bright red letters was "Check Tire Pressure" and it was checked off! By the way, the recommended pressure is 29psi or so. If I had seen the PDI sheet and just trusted it, I'd think the Forester has a really "lively" ride.
So what's a guy to do? Here I have a dealer basically telling me that the tire pressure has been checked. I don't think it's fair to assume that a buyer has to do that checking him/herself, especially when a dealer says they have. Now that I know how inconsistent dealers are about this, I'll check them all from now on.
It's due to boards like this that I now know these types of things. Before I got on Edmunds (way back when :-), I didn't even know cars were shipped with higher tire pressures. Some people may know all about cars and dealers, but the rest of us are here to be helped (and to help out when we can), which makes this a great place to hang out.
Sorry for the long post...
-Dan
I'm going to take this opportunity to comment on what I've found when perusing other Edmunds boards (I DO have a life...but sometimes, when I'm on 'free' time, I check them out). Let me tell you...for those of you that haven't 'trolled' (and I think there are good trolls and bad trolls...I'm a 'read/only' troll...that's the good kind in case you didn't know:-) ), there are some boards where half the posts are from folks that don't own and aren't considering the subject car and basically just trash and taunt the ones that do. It can be pretty disruptive and the subject gets lost in the cat fur. I know this is one of the downsides of the anonymity of the internet but some people can get out of hand. I've seen some otherwise respectable list contributers trolling several different boards making questionable comments...we're only human, I guess.
So I guess my point is...we're lucky we have such a great group here with mostly great info and folks willing to help those who have questions even when we've heard them a hundred times. On this board, folks feel free to ask even questions they think are dumb (I've asked quite a few myself) 'cause they know no one's going to jump down their throat. Of course, it doesn't hurt that 'our' car is such an excellent example of craftsmanship with too few faults and so many happy owners (BTW, is it my imagination or are there a gazillion 2001 PF's out there...it seems I see them everywhere!).
Ok...sorry for the long post, had to get that off my chest...besides...I'm waiting for the rain to end so I can go back to work on the boat!
Tom
Is this the correct K & N Filter to buy for the 2001 PF?
33-2031-2
I know that there has been much discussion on this in the past on this board, but after a search for the correct filter # earlier today I didn't come up with anything. Thanks for any help!
How much can I expect it to help??????
Dano
Bimmer4ME, watch out for those manufactures suggesting certain settings. Is that not what Ford and Firestone are dealing with right now?
I am about to close on a 39 month, 39,000 mile lease on an SE automatic with sunroof, in cabin microfilter, body color side moldings, sunroof deflector, floor mats, and mobile entertainment system. I really didn't want or need the entertainment system but it was already installed on the SE they were trying to sell me. I think they were having a tough time moving it because of the entertainment system. Anyway, they gave me the best deal I've found in 3 months of looking. It is a Chase Manhattan lease with $500 down plus first payment due at signing. Payment is $409/ month. $909 is total due at signing, all taxes, fees included. I think I did OK. Thanks to everyone on this board for all of the valuable information. It really helped me make my decision. I will finalize things tomorrow, so wish me luck! Any thoughts on the deal?
Dano
1. My truck came ith the OEM rear air deflector but dirt seems to cover the whole liftgate more than anywhere else. Are you people experiencing the same thing?
2. K&N filters...are they beneficial or do they actually let more air bypass in the name of performance?
3. What a gas hog this truck is! So hard to ease up on the gas pedal with such a powerful engine!
4. The wheels appear to be aligned but the steering wheel is off-center...when truck is going straight, steering wheel is off to right approx 5 to 10 degrees!
5. Should I start putting 100% synthetic oil in this beast? Would it be beneficial?
6. I hear you guys talking about Zaino a lot. Have you ever heard of LIQUID GLASS? Is that product any good?
TIA
I have polished and waxed my 2001 Pathfinder as well as my last two new cars two weeks after I have bought them and never had a problem. I use Meguiars Gold Class products, but sure the Zaino are the same type.
Hope this helps.
$0.02
I just test drove a new PF and it seemed as though the steering wheel was off-center... It tends to steer to the right when driving straight.... Anyone know if this is normal? i own a 95 Maxima and do not have the steering problem.
Thank you in advance,
Aris
We called Nissan to cry BUT they couldn't care less. I guess I can agree with them BUT I only took delivery 2 days ago! I guess it's all a gamble and I wouldn't be complaining if their rate increased from the 2.8%. Oh well...on the positive side, the 01 PF is just an awesome truck with a terrific engine.
BTW...while crying to Nissan, I found out the new 02 Maxima will be equipped with this PF engine but it will be tuned to 268 HP !!! WOW...just awesome stuff...I need to get a Max as a 2nd car!
I'm gonna get a K&N filter and S.S. exhaust tip for my PF...any thoughts?
TIA
Where else can the deflector be had for around $65?
Dano
There are a couple of good paragraphs that discuss street-tire pressure, near in the middle of the article.
http://4x4now.com/sfjun96.htm/sfjun96.htm
It appears that the proper air pressure in tires depends in part on the weight of the vehicle and the tire manufacturer's specifications for the tire
Nissan has "recommended pressures" because they know the vehicle weight and which tire brands they put on the trucks at the factory.
If you ever install a different brand or size of tire, you might need to change the pressure accordingly.
PYRENUS
One shot in the dark: look beneath the dash at the clutch linkage. There should be a pivot, and that pivot may be binding or dry. Give it a shot of penetrating lube and work the pedal. Maybe it's binding enough to absorb your foot effort and not actually throw the linkage? Doubtful but maybe. Or if there's a cable maybe it has a lube port?
These are where I'd look first. Regards, -Bob
