If you want a dual exhaust system for your truck, call some local muffler shops (NOT Midas, though) and see if they can set you up.
Last weekend I went deer hunting with two other people so we had 3 people, a couple bows and some clothing, not really a load and it was the same way, sitting low in the back and bottoming out on medium size bumps. I like driving the truck, especially with the manual trans. but I can't wait to get rid of it so that I can get a real truck. I hope the new full size pick up isn't this weak in the knees.
If I'd buy a Pathfinder I would install these shocks the solve the sagging done by my boat trailer tongue weight.
The bottoming out could be a problem for me. Almost every weekend during the summer I pack the kids (2), lots of luggage and a large cooler, I attach the boat (250 lbs tongue weight). Gee I'm worried that I will bottom out with such a load.
Opinions ?
Anyone here have airlift on a 2000-2001 or 2002 Pathfinder
I'd like to hear more about the improvement in ride and handling before committing that much money.
AW
Is it possible they have fixed this problem with 2002 or 2003 ?
And for those who bottom out, does it occur often or is it occasional.
Will I bottom out each time I will pull my boat ? Some people here say they bottom out with fishing rods !!!! and obviously some passengers....
Yep, Rancho's catalog doesn't specify a shock that fits the Pathfinder. However, coincidentally, the RS9116 is a near identical match to the OEM shocks. It turns out that the RS9010 are a good fit with a 2" lift. My testing (and many others on another discussion board) have shown that the RS9000 adjustable shocks (or the new RS9000X) are a good fit indeed.
I do not recommend the RS5000, because they are not adjustable, and the valving may not be ideally suited for the Pathfinder.
As for bottoming out, it happens only as frequently as you carry 3 passengers and luggage/cargo (or tow a heavy trailer) and drive over bumpy roads. Never happens during solo driving.
Best thing is to wait and find out when it's a problem, and see if you can live with it. It all depends on the load you're carrying and the road conditions (and of course vehicle speed).
I can only say that since installing the airsprings over 30000 miles ago, I've never bottomed out.
Here's the instruction, read them before you decide to buy.
http://www.koni-na.com/pdf/boltstrut.pdf
I bought the Konis but returned them when I found out how complicated the steps are and went with KYB GR-2 struts which are identical to stocks but a little stiffer. I can't comment on how they ride with stock springs because I have the 2.5" spring lift and they ride nice but definitely stiffer than stock.
For the rear, as xplorx4 said, Rancho RS9116 will fit fine and ride very nice.
I've got a 2002 LE and i've thought about putting the electric antennae from the QX4 onto my truck. Has anyone tried this? Is it easy to install? Expensive? Any input would be helpful. Thanx...
I agree that it shouldn't even be an issue, but it sounds like the 2002s have been fine, so it might be a problem that they fixed.
As well I'd like to have comments about the lastest version of this truck.
How's the leather in the 2003 LE ? Good quality ?? Slippery ??
Any problem with your Pahtfinder so far ?
Any good comments ?
Is MPG as badd as they say ?
It was a terrific ride !!!. I don't remember bottoming out at all even on very tough and bumpy roads.
Could they have put the QX4 suspension on the 2003 Pathfinder LE. Gee the two trucks are so similar.....
They may have merged most of both products specifications for this last year of production.
As a starting point, I'm considering replacing the rear shocks first, to get better ride control especially when fully loaded.
I don't have the tools to do the installation, so I'm relying on a shop to do the work so I'm cautious about asking a garage to perform a complicated installation.
If the Konis or the Ranchos are the direct fit (at least in the rear) and would provide improved ride control, I'm on board. The rear Konis cost $80 each at Tirerack. How does that compare to the cost of the Ranchos?
The OEM shocks need a bit more compression damping (which should reduce bottoming) and a lot more rebound damping. My PF has 25k miles and of course the dealer is absolutely no help on the shock issue.
AW
-Soak the bolts with WD-40 for a few hrs.
-Jack up the truck,
-put jackstands under the axle,
-move the tires,
-remove the bottom shock bolt (19mm),
-remove the top shock bolt (22mm),
-remove the shock,
-put in the correct metal sleeve for the new shock's bushing.
-Rancho come with a few washers, or you can pick them up at any local hardware store. I use 3 for top and 3 for bottom.
-Install new shocks,
-Install tires.
That's it. The shop shouldn't charge you more than 1 hr of labor.
Rancho doesn't officially make shocks that fit the Pathfinder. However, by coincidence, the RS9116 is a near perfect match.
Other alternatives would be to buy whatever Sears, etc. recommends as a "performance" shock for the Pathfinder. It will certainly not be as good as the Rancho (which is manually adjustable), but it could be better than OEM.
bottoming out complaint. They said there is a NEW
fix that they just got on their intranet.
Albeit the parts were back ordered for a month, I just had them installed on my 2002 LE. What they amount to is a LARGER & LONGER solid insert in the spring assembly...I still don't understand the enginering of it all but I had 4 guys ride with me after installation and even though we wnt over speed bumps, dips, etc. I could not make it bottom out
Make: NISSAN TRUCK
Model: PATHFINDER
Year: 2002
Service Bulletin Number: NTB02081
Bulletin Sequence Number: 633
Summary Description:
SUBJECT REGARDING REAR SUSPENSION BOTTOMS OUT. *JG
It says 2002 though, but my 2001 also bottoms out. Any 2001 owners trying to get this fixed at the dealership, please let everyone in the forum know how it goes. Thanks.
I'm calling my dealer later today to ask about both.
AW
It has only been only three days since they installed the new equipment on my 2002 le. I am what they call their "guinea pig" since I was their first. I cannot feel much difference so far, as far as stiffness goes, they said they thought it would ride a little higher too, but there again, I cannot detect too much difference. I noticed the problem mostly when going golfing with 4 guyes in the truck and 4 golf bags in the rear. But alas, I have not had the time to get a forsome together since the "fix. darn! darn!
what was the outcome of bringing your PF to the dealer last Friday. you posted a problem with humming noise at 35mph.
I have a 1998 BMW 323is that never bottomed its suspension despite riding much lower.
I'll wait after the fix is made to decide on rear shocks. Thanks for the instructions, but I don't have an impact wrench and my experience with replacing shocks in a Ford Fiesta during my college days makes me leary of trying it with hand tools alone.
I've had all the O2 sensors, the AT module and valve body replaced, all under warranty. Granted none of these issues left me stranded, but I'm still hoping the PF provides many years of trouble free service.
The dealer is also checking into the temp display TSB.
FYI, the NHTSA item numbers are:
SB633673 for the rear suspension
SB632155 for the temp display
AW
When the car was under warranty I had the AC Compressor replaced after only 33,000 miles. It made a horrible pinging noise. Now that I have 60,000 miles I have the same problem. You can hear the car coming from a half mile a way. Of course it is not under warranty now, and the dealer wants $750 to replace it. Has anyone else had this problem. I am afraid to replace it, thinking it will just have the same pinging noise problem a year later.
Similar to above, my fan is making an annoying whirling sound. It happens whether the AC or heat is on. Problem is I can't tell if it is actually the fan or something in the air ducts. Any suggestions so I don't have to pay the dealer $80 bucks in hour with the potential of still having the problem?
My Dealer has been useless as usual.
My Pathfinder SUCKS. I knew I should of bought a Toyota
nchelo - i don't know if you have any other dealers nearby, but maybe you should try another one and explain that this is a recurring problem for you. if not, try a call to nissan customer affairs ( the # might be 1-800-nissan-1), open a case file, explain it was already repaired under warranty and the problem came back. its worth a shot.
