Nissan Pathfinder
19293959798158
  • bigorange30bigorange30 Member Posts: 1,091
    http://www.sharonview.org/carbook.htm shows the items listed below as what is on the QX4 that is not on the Pathfinder LE with leather. It also shows an Invoice Price difference as $3405.
    Mechanical
    • Lightweight molybdenum-coated pistons
    • Variable-induction intake manifold
    • Continuously variable valve timing
    • Lockup torque converter
    • Brake transmission shift interlock system
    • Direct ignition w/platinum-tipped spark plugs
    • Full length steel fuel tank skid plate
    • Independent strut-type front suspension w/coil springs
    • P245/70SR16 all-season SBR tires
    • 16 x 7.0 3-spoke aluminum-alloy wheels
    • Full-size spare tire w/aluminum-alloy wheel
    • Pwr engine-speed-sensitive rack & pinion steering
    • 4-wheel anti-lock braking system w/load sensing proportioning valve
    EXTERIOR
    • Body-color body-side moldings/fender flares/door handles
    • Front/rear mud flaps
    • Body-color grille
    • Automatic-on/off multi-parabola xenon headlamps w/manual leveler
    • UV-reducing glass
    • Tinted driver & front passenger windows
    INTERIOR
    • Front/rear outboard seats-inc: height adjustable head restraints
    • Genuine wood trim
    • Cut-pile carpet w/matching floor mats
    • Stainless steel door sill plates
    • Retained accessory pwr for windows
    • Pwr locks w/selective unlocking
    • Illuminated entry system w/theater dimming & battery saving feature
    • Infiniti vehicle immobilizer system
    • Remote electric liftgate glass/fuel-filler door releases
    • In-glass & pwr antenna w/diversity system
    • Analog clock
    • Triple front cup holders
    • Overhead console-inc: temp display, digital compass, dual map lights, storage
    • Leather-wrapped shift knob/parking brake
    • Cargo area light
    SAFETY
    • Steel pipe door guard beams
    • Energy absorbing steering column
    EMISSIONS CERTIFICATION
    • LEV certified (3.5L engine/4-speed auto trans)
  • wildcorgiswildcorgis Member Posts: 84
    Some of the things that I noticed that the QX4 has that the Pathfinder doesn't--- extra year of warranty, Better treatment and service, different look-especially with the side cladding and I love the wood steering wheel.
    But some of the things you listed are also on the Pathfinder. Mechanically the two are twins so most of the difference is cosmetic, luxury cosmetics at that. When the QX4 had the auto 4WD thing while PF had the extra gearshift that was a pretty substantial difference.
    The QX4 is definitely more prestigious. If I had a choice of which car to drive, it would definitely be the QX4. I just couldn't justify paying more. Regardless of which vehicle you have, they are both great!!
    On the regular vs. premium debate, 'I've only tanked up about a half dozen times, 50% regular and 50% premium.One caveat, I do drive slowly and conservatively. But I have found no difference in performance or gas mileage. I get between 17-18mpg consistently, excluding long freeway trips (20mpg).
    Happy Pathfinding!!
    Steve
    If you will check on the link I showed, you will find that all of the features I listed are either not listed on the Pathfinder or the features exist but are a little different than they are on the QX4. If you have a Pathfinder with some of the features exactly as I have listed them, which features are they? People deserve to know the truth. I do understand if you can't afford the extra $47/month on a 5 year loan that it costs but it is not much when you are already paying over $500/month.
  • li_sailorli_sailor Member Posts: 1,081
    I own a 2001 LE. I can tell you that most of the features you listed as not on the PF are indeed on the LE PF. I won't list all of them, but it seems like it's most of them. The engines are identical, so I believe all the mechanical ones are the same. Some examples of features you list that the PF LE has are:
    • UV-reducing glass
    • Infiniti vehicle immobilizer system (just substitute Nissan for Infiniti)
    • Cargo area light
    There are others that I think are the same but I'm not positive, so I left them out.
