Visitor Agreement.
But if you have a little wiring knowledge, it shouldn't be that hard to make your own switch to keep at least one outlet constantly powered. Just hook up a fused wire from the battery to the switch, then connect the switch to the positive connector on the 12v outlet by using a wire-tap ("Scotch-Lok") connector.
If the switch is on, the outlet is always powered; if it's off, it operates normally (with key in ACC position).
Great little mod I might try!
I had my 7 months old '01 Pathfinder in for service as well, and the dealer replaced the instrument panel clear plastic for me. I have noticed since installation a few weeks ago, an accumulation of dust etc. sticking to it, so bought some Meguire's Clear Plastic polish, which is said to reduce static - so far so good. It appears that by wiping the panel, scratches can occur. My theory is that if I can reduce dust attraction, scratches will be lessened?
Woody
Full5.
The crash results were low on my list of concerns when i bought it. That's not to say it doesn't matter though. To be honest i'm very impressed with the Paths abiiity to corner, handle and brake which all play big parts in avoiding an accident.
Don't forget to take the front & side airbags, abs, AWD, and structural components into consideration before passing on buying the Pathfinder.
Just my thougts,
S-66
Sorry if this seems like a thick-headed questions, but sometimes it's the simple things that causes me the most problems.
Has anyone noticed abnormal vibrations while braking? Like the pads or rotors are warped? My Path has only 3200 miles on it, so i don't think the brakes should be undulating.
S-66
Hope this helps,
Keith
I guess i'll just ignore the manual and follow your lead dieselone. I don't know why they'd say to only use ECON for heating...seems kinda kooky. Could be i misread it or something, but don't think so. Anyway thanks for your relplies.
S-66
Besides the 2002 SEs are going to have the 2001 LE wheels (what's that about!), so i'd like to keep mine differentiated from the 2002s.
I have actually had my rotors replaced twice due to warping over 34k miles. I drive aggressively, but not absurdly so, and often head to the mountains during the winter. I'm hoping the current set will see next summer, but who knows ...
Just out of curiousity, I looked at the manual, and yes it says to use econ mode to heat only. I guess you can read that a few different ways. I think what they are trying to say is don't use econ mode to cool the vehicle, because obviously it won't cool outside air. I don't see anything wrong with using the econ mode merely to bring outside air into the vehicle.
my 2 cents
I'm also gonna have them check out my quirky rotors when i take it in.
Just wanted to let everyone know they should be getting similar letters too.
Y'all have a fun weekend
S-66
Other than these recalls....I love the pathy.
The recall you're thinking of IS for struts- the rear hatch 'struts'. (Same thing that sabre66 mentioned).
sabre66-
You mentioned that 17" wheels would give you more ground clearance than 16". That's not necessarily true. The wheel-to-tire size ratio changes with the new wheel size, and the ground clearance will likely be nearly the same. 17" wheels mean there's less rubber between the wheel and the road (lower profile tire). If you're concerned about ground clearance for off-highway use, I'd stick with the 16" wheels and get 265/70R16 tires.
You can get Brigestone Duelers in 265/70R17. Wouldn't that provide 1/2in. more ground clearance? Aren't tire profiles measured from the edge of the rim to the outer edge of the tire and not from the center of the wheel. (i could be wrong)
In any event with 17 inch rims 265/70R17 tires may rub on the wheel-wells, so they may use a lower profile (65 or lower). Not sure how they'd work, and since i don't have the spare cash right now i'll probably have to wait and see what size tire they put on the 2002s.
Thanks for the reply,
S-66
255/65R16 and 245/65R17
According to my (rusty) calculations, the 17" wheels are only half an inch higher which gives you a quarter inch of additional ground clearance. The compromise is that the 17" wheels give up a quarter inch of sidewall height. Neither is a very big compromise (plus-one sizing rarely is).
However, the 265/70R17 tires you mention are a different matter. They are 2 inches taller and 3/4 of an inch wider than the stock 17" setup. They would provide more ground clearance AND more sidewall height than either of the stock setups, but they would be a very tight squeeze and likely rub or bump. I think Dean (xplorx4) has a good compromise at 265/70R16 as it is less than a half inch wider and an inch taller. I will likely replace my tires with this size when they wear out.
The biggest difference between the stockers is the "look". I agree with you, I definitely prefer the 17" look, but I know we'll get hammered on the "trade-in".
I tried 265/75R16's, but they rubbed the fender a bit while turning, and came to within 1/2 of the struts. Under even moderate articulation, there would be some contact.
Just a note, the rims have enough offset that they don't even come close to rubbing on the insides of the wheel-wells like my old Cherokee, just the front of the fenders and flares.
gritz
does the Phillips bulb H3 have the amber color (ala QX4) and does the BlueVision really has a blue tint in it?
