Visitor Agreement.
http://www.nissannews.com/nissan/2003vehicles/murano/index.shtml
p.s. all my relatives loved my PF!!
Happy Pathfinding!!
Steve
Although I have rotated these tires only twice in 35K miles, they are wearing evenly. I have not experienced the outside edge wear that others have reported here, and I attribute this to my driving rather conservatively much of the time as far as turns and curves go. In fact, most of my driving is on the freeway. I assume SUV's have more of a tendency to chew up the outside edges of tires due to the higher center of gravity, especially in hard turns and curves.
Despite all the negative comments expressed here about these tires, I have been relatively satisfied with them. I do virtually no off roading, and the Duelers seem to be good enough in 2 feet of unplowed snow, so I don't think I'm looking for a tire with a more aggressive tread pattern. In fact, I would prefer a tire biased towards good handling, wet stopping ability and a comfortable, quiet highway ride rather than strong off road ability.
My truck does suffer from the occasional 60-65 MPH steering wheel shimmy that has been discussed here many times, but based on the comments here in the past it seems clear that the shimmy problem is not related to the Bridgestone tires, as many owners with other tires have reported the same problem.
Any recommendations regarding replacement tires? What have your experiences been? Thanks in advance for your comments.
I ordered them from etires.com and their service was very good. Seems to me they were about $400 w/ quick shipping. UPS lost one of them and etires gave me no hassle in sending another. They are tied with Michelin in JD Powers Report for owner satisfaction, have a treadware rating of 500, temperature A, and traction A.
I don't think you can go wrong with'em, just rotate them often (I do with each oil change, 5K)
The shop you used did not install the air bags properly. They should have removed the bump stops, not cut them off. The bump stops are easily removable with a 12mm socket and extension.
They also should have drilled out the hole in the lower spring perch to 3/4", even if they did install the plastic disc under the bag. Failure to drill out the hole to 3/4" will cause the air lines and hose clamps to pinch during suspension movement. Eventually the air lines will break open from the constant contact with the too-small hole. (I know this from experience. I installed the airlift myself, and I only had a 1/2" drill bit, so I got lazy and figured it would be OK. Not!
Visit this link to see photos of my installation
Pathfinder Jiggles on freeway expansion joints:
Sorry to break this news to you, but this phenomenon is caused by the Pathfinder's wheelbase and suspension. In fact, this is not unique to the Pathfinder; many other vehicles with similar wheelbase have the same problem. The effect is more noticeable at speeds between 35-50mph, but lessens above 60mph. (I agree with you that it's quite annoying!
By the way, after the initial installation, the Pathy door was open so I closed it. Lo and behold the doors had been locked by the shop people (accidentally, I'm sure) so I was locked out. They called a guy in that they use for such things and he managed to slip a thin bent rod down along the window glass and up the inside to push the electric lock to open the doors. Then he couldn't get the rod out, so he had to pull the inside of the door panel out so he could get his hand inside to free up the rod. Today I noticed that he had put some dimples in the outer skin of the door. I'm now waiting to hear from his company so I can tell them they need to pay for it to be fixed.
Some days just don't go well. Bad Karma or something.
I agree with PF01 that it would have been nice if Nissan had changed to an independent rear suspension the last time the PF was totally redesigned in the mid 90's, but I disagree that competition dictated the need to.
The PF competes well against its competition - the truck based SUV's listed above (of course one could that the PF is not really a truck based SUV given it's unibody construction...so perhaps there's a third category...non car based SUV's with unibody construction...this would include the PF and Grand Cherokee) Anyway, the RX300 is not really a direct competitor of the PF. It is a car based SUV that does not have the off road nor towing capabilities of a truck based SUV like the PF. The trade off is that the RX300 has a car like ride, and the PF has a more jiggly (trucklike) ride.
The opportunity Nissan missed was to not have a car based SUV before now...but PF01 is correct...development funding was limited at Nissan, and a car based SUV may have looked like a big gamble 7 years ago.
I do disagree with PF01 on one point. There were at least two other significant unibody SUV's on the market in the mid 90's...the Cherokee and Grand Cherokee.
What pressure seems to work best for light load conditions? Does the kit have any effect on ride or handling during light load conditions? Any additional noise from the suspension?