    The basic difference between the two (besides cost) is extra soundproofing, the extra warranty and a few "special" items on the QX4.
    li_sailor:
    Your statements are not supported by any documentation I can find. The nissan website http://www.nissandriven.com/vehicles/ModelSpecifications/0,9439,20702||,00.html calls out the specifications and the first 4 are not mentioned at all. The 5th one "retained accessory power for windows" is described as "Accessory power delay (30 seconds)" on the Pathfinder. That is not the same thing. I will grant you the immobilizer point, the overhead console and the Energy-absorbing steering column as they are on the Nissan site. The leather wrapped shift knob/parking brake is not listed. The cargo area light is not listed. The "Rear load-sensing proportioning valve" is listed for the (4x4 models) so you would have to add the cost for 4X4 if you are going to claim that too. I know car companies like any other industry will advertise anything that is there so why do they not list it on their website if it is on the vehicle. Can you list a link to a site that calls out these things that you say are on the Pathfinder that Nissan does not claim?
  • 2001se22001se2 Member Posts: 1
    I've had mine since new (30k now). Since 15k approx. had problems with highway shimmy. Slight , but definite. Dealer not able to figure out. Found some info on chatroom about a US bulletin that described my problem to a "t". Dealer wouldn't repair under warranty however (claimed it is an 'adjustment'). I gave dealer copy of bulletin, so they did preform a steering rack adjustment. Didn't fix the problem. It is very annoying to drive the vehicle anymore.
    Has anyone had similar experience? I was wondering about the rubber (Yoko). Tires have been rotated, balanced numerous times in search of problem, but no luck. I have had tire problems in the past with other vehicles...?
    Any thoughts or help would be greatly appreciated.
    Doug.
  • smokey75smokey75 Member Posts: 434
    Hey bigorange30, I have a 2001 PF LE & I have to agree that almost every option you listed is also on mine... especially when it comes to mechanical. Keep in mind that just because it's not listed on the Nissan website doesn't mean it doesn't have it. The main differences are cosmetic (exterior & interior). Seems to me the $3405 you quoted as the difference hardly pays for itself, especially when I hate the exterior looks of the QX4, but that's just my opinion. But, it does buy you more prestige because you own an Infinity (wow) & a little more plush vehicle inside, so if you're into that kind of thing... by all means buy a QX4
  • xplorx4xplorx4 Member Posts: 621
    Mechanically the QX4 is identical to the Pathfinder LE 4x4. In fact, aside from minor variances in exterior and interior styling (and minor 'luxury' features) there's not a whole lot of difference. Just because there's no published information about the Pathfinder feature set doesn't mean that it doesn't have it. All it takes is a peek under the hood and under the chassis to see the similarities. With the Inifiniti, for the most part you're paying for the extra service amenities, free loaner cars, etc. The trim differences are just icing on the cake (and a way for the QX4 to be marginally unique.)
    Look at it this way: Imagine you're the director of marketing for Nissan Motors, who manufactures both the Nissan Pathfinder and Infiniti QX4. Now, you know that you want to charge more for the QX4 than for the Pathfinder LE because, well, it's an Infiniti. So it makes more sense to "downplay" the Pathinder LE options so you can make buyers believe the "superior" QX4 is really a great bargain. Infiniti knows and admits that they are handicapped by the fact that virtually every luxury automaker has its own unique SUV, while Infiniti is forced to rebadge a Pathfinder and just change its appearance a little.
    Don't take this message the wrong way, though. Infiniti is a great automaker and has an excellent reputation for service, so for many buyers that's worth the extra $50 or so per month in the payments.
    I myself wouldn't mind having a QX4. I think it's got better HID headlights and (among lots of other niceties) a remote switch to pop the rear glass. That is worth something to me!
