Visitor Agreement.
- wood plastic trim: I KNOW I saw a website back in October of last year that sold this stuff for the Pathfinder; aftermarket but identical; just start searching Google or something and it will have to turn up . . .
Is there an aftermarket Navigation system available, perhaps portable that can be taken from car to car? It is one slick toy with the 7" screen and female audio voice!
www.crutchfield.com has the alpine units I believe (not portable but an aftermarket install)
I'll be picking up my boat pretty soon. Since I bought my new Pathfinder in late October I never pulled the boat with it.
I have to admit that I'm afraid that the Path will sag when I will attach my boat.
Boat + engine + trailer = 2500 pounds (+/-) but I have no idea how much weight is on the tongue (10% ???)
Anyone with sagging experience with a similar setup ? For example my 99 4Runner used to sag big time with the same setup. I looked more like a rocket than a truck ;-)
Anybody installed the Airlift product? Did it impact suspension and VDC performance ??
Thanks for the info
Many others here have cited the soft rear end while towing and even bottoming out, although I think that happens only when you have folks in the back seats.
There's a TSB on this that should stiffen the rear suspension and improve this...I haven't done that yet. And of course there's the air lifts that some others have added.
My personal experience is that the 350 lbs tongue weight does drop the rear a bit, but I've never bottomed out. I don't tow long distances, but I do go over some rough roads. I also never have more than 3 people in the PF while towing (1 in the rear). So...to me, I have no problem.
Given that, I don't really want the rear end to be any stiffer...but that's individual taste.
Hope this helps,
Tom
Have any of you changed tire size? Original being 255/70/16, would 265/65/16 work on the OEM rims?
http://www.c5-corvette.com/tirecalc.htm
They are wider...So I'd check room in wheelwell...
The Michelin LTX was original tire on my QX4...Really like them, but I think if I were to replace I'd go with the Cross Terrain SUV's like Smokey75...Write ups show even better..But LTX's are cheaper...My .02.....
http://dean.thayer.net/off-road/upgrades/airlift/
I believe the TSB that reduces bottoming out has more to do with modifying the bump stops than replacing the springs with stiffer ones.
At any rate, the airlift setup maintains level ride height and can preserve handling when loaded.
If you desire, you can replace the rear shocks with adjustable ones (Rancho RS9116X), which also help in preserving ride qality when loaded.
Only 1 regret so far is the lack of the LATCH securing points for car seats. I know that the 02' US models came with them and was wondering if anyone has tried or has heard of a LATCH retro fit kit for the Can versions.
Bryan
Jon
They technically aren't better as far as safety goes but it ensures that the seat is installed properly as it leaves less room for error and also is easier to install/move the seat from car to car.
Goose 1207, we also have the Britax Roundabout seat. It is wonderful. Britax is definitly head and shoulders above the rest when it comes to build quality and features. I definitly recommend them to someone looking for a seat for their child. I researched the subject for like 2 months before getting the Britax and haven't regretted it. Only drawback I can find it is the price <ouch>.
Bryan
Hopefully I found the right place, if not please point out the local information station
1. If doing yourself, be sure to remove the fill plug first. If you drain, and then can't get the fill plug out you have a problem. Also, this stuff is so objectionable, find a good system to pump/flow it in with minimal spillage. I quickly got tired of cleaning up the stuff that ran down my arm as I strained for 10 min. to force it uphill into the cases. There are nice "professional" pumps that attach to the bulk containers you can buy.
2. Type of oil. In the past I have always used "normal" oil. After my experiences with Mobil 1 in the engine (more than pays for itself in better mileage, and the engine is so much smoother/quieter), I will be using synthetic when my PF miles up to change time. Be sure whatever you use meets the owners manual specs.
When it comes to the pet divider I'll naturally consider the metal type not the plastic type, no matter how well a dog behaves.
Mobil 1 container has the long nose spout that you can pour directly into the fill hole without a separate pump. I found that jacking up the rear higher than the front and drop the spare made it much easier. Just fill it up until it is about to spill out.
Thank,
Felix
I put Cooper Discoverer tires on my Pathfinder, and I couldn't be happier with performance. I think the type was HT, which is a highway tread that runs smoothly and quietly. The first rotation is coming up this summer.
To my surprise, auto parts stores like Pep boys and Auto Barn list 4 colors for all of Nissan (?!?!?) and not one is my 2001 LE's silver (which, accoding to the tag on the firewall is KR4).
So I went to my local Nissan dealer, thinking "oh well, I'll spend a little more, but at least I'm guaranteed a match" and....I was told that Nissan does not sell spray paint. He suggested that I go to a body shop and have them match it.
Anybody have a source for matching spray paint? Would a body shop mix and sell me some of the paint? Any suggestions are appreciated.
Tom
So yeah, I'd try to get some at a body shop or similar, but a small amount may be too much hassle for them to fool with. And you'd need a sprayer.
Maybe you can swap them some KK's for a half-pint and get one of the paint booth guys at the shop to spray it for you after hours :-)