I frequently tow a boat and trailer totalling about 4300 lbs., and I estimate the trailer tonque weight to be about 100-125 pounds. Given that the towed weight is so close to the 5000 lb. towing capacity specified by Nissan, I try to minimize passengers and cargo in the truck when I'm towing. Does anyone have experience with the Airlift kit at a similar tonque weight? What inflation pressure do you use? Does it significantly improve the ride and handling when towing? Currently my rear suspension bottoms out frequently when towing, and at night I'm blinding oncoming drivers with my headlights.
Thanks in advance for your input.
I know you have some big hills in your area...you might need to go all the way down to second gear to pull a 4000 lb. trailer up the hill from SLC to Park City with a PF! I do have to climb a very steep hill for about a mile to get to my house and I do get a wiff of burnt trans fluid on a hot day.
If using the truck for towing, the owner's manual calls for an engine oil and filter change every 3750 miles or 3 months, a trans fluid change every 30K miles or two years, and if equipped with a limited slip differential, a rear diff gear oil change every 15K or once a year. I am installing an air lift kit to assist the rear coil springs...not certain if you will need to given the equalizer hitch you use. Note that model year 2000 and earlier PF's have a much less powerful engine. Although Nissan rated their towing capacity as 5000 lbs. (same as model year '01 and '02) I would assume they would not be as adept at towing 4000 lbs. One last thing...the stated towing capacity for late model PF's with manual transmissions is only 3500 lbs. versus 5000 for an automatic.
Previously I had a Grand Cherokee with a V-8, and the PF seems to be better at pulling my boat (although the Jeep did seem to handle the tongue weight better).
My wife and I just bought a beautiful, black 2002 4wd PF SE with pop. package/auto climate control plus a tow hitch for 27k (and 3.9 financing)(out the door--fees, tax, etc.--for low 29k). I think this is a good deal, but am interested in other's opinions, as my dad is now seriously thinking about going back to the same dealer and getting one at the same price. It was a positive dealer experience overall, but it took almost 6 hours to close the deal.
Also, when I asked the dealer about breaking the engine in, he said just to not drive a constant speed for more than a couple minutes for the first 500 miles. Any other suggestions? I want this car to last for 15+ years, so I wanna break it and maintain it very well. Thanks!
tidester
SUVs
Under normal conditions, 5-10psi is fine. Most of the load bearing is done by the stock springs, and it's not necessary to provide extra support. Plus, your ride might be a little harsher.
With passengers aboard, 15psi is pretty good.
For towing a boat (150 lb. tongue weight) I have gone as high as 25psi.
The max recommended pressure is 35psi, which results in a very harsh, nearly 'springless' ride with an empty vehicle.
In addition to the Air Lift springs, I installed manually adjustable aftermarket shocks which help dampen the vertical oscillations of the springs when the rear is heavily loaded. (Springs carry the load, shocks dampen the spring motion.)
When I tow or carry passengers/cargo, I tend to use 15-20psi and a middle setting on the shocks (Rancho 9000 shocks, part number RS9116).
I should add that since installing the air springs I have not bottomed out once. Nice.
I used a rubber tie-down that has an s hook on each end. I wrapped the tie down around one of the brackets that holds the rear bumper in place and the muffler just behind the canister. My father-in-law had a heat resistant material he uses for welding which I placed beneath the tie-down were it wraps around the tail pipe. The end result is it holds the exhaust about an inch away from the hitch frame and I have not had a problem with this setup since I rigged it up last August.
I think any type of bungie or rubber tie down will work in holding the muffler away from the hitch.
Sorry it took me so long to respond, I've been out of town.
You've got a Pathfinder. That right there says you got a good deal. I wouldn' worry about if you got a good deal or could've gotten a better one. You already have it am I 'm sure you're happy with it. Enjoy! and welcome to the club with people with good taste.
robc5-
Black is beautiful!! I checked your price on carsdirect.com and assumed you also got auto tranny. The price was close. Sometimes if you tell the dealer you looking at an auto-locator such as carsdirect, they wil say they will beat the price. I mean why not, if you can get the car for less elsewhere? I was very happy with the dealer treatment I got. So I didn't mind paying a little more than carsdirect. By the way there are only two Nissan dealerships in San Diego County. One which has about seven outlets and as they call themselves the "other Nissan dealer".
Manual on break-in was 1,000 miles varying speed. I would also go easy on the brakes. Loved my Pf so much I put 1K in about 3 weeks.