    In February 2002 Nissan sold 5150 Pathfinders and 1181 QX4's. Your arguement about downplaying the Pathfinder's included equipment to make the QX4 look more attractive is just insane because instead of attracting more sales to the QX4 it would just take more sales away from the Pathfinder to a Honda or Toyota $30 M SUV. The arguement some of you have stated that they are "mechanically the same" is wishful thinking. How do you know that the Pathfinder has lightweight molybdenum-coated pistons that are not listed in the Pathfinder literature? Did you take the engine apart and do a metallurgy test on them? Did do you take the engine apart to see that it has direct injection, variable-induction intake manifold, continuously variable valve timing. In other words, there is no way you know that just by looking underneath it. You can't logically claim that they are "mechanically the same" unless the literature says that it is. In fact, Nissan salesmen go to a lot of effort to convince you guys that the engines are the same without offering you any shread of written proof.
    2002 Pathfinder Brochure reads verbatim , " 01: SMOOTH OPERATOR Minimize friction and the engine does everything it needs to do with a lot less friction. That's why we put a slick molybdum coating on the pistons and why we microfinish the surface of the crankshaft and camshaft.
    Happy Pathfinding !!!
    Steve
    Don't know if this holds any water but almost every review, I've ever read says the QX4 and PF are mechanical twins. Even the reviewer here at Edmunds:
    Can't figure out how to put the link in here but it's stated under 2001Infiniti Spin around town and under New (top of this page) Infiniti QX4 Overview .
    They say "But when all is said and done, the notoriously tightfisted Edmunds.com bunch would stick with the Pathfinder LE, with its identical engine, underpinnings, similar option list and as nearly as opulent an interior."
    Still the QX4 is a gorgreous truck and a worthy selection from Infiniti.
    Happy Pathfinding!!!!
    Steve
  • phillyguy3phillyguy3 Member Posts: 88
    Since the PF is not due for a redesign until 04, I can't understand why they are not "clearing the decks" with blowout prices. I know they still have the 03 to contend with, but they are also creating their own competition with the more modern Murano, not to mention the rest of the field.They always offer some lease or cash back program this time of year so that's nothing special. Of course I have selfish reasons since my lease is due in 2 months and I would like to see a terrific deal.
  • bkfulbrightbkfulbright Member Posts: 15
    Just wondering if anyone else had read the latest review by Edmunds on mid-size SUV's. Is it just me or are they not comparing apples to apples in this review. Nothing against the Explorer or any of the other SUV's for that matter, but I think the Pathfinder got a raw deal since they did not use an LE with similar equipment like the other SUV's in the test. Any comments?
  • jflashjflash Member Posts: 45
    No, I don't think that the PF got a raw deal. Look carefully at the test score breakdown and you'll see that, for the most part, the areas in which the PF scored poorly were those in which the trim level didn't matter (dead last in the cupholder category, for instance. CUPHOLDERS?). Storage space and cargo loading were also low scores and are the same for the SE as the LE. I'm sure that the Explorer impresses the editors, but with my hard-earned money I opted for Nissan quality and the much longer powertrain warranty.
  • wlee8wlee8 Member Posts: 7
    Please check the website for Nissan and you will discover that the Pathfinder and the QX4 are almost identical except for a few luxury items to added to the luxury end of the spectrum. For example, the QX4 has HID and a different cruise control option.
    www.nissannews.com
  • crikeycrikey Member Posts: 1,041
    Go to http://www.nissandriven.com/vehicles/ModelAttributes/0,9443,20862|31005|,00.html and click on 'VQ Technologies'. It says:
    What's the secret behind Pathfinder power? Something we call VQ technology, which combines the use of precious metals, lightweight materials and race-bred engineering. An aluminum engine block, cylinder heads, and pistons add up to light weight and superior strength. Friction-reducing measures include molybdenum-coated pistons and a microfinished crank and crankshafts, both of which help the engine operate more smoothly and last longer. And double platinum-tipped spark plugs help Pathfinder go 100,000 miles without a tune-up.
