Nissan Pathfinder
1138139141143144158
  • sivi1sivi1 Member Posts: 82
    as i said i do not want a 3rd seat. if you fold it down do you lose the at nice little compartment in the rear for tools ,extra hitch, etc. i want all my space for trailering, not passenger hauling. there are only 2 of us. if the 3rd takes up storage, i will probaly have to go back to 4runner
  • zaphodatlzaphodatl Member Posts: 9
    I'm starting to look for a good used vehicle. The Nissan Pathfinder LE (2001) is on my list. I want something a bit bigger than my 1996 Camry DX. In no particular order, I'm looking for reliability, cargo hauling, utility and the occasional light off-road duty (Cub Scout camping and the like). Most I've checked have 40-50K.
    Based on experience here at the PF board, would this be a good bet for me? And, any recommendations on 2WD vs. 4WD in the Pathfinder?
  • laundryguylaundryguy Member Posts: 89
    Always wondered why the light stayed on in my 1997 Pathfinder (82k miles) after I shifted out of 4WD after getting back on clean pavement after driving through heavily drifted areas when very cold. For the $300 bills mentioned above, though, I'll live with the light.
    Anybody end up replacing their front struts on a 1996-1998 Pathfinder? I saw lots of posts on shaking/vibration. I had vibration issues too - much later in truck life so I installed new struts at mechanics recommendation. Although very pricy (seems like $600 installed), put my vibration issue to bed at about 75k in miles. Ride is spectacular now - just like new. I tow alot, but hardly go off road and would count this as the only flaw I ran into in 6 years with the pathfinder. Exhaust was spent after 6 salty Wisconsin winters too - but that has happened in every vehicle I have ever known up here.
    Hint for new Pathfinder owners. If you live in the north - go out now and get stainless steel hex flange screws to hold the brush guard on with. If left alone, the poorly coated ones will rot away and snap off in the threaded holes, making the joints useless without a drill and tap. I was down to just (5) functional bolts and finally went out and got some M6 x 18 mm along with stainless steel fender washers.
    Great SUV otherwise - enjoy!!
  • jack1619jack1619 Member Posts: 6
    zaphodatl, I love my LE and reluctantly just (yesterday) traded it in for a new Quest. We have more kids on the way and needed the extra room. I had 4 wheel drive and it was great in the snow. When in 2 wheel it was tough to handle in snow, though.
    I just changed the oil/filer and rotated the tires.
    I miss my PF already. In my opinion it is a great vehicle.
    Jack1619:
    What were your maintenance costs like? Is it a vehicle that will hang tough, for, say, 10 years? Utility is important to me, but so is reliability. I've been a sedan driver most of my life, so an SUV would be a big change for me. Just wondered whether it was worth considering this vs. a sport wagon or smaller SUV.
  • pathstar1pathstar1 Member Posts: 1,015
    Mine has been trouble free so far, except for the two O2 sensors replaced under warrenty. That's the only time it's been to the dealer. I too do my own service (oil, filter, grease, coolant changes). Got just over 30,000 km on it now so not much mileage.
    From what I've seen here, O2 sensors and ignition coils are about the only common failures, and they appear to be rare. Tires will be expensive as they are big. Mine are still original and wearing well. Tire balancing can be an issue (Hunter 9000 may be necessary to do it properly), though I haven't had a shimmy issue on mine. It goes through fuel a bit faster than smaller vehicles, but it is very powerful and heavy (4300 lbs) so that shouldn't be a surprise. I'm getting better mileage than my friends RX-8, and that's funny. Highway in summer of 13-14 L/100 km. City in summer 15-17 L/100 km. I don't want to talk about winter mileage ;-).
    Got mine in June 2000, so that's 4 1/2 years so far. I expect better than 10 years without major problems.
    I have an older designed 1997 Pathfinder, but can share some thoughts if you are switching from a sedan to SUV or sport wagon:
    In 6 1/2 yrs I have had the following non-standard service warranty items:
    a) New front struts at about 75,000 miles - $750
    b) New exhaust from just behind catalytic converter to exit pipe: about $600 installed after 72,000 miles
    c) One reset of engine codes (wife forgot to put gas cap on - our fault)
    Absolutely nothing else in 82,000 miles. The exhaust rotting out is normal in 6 salty winters in central Wisconsin - it might last forever in warmer climates. Only the struts, which gave rough ride and shimmying prior to replacement, was an issue.
    To be honest, I bought it mainly to tow a 2700# boat and trailer where 4WD helps getting up steep ramps. Does great in snow as most will attest in 4WD. If you are just going to be running city/highway roads never towing, the sport wagons (Subaru/Lexus RX300) or a 4WD minivan are not bad options and give most of the functionality you get in an SUV, but with a more car like ride.
    4WD will require rotations of tires every 3500 miles vs 7500 miles in 2WD cars/vans/wagons. There is maintenance cost here. Also, tires will be about $100 a set more expensive on average than minivan/sedan tires because of size. Some limited additional maintenance for greasing/changing fluids of 4WD transfer case.
    A sport wagon would also offer better emergency handling - I once lifted a tire off the ground in my Pathfinder avoiding the rear end of a car that stopped for a pheasant in the road. Scary - but Pathfinder is the best handling SUV because of low center of gravity.
    I like the Pathy and think it should be good for 150k at least. I knew a few guys who had early 90 Pathfinders and were in the 250k - 300k mileage range. These things can go and go.......