Happy Pathfinding!!!
Steve
The Altima offers a carry bag (maybe for a laptop) or a nice watch. I haven't ordered any other brochures but I'm sure they also have stuff. Infiniti does not do this.
GM announces recall of 1.9million cars
Thanks again, Crete.
Enjoy yours.
rorothere
Dear GM:
This letter is regarding a Pathfinder LE that was delivered to me this evening. To say I am unhappy with this car would be an understatement. I have the following issues with the car:
• The mobile entertainment system is a cheap substitute for the factory model. I was told I would have the same system installed as the factory model. As I mentioned over the phone, the VCR was installed in the wrong location. Equally important, the video screen installation was poorly done. The ceiling rattles over every bump and the interior ceiling itself is flimsy.
• The car has almost 400 miles on it. Matt said the car was driven from the coast. I was told that the car would be delivered on the back of a truck. I am basically paying full price for a semi-demo car. I have not viewed the exterior in daylight but can imagine that there will be scratches on the front end from being driven on the interstate.
• The car has a strange smell. It smells like a car that is two years-old, not a new car.
• The hitch was not installed as the factory hitch is. The trailer plug was left loose in the interior instead of integrated with the hitch as it is supposed to be. The step for the hitch is missing as well.
• There are scratches in the dash wood trim.
You can have the salesman bring you up-to-date with the delays that I had in having this car delivered in a timely fashion as promised.
At this point, this car is completely unacceptable. Given some of the fundamental problems mentioned above, I will not accept this car. Therefore, we can review the other Pathfinders you have on the lot, and we can take delivery of one of those. For example, you have an almost identical car as the one I ordered, but it has the navigation system. I would be willing to buy that car and pay $1,500 more than I paid for the car that was delivered.
The bottom line is that I will not accept a car that has had any options installed by the dealership, as I have absolutely no confidence in the installation capabilities there.
It is my sincere hope that we can reach some kind of compromise on this issue so that I do not have to walk away altogether.
Me again...I'm probably in for quite a fight on this one, but we'll see.
tidester
SUVs
But over the last two days it isn't working consistently. Is there a limitation on the angle or distance the transmitter needs to be from the receiever on the garage door opener. Do you have to pull down the sun visor to get a better transmission? I can't seem to find a consistent location of where it works or doesn't work.
When I let the air out of the system until the automatic sensor starts the compressor up, the gage shows about 0 psi. I called Air Lift and they said the gage isn't very accurate at low pressures. He suggested I put a test gage on the system to check at that low pressure and if not correct, there is an adjusting screw at the back of the gage to adjust the sensor so that the system is more accurate at the minimum pressure (maintains it at 5 psi.) He also said there should be an air stem in the system that I could put a gage on to make the check. I'll have to look under the car to see if they installed that. Knowing how sloppy they were with the installation, it's probably not there.
Anyone else have this experience?
I also am reading about users changing to synthetic oils. 1. What are pros & cons? 2. Some say change to ALL synthetics. What other fluids? I know PF are due for complete redo in 04, but I will have to wait for 05 or06 for next one.
I've already switched to Mobil1 engine oil which gave me a slight increase in mileage. I've been using this oil in my other cars for years. I don't use synthetics for any of the other lubricants.
I currently have a 99 Blazer and 2k Silverado. Both Chevy's just drop to second almost as fast as you floor it. The Nissan dealer says this is normal so you don't feel the shift. It seems as if Nissan is limiting the power to protect the transmission during the shifts.
Is this normal? Should I drive another one?
A similarly optioned Pathfinder LE comes out to $31,398 (Leather, roof, limited slip ....)
What makes the QX4 worth an extra $4,000?
Has anyone else checked their mileage on regular here?
As far synethics go, there is the differentials, transmission, and engine oil. Low on the priority list, but also on the lubrican list is the power steering and brake fluid (yes you should change your brake fluid at least ever 2-3 years).
I slowly (as time permits) migrate to 100% synthetics in all of these areas... Cost is minimal (except for motor oil) and the benefits are substantial.
I favor Redline and Amsoil (two of the oldest and best) for my vehicles. Send me a note if you need more info on where to find them.
For Fuel Economy...
Don't want to be a sourpuss, but you can't easily base fuel economy on just one tank. There are just too many variables in the equation to get a reliable number from one data point.