    Click on 'Variable Intake, Variable Valve', it says:
    Breathing is everything. Anyone with a trained voice or a Nissan engineer will tell you it's the secret to power and range. For example, Pathfinder's Variable Intake System automatically changes how air flows through the manifold according to engine speed. You get plenty of thrust off the line; then, as rpm rise, it opens a shorter air path in the manifold for a more direct pipeline to power. Continuous Valve Timing Control similarly changes engine "breathing" according to conditions. It precisely modulates when intake valves open and close, factoring in throttle position, vehicle speed and engine rpm. Again, the result is outstanding low-rev acceleration, with deep reserves of passing power.
    I am pretty sure that the QX4 and the Pathfinder are mechanically the same, i.e. engine, brakes, etc. The QX4 just has more luxurious amenities than the PF to justify the difference in price. But both are exceptional vehicles.
    Finally some documentation on the issue. I stand corrected on the mechanical twins and understand your position. Having said that, I would not buy a Pathfinder because I don't like the way it looks. I didn't even consider it when screening the QX4, Lexus RX300, Toyota 4Runner and Toyota Highlander because of the less classy appearance comparatively. I did buy the QX4 and love it.
    You are right jflash. I didn't really look at the test score breakdown, but what I was talking about was the written reviews where every other SUV had the auto(push button) 4WD and the Pathfinder didn't because it was an SE instead of an LE. Also every other SUV had leather, heated seats which once again the LE has and an SE doesn't. I currently own a 01 LE and have been very pleased with my decision on buying a Pathfinder, which is also the first Nissan I have ever owned. Check back later!
  • hmamontovhmamontov Member Posts: 10
    Hi
    Is there anybody from Miami area? I'm looking for a new Pathfinder LE but don't really know where to go for it. Could anybody advice me good (or at least not bad) dealership around Miami, please? Any information about real prices and deals etc would be very useful. One more question: I have some doubts about what I need - 4x2 or 4x4. Is there any advantages to have 4x4 in Florida?
    Herman
  • tbobbytbobby Member Posts: 9
    Herman
    I strongly recommend you use the "price" a new car link at this website. Buying a car online was very pleasant for me. All you are doing by using this link is emailing the salesmen at all of your local dealerships telling them you are an internet customer and are interested in buying. They will call and/or email you back with their best price. They know they are all competing against one another, so they offer decent offers up front. In my experience, 4 out of 5 of these salesmen had very good, competitive offers. You can then go the dealership of your choice to check out/test drive/buy the car. My buddy's wife bought a 01 LE at 14% off of MSRP and I was able to get a O1 SE at 13% off of MSRP (won't bother giving you exact numbers because MSRP actually went DOWN roughly $1K for 02) (imagine that). I think you will have much difficulty even finding a 4X4 model anywhere in the southeast US. They are not in much demand here because it never snows. I saw some bogus dealer add-on fees on some random stickers (like paint sealant for $500 and $600 for advertising and $800 for reflex paint which was identical to the regular paint). Assume everything a salesman tells you is either a lie, a psychological ploy or plain ignorance and you will do OK.
  • cretecrete Member Posts: 105
    Wow.. A lot of verbage here for comparing the QX4 vs PF. I test drove the QX4 after the Pathfinder and found no mechanical difference other than a slightly smoother (cushioned) ride. A more luxurious interior with more appointed leather and wood trim in the QX4. As well as a few other features mentioned in the past few posts. But overall IMHO I think Infiniti which did not have an SUV in the market had to compete with Lexus, and others somehow. So to get something out there quickly they re-badged the Pathfinder with luxury features and few options and marketed it as the more re-fined SUV.
    I think both the PF and QX4 are very good SUVs, if you want to have a more luxurious look and feel with possibly better dealer service, go with a QX4 but you'll pay the extra costs. Although my Nissan dealer was just as friendly and professional as the Infiniti dealer I went to. So I went with the PF and I'm very happy with it.