Full5.
The IIHS crash test is a good test for the vehicle's structural strength/safety cage. The NHTSA's test is a good test of the vehicle's restraint systems. Both tests complement each other, however, the IIHS' is said to be more real world as a deformable barrier (resembling a front end of a similar vehicle) is used, rather than the concrete non-deformable wall in the NHTSA's test. For more information, follow the link below:
http://www.crashtest.com/explanations/nhtsa/index.htm
Drew
I swapped the factory tires on my 2001 LE 4x4 with a set of Pirelli Scorpion A/T's in 265/70R16. Here are my impressions after about 2,000 miles:
* Severe drop in gas mileage. If you look back on some of my early posts, I was one of those Pathfinder owners who was consistantly hitting the 19-20MPG mark on every tank(I do a quick calc every time I fill up). From the first tank after the tires were swapped, I can't break into the 17's on any tank. Same commute, same grades of fuel and all that. I attribute this to the engine now running at a lower RPM (not in it's optimum band), heavier tires, meatier tread.
* More sluggish on the acceleration. This is more on the weight, size and tread of the tire...but I think most of it is the new gearing problem with larger overall diameter of tires
* More road noise. This should be obvious...But at this point, I can't remember what the factory tires sounded like. It's perfectly acceptable, just a little more hum.
* Flat spots. The Pirelli's "flat spot" when I'm parked all day in a 100 degree parking lot. This causes an imbalance for the first couple of miles then works itself out.
* Traction off road! Thrilled with the grip!
* Maximum size you can fit! I got into a real frame-twister yesterday with the rear passenger tire stuffed up into the wheel well and the axle flattening the bump stops. The driver's side tire was just dangling in mid air. You get the picture. I stopped, got out and checked the clearance. The front edge of the tire was 1/16 of an INCH from fully contacting the wheel well trim...Like the fender flare part. Any bigger and the flare would be toast.
* Looks! Love it. The truck sits a little higher, the tires are a little beefier than the factory ones. Great look!
Over all, I'm very happy. I've now been doing so much off-roading with the Pathfinder that I'm concerned about squeeks and rattles and dents and the like... So, I'm actively searching for a trail truck...like a Jeep CJ that I can beat up and return the Pathfinder to stock tires and shiny paint!
Anyway...I hope that helps some of you...if you have any questions or want pics of the Pathfinder off-road, send me an e-mail!
I'm off to wash the mud off and hit it with another coat of Zaino!
Captain Ron
ron.chase@internetmachines.com
Good luck with your decision,
Drew
S.Fl.
Bob
The rest is probably a gearing issue, as you said.
evaluation and it was given a 4.3 for Safety (out of 10). Does anyone know why???
There are no reviews on the site and so I don;t have a clue.
Check out NHTSA at their Web site.
Steve
they are the Pathfinder Sport SUV sold by the Discount Tire chain (tires.com). They are actually made by Kelly Springfield and have a 60k mile warrantee.
After a week my impressions of them on the pavement are great. The ride seems to be a bit softer than the Bridgestones. and there is no wandering at all like some A/T tires. It has been dry as a bone here in Denver for the past week, so no idea on how they do in rain/snow.
We are heading to Canyonlands UT in two days for some backcountry camping, So I'll have a report on how they do off-road next week.
I live in a winter climate, and am concerned about the effect of salt, sand etc, on the Nissan alloy rims on my 7 month old '01 Pathfinder XE. I understand that the rims are clear-coated. Has anyone who lives in a winter climate noticed any damage from the past winter? I have P245 70 R16 tires supplied from the factory. When the speedometer reads 100 km/h, my GPS reads 97 km/h, hence a 3% error. Should I decide to purchase a winter type tire, what size shall I look for?
Woody in frosty British Columbia
For the winter I will also switch to snow/ice wiper blades and I put a set of Focus headlight covers on to protect the lenses from gravel rash. I also add a set of Husky custom liners (floormats) as they provide the best coverage of the carpeted area I have seen to date.
I find the stock Bridgestone Duelers are quite adequate for snow and ice. I'm sure there are better snow/ice tires out there, but the stockers never let me down, particularly with 4wd. I don't plan on changing them out. Hope this helps.
I only have 7000 miles on my 2001 PF LE, but so far no problems (other than a hard downshift from 3rd to 2nd which never seems to get any better).
Has anyone had this problem with their 2001 tranny or had the PCM replaced?
Evidently, the SE and LE have a different wheel offset; Captain Ron was able to fit 265/70R16 tires on his without any problems.