    See, all the fuss for nothing... Well, maybe not nothing. You were given evidence to support our claims that the vehicles are nearly identical, and our "wishful thinking" wasn't just pipe dreams after all.
    In re-reading your posts about the QX4 and PF, you opened by stating that you got a power antenna, wood grained steering wheel and classier look for around $3000 more. Then somehow (justifying the extra $3000, perhaps?) you got stuck on pointing out the mechanical superiority of the QX4 (but that was shown to be false). And now you're back to "I didn't like the looks of the Pathfinder anyways".
    Well, honestly, I'm glad you enjoy owning and driving the vehicle you purchased. It's your SUV, after all. My first car was a Hyundai 4-speed hatchback with no radio or AC. I hated dropping the monthly payments on a car I disliked driving, but at the time it was all I could afford.
    I just think that many other people on this forum are interested in saving some money and not wanting to spend $3400 more for a prettier version of the near-same vehicle. The bottom line is that the differences between the Pathfinder XE, SE, LE, and QX4 are simply better trim levels, in ascending order. Early QX4's were much different mechanically because of the full-time 4WD transfer case, but now the playing field is even with the PF LE. Still, the QX4's bonus is that it's backed by Infiniti's service, which puts most Nissan dealers' service to shame.
    So if you want to talk about the differences between the PF LE and QX4, focus on the service experiences and trim niceties (like rear window release), not the major mechanical differences. And hey, if your temperature gauge reads dead on in the summer, let us know, and tell us how your sensor is mounted because that seems to be one of the 'hot' topics here when the weather warms up.
  • wcrolandwcroland Member Posts: 26
    I have a 2001 LE with 15k miles on it. I noticed when I use Econ setting for heat, that I am now getting a musty smell? Does anyone have this? When I use the Auto setting it works fine, but when it's 40 degrees outside, you should be able to use the Econ setting.
  • jgobravesjgobraves Member Posts: 5
    Going to the dealer tommorow to try to finalize a deal on a new pathfinder. There is just one questions they say i have to get this paint and leather protection plan for 5 years which cost $599.00. From what i get if any time in the first five years i have any stains or spills they well clean for free or replace if need and on the paint if sap or bird droppings damage they will fix to. Personally i dont think it is worth it but he keeps saying there no way around. He also says it back by nissan but i dont see anything about this on nissan wesite about this. At this point i think i might just go to another dealer what do you guys think. Thanks sorry for going on and on hopefully this makes sense
  • jmsmithbc1jmsmithbc1 Member Posts: 9
    My opinion for what it's worth: go to a department store and buy 2 cans of Scotchguard for the fabric and wax your PF regularly and you'll be fine.
    I did w/my O1' SE and it's got 45K on it and everything I've spilled (coffee) on the fabric beads right up. I think you're dealing forcing you into an item not required!
    I too had the same shimmy starting at about 63 mph w/my 01' SE. I made the mistake of rotating my tires initially every 10K.
    I've since bought Toyo Open Country A/T's and rotate them every oil change (5K) and have had no problem. I've got 45K on the PF and about 15K on this set of tires.
    By the way, love the Toyo's and great price at etires.net (about $90/tire +shipping) Good luck and there are several posts on this issue way back on this board.
    THis is one of the biggest rip-offs ever perpetrated on the car-buying public! Dealers give the car a silicone sealer wax job and spray the seats with Scotchgard then tack $600-&1000 onto the sticker price. Last month, when I was shopping for my new SE, I stopped by a dealer that used this tactic. I told the salesman and the sales manager that it insulted my intelligence and that I would NEVER buy from a dealership that automatically tacked on such a charge. I made a good buy at another dealer that was more honest. NEVER pay for this, or the old "undercoating" scam either.
  • pf01pf01 Member Posts: 35
    I cannot help myself post this again and again. For those who have already seen a similar message or two, please bear with me. If you were in the U.S., you could just go to hunter.com and find a Hunter GSP9700 computerized balance machine, which was specifically mentioned in the Nissan Service Bulletin I got from my dealer last summer(I am not sure if there is a new version of the bulletin that tells a different story). Note that Nissan just gave you an example, in fact any computerized balance machine should be able to do the job. I found a GSP9000, but I still had a slight shimmy above 70 to 75 miles after balancing all four tires. My break came 2 months ago. I had a flat tire, one of the five original Toyo tires. I found a Toyo authorized dealer(the phone number should be somewhere in the Pathfinder's manual), they had a balance machine that was similar to GSP9000. They switched one of the old tires with the spare, so I got two new tires. The result? shimmy no more, even at speeds up to 90 mph.
    To shark715: you are correct, Jeep was the first one to offer unibody SUVs. Nissan engineers obviously were aware of the jiggle ride, so they soft-tuned the springs of the rear suspension, hence the bottom-out problem. Similar problem is seen with the 4Runner. The solid axle rear suspension just cannot be made to give you a comfortable ride that is comparable with the independent rear suspension.
    Aren't we bitter. If you go to http://comp.autosite.com/configurator/code/advantage.asp?AICWS_Parm1=1&AICWS_Parm2=20024822232916516613805178 you sill see the advantages of each on the Pathfinder vs. QX4 debate. The $2657 lower price is interestingly low.
  • woodyr1woodyr1 Member Posts: 142
    Here in Canada, a small number of Nissan dealers also sell and service Infiniti vehicles. I had some warranty work done on my 01 Pathfinder XE (cheapest of the lot), at an Infiniti/Nissan dealer, thinking that they may offer a higher quality of service. They diagnosed a problem with a roof pillar and had to remove part of the headliner. Greasy fingerprints were left over after the job was diagnosed and greasy feet left stains on the underside of the driver seat (light beige colour upholstery). When I confronted them about the stains, they indicated that the detail guy never had a chance to get to my vehicle before I came to pick it up. In both cases, I had to scrub the vehicle in an attempt to remove the stains. Months later when they went to remove the headliner, they kinked the headliner when replacing it, left it that way, and never told me.
    I don't think I would have done any worse at a regular Nissan dealer.
  • mbuntingmbunting Member Posts: 158
    I had not visited this fine forum in some months - due to working way too much lately.
    I had planned on buying a 2003 PF from Vancouver, Canada - if it was going to be the bigger, redesigned model from Nissan.
    Looks like I won't be able to save the $$$ by purchasing in Canada now...what a bummer. I now live close to the border (Seattle, WA) and this would have worked out great.
    I even had a co-worker ask me about my 2001 PF LE and how much I paid for it. I gave him the "GO TO CANADA" spiel that has drawn so much attention here and the board - THANKS TO JON !!!
    He was pumped....and I told him that I would get all the imformation together for him tonight and all he had to do was pick out a color!!!
    He is gonna be ticked at me tomorrow when I tell him buying in Canada isn't an option now.
    Many thanks need to go out to Jon Lofquist - he should have gotten commission on those 70+ sales he helped with.
    Thanks Jon !! (even though I bought my PF in Maryland last January 02')
    Save your money and pass on the paint protection. Buy a good leather protectant spray and car wax, or even a good nylon car cover. If you can, don't park under trees whenever possible.
    One question about exterior care.... The manual says to avoid using tight-napped or rough cloths, such as washing mitts.
    I was looking at buying one of those washing mitts, but how does one determine if it is of tight-napped construction. Has anyone used these mitts and if so, what kind?
    Your link didn't work for me. "File not found" error. As for being bitter? Was that we or you? If there's anything for me to be bitter about it's the fact that my Pathfinder lacks the nice 240hp engine available in the newest models and the 2.5:1 low range in the auto-mode t-case. Then again, it's already paid off, so I'm loving not having the $500 monthly drain.
    But I'd be more than happy to adapt some QX4 parts to bolt them onto my aging 97 LE if it makes my life easier. Your truck does have the remote rear-glass release, right? And if your external temp gauge reads accurately in the summer, please tell us! Seriously. This was a topic of great debate last summer.
    Hi, I tried your link only to get an error:
    Directory Listing Denied
    This Virtual Directory does not allow contents to be listed.
    Maybe this is a good place to end the QX4 vs PF comparison for now.
  • jecklesjeckles Member Posts: 87
    Well a lot has been said, but I couldn't sit on my hands any longer.
    When I bought my PF 1-yr ago, I admit I didn't consider the QX4 and probably should have. However, I didn't like the looks and desired a utility vehicle capable of off-roading. Lexus and Highlander were out because they were CUV not SUV (car-based). 4Runner was out because it was too weak, but I loved the looks and back window.
    So Between the two Nissans (QX4 & PF); Enough people have said it, but there really are very small differences between the two vehicles!
    The HID headlights, remote hatch release, and real wood trim are the ones I would say are significant.
    I don't want to hurt anybody's feelings, but the majority of things things listed by bigorange are marketing magic. Why wouldn't Nissan say there were differences between the two vehicles (even if is only the way they name the features...) Their goal is to differentiate the vehicle as best they can; even if it means downplaying the nearly identical features on the PF.
    The internet is a good resource, but many of the sources rely on surveys filled out by car manufacturers or administrative assistants reading through marketing brochures. Not all surveys are completed, or are entirely accurate...
    Bottom line: Consider both cars and pick the vehicle that suits your needs and taste. The price difference is small to some and big to others. At QX4 prices I would be in BMW or MB.
    Sorry that first link didn't work. Use this to go to the site and then find the Pathfinder and do a comparison. This also a very good site for lots of information including market/sales information.
     http://www.comp.autosite.com/configurator/code/makes.asp?AICWS_Client=autosite
    As for my temperature gauge, I will check that when it gets a little hotter. Right now it seems to take about 3-5 miles of driving for it to read correctly. I believe they are calibrated under driving conditions with air flowing across them. They are mounted in front of the radiator the manual says. And yes, it does have the remote rear glass release. I really wish it released the whole door and not just the glass. We open the whole door more than we do just the glass.
    Sorry for my ignorance on this issue but what is a shimmy? and does it do it all the time above a certain speed?
    I too was a little dismayed at the 2nd place finish of the PF.Maybe the reviewers thought the PF is to small in the back seat but I think it's fine for a mid-size, while the Explorer borders on large-size. The Explorer sure can look impressive on paper with the cavernous interior, third row seat , innovative options such as adj. pedals and reverse sensing system, towing capability, V8 stump pulling power and I think it looks nice too. For the long term I think the PF is a better buy as it will be more reliable. If you lease an Explorer, it's probably a great deal.
    My two cents on fabric protector; not worth it. Unless they are giving you an unbelievable deal so the treatment cost is very small, I would recommend doing what I did which is buying a couple cans of Scotchguard and DIY.
    My little boy walks all over the seats with his shoes and I'm constantly wiping the seats off with a damp rag which so far has been very effective.
    Steve
    wildcorgis - Anyone please correct me if I'm wrong, but the extent of my knowledge of a shimmy is a vibration or slight movement felt through the steering wheel at certain speeds. I had an acura which had a shimmy and was caused by improper tire balancing on the front wheels. It usually occurred around 50-60mph. Other causes can be uneven tire wear, air pressure and is some cases warped rotors when applying the brakes. In my particular case it was the after market custom rims. They were not perfectly matched to fit on the spindle like the factory wheels are, thus causing uneven rotation of the wheels. Every place I went to could not properly balance the tires until I found a specialized alignment shop that balanced the tires on the car. As mentioned in previous posts, proper tire balancing (those done on the car at the speed the shimmy occurs) hopefully can eliminate the problem.
  • poppadoc1poppadoc1 Member Posts: 11
    HI ALL, I'VE NOT BEEN KEEPING UP WITH THIS SITE LATELY. I ALMOST HATE TO ASK BUT WHAT'S THE LATEST INFO REGARDING THE NEXT GENERATION PF, THE NEW FULLSIZE NISSAN SUV, AND THE CROSSBOW CONCEPT VEHICLE. ANYONE SEEN THE CROSSBOW LIVE AND IN PERSON AT ANY OF THE AUTO SHOWS? THE PICTURES ARE VERY IMPRESSIVE. I LIKE THE RETRO LOOK. TOO MANY SUVS ARE STARTING TO LOOK LIKE MINIVANS.
    Are you yelling (all caps) because you have your speakers cranked up?
    Top 10 Sound Systems in Cars Under $30,000 for 2002
    (Pathy did well in our survey)
    Steve
  • kmrqkmrq Member Posts: 50
    Busy at Edmunds.com too huh... hehehe!!!
  • brian60brian60 Member Posts: 76
    I would be very interested in retrofitting my PF with a QX4 remote glass hatch release as well.
    I use the glass hatch whenever possible to save wear and tear on the main hatch struts, which are usually $$$ to replace. Granted, the glass hatch struts will have to be replaced much sooner, but they look to be a lot less expensive than the main hatch struts.
  • alwaysfordsalwaysfords Member Posts: 210
    You really aren't saving that much wear and tear on the struts - they are in their most stressed (compressed) state when the door is closed. They don't go bad because you open and close the door, they go bad because over time the seals eventually give up.
  • couimetcouimet Member Posts: 130
    Well, it was an SE without AWD ...
    Good point! I was thinking about the physical assembly of the strut being under the most load when it is fully extended, supporting the weight of the door. You're right though, struts tend to fail when the seals blow as opposed to a crumpled structural member.
    In that case, I use the glass hatch so that I don't have to listen to the rear hatch squeak as often when the strike plates dry out and get dirty. Ha.
    I was going to provide you that alternate reason in my original message.
    here in Nissandom, so I guess this is a good time for me to interject some of my myriad of questions.
    I've got almost 1500 miles rolled up and I was suppose to get a coupon for a free oil change at 1,000 miles plus a survey of my buying experience from Nissan HQ. I wouldn't mind changing oil myself but after a quick peek under the hood and under the car I failed to see the oil filter. The manual wasn't very helpful. So how hard is it to change the oil?
    Here's a super dumb question. After a month I still haven't figured out how to switch sides on a tape? I'm pretty familiar with the pop the tape out and flip the wrist technique.
    I've been figuring out most of the HVAC controls. The ECON switch still baffles me. Whether in Auto or Manual mode if I ratchet the temp up, air gets hot.
    Also got my free Swiss Army watch for test driving the Pathfinder. Gave it to my wife as a consolation gift for not getting the Highlander. See!, good things happen to those who own Pathfinders!!!
    Steve
    Does the Pathfinder have a plate over the oil drain plug that has about 10 bolts on it? The QX4 has one and I was told that it would require a $10 surcharge where I normally get my oil changes done to remove that plate. It sounds like the dealerships $50 oil change might not be a bad deal after all especially with a loaner.
  • smithmdsmithmd Member Posts: 167
    Actually, my oil change place told me the same thing. I said, "That's a load of crap. I guess I'll have to go across the street from now on." He quickly changed his tune.
    To get at the oil filter you need to remove about 10 screws that are holding up a plastic guard that spans the gap between the radiator and the engine block. It is about 4' wide by 1.5' deep. Pretty hard to miss it. It takes about 2 minutes to get them out. The filter will be right in front of you after that.