  • cdnpinheadcdnpinhead Member Posts: 5,621
    make me even happier that I bought an '04 SE a couple of months ago. Other than the fuel mileage, couldn't be happier. Already had it on a pretty serious 4WD adventure & gathered a dent or two to the undercarriage & a bit of desert pinstriping.
    We keep vehicles 7 - 10 years & it sounds like this one'll do us proud. I drove a 240Z 226K miles in the 70's & early 80's, & it looks like I can do it again with the PF.
  • marsha7marsha7 Member Posts: 3,703
    photo/description of the next (2005?) Pathfinder in one of the car mags...seems it will be a little bigger (but obviously smaller than Armada, then what ISN'T smaller than Armada) and maybe a little nicer inside...anybody know more (not that I really KNOW anything, just what I read)...
  • bowke28bowke28 Member Posts: 2,185
    go to http://www.nissannews.com for info on the new pathie. it will also have 3 rows of seats and over 250 h.p.
  • glenski01glenski01 Member Posts: 44
    I have owned/leased 3 Pathfinders. Currently have a 2001 SE, the best yet. Performance is phenomenal, tow a trailer here in Colorado/Rocky Mtns. and it is great. No rattles, have 36K miles. NEVER has had a warranty issue. Most important to me, the handling is great, car like for an SUV. My lease is up next month, have checked out other SUV's and putting price and quality in mind nothing compares.
  • rx8riderx8ride Member Posts: 5
    Bought by 01 LE new (my second Pathy) and have loved it ever since. I have 30K miles and the only warranty work I've had done was just recently with an O2 sensor and a shock that went bad. Terrific engine, great build quality and it still looks great on the road.
    A little oops. I have 40,000 km on it, not 30,000. They kind of sneak up on you ;-).
    I found the site, and the description...thanks
  • viking03viking03 Member Posts: 21
    This weekend I brought my 03 SE 4WD in for the 7500 mile oil change/tire rotation. Some of you may be aware I've had some issues with the Pathfinder up to this point-but after the tire rotation the ride is very smooth and it seems to handle better than ever - go figure. The shimmy is gone! Now I know why some of you love the Pathfinder so much - it is really enjoyable to drive without the constant shudder. I had the tires balanced twice previously using the Hunter machine and that had only reduced the vibration approx 75% - still annoying on smooth roads. I fully expect that at the 15000 mile rotation the vibration will return, alas, but I will fully enjoy the next 7500 miles!
    To some of the gearheads on this board, does this change in vibration pattern indicate a pair of out of balance front tires, or a pair of out of ROUND tires?
    I shudder to think of the fight I would face trying to prove that I needed a new, full set of tires.
    To those of you considering the Pathfinder - don't let me scare you off. ALL makes/models of vehicles haves problems - the differences between makes, american/foreign, etc are so miniscule it is counterproductive to worry about it. You are either lucky or you are unlucky -it's that simple (caveat - if you follow maintenance schedule properly). Today I saw a Toyota Camry broken down on the side of the road with coolant smoke billowing out of the hood on the road up to Big Bear. So much for the bulletproof Toyota myth. Buy what you like and what feels good and fun to drive - don't worry about the "reliability" issue in regards to most makes of automobiles. It is NOT worth an ulcer over.
    AS far as perceptions about reliability go, I could go on to another tangent about the absurd prices payed for 3 to 7 year old Hondas and Toyotas - what are people thinking? My girlfriend's 99 Civic has 90000 miles and more squeaks, rattles, and groans than a clipper ship. I have owned 4 different american cars and never had major engine or transmission problems with any of them - all driven over 150000 miles. Those are the only types of expensive problems to fix that would justify paying the premium for an import.
    However, resale value is clearly better for some makes such as Honda/Toyota. Again - I don't feel this is justified, but it is what it is.
    You will like your Pathfinder - guaranteed. They are near bulletproof unless you're unlucky.
    The interiors/seats are extraordinary, the engine is quite strong, and it does have some capability offroad if needed. If you are only going to drive it on snowy roads however there may be better choices for you in an AWD type of vehicle.
  • sivisivi Member Posts: 20
    02 le 16000 miles,no shimmy even with 2 screws in 2 different tires, both patched. as a matter of fact, no troubles. less trouble than 2 4runners.
    Thanks for all your reliability reports on your 2001 Pathfinders. It's all been helpful.
    One more question: How about rear seat room? From time to time, I'll be hauling three kids - the oldest an 11-year-old girl. The others are smaller and are in booster seats. Will there be a space issue?
  • lbinhlbinh Member Posts: 190
    Rear seat room is good for kids. Entrance and exit from narrow door opening, a little tight legroom, and missing rear middle headrest is bit of drawback but the reclining rear bench seat with the folding arm rest is great. No need to worry about head room when you lean it back. Not many SUVs have recling rear seats.
    When loaded with rear cargo and passengers the 2001 Pathfinder bottoms out with factory coils and shocks. It was really bad for me. You would feel a thud when the shocks and coils gave out and collided with the body. Even worse when towing. There is a TSB (manufacturer Technical Service Bulletin, unannounced to public) for the known issue. Tradeoff for smoother/softer ride. The fix from the dealer is to install larger/longer rubber bumb stops inside the rear coil springs. Solved the issue for my 2001 LE.
    Check out www.alldata.com for brief description of all the TSBs. If you pay, you will get indepth detail on it. I did not have too.
  • duncdunc Member Posts: 2
    I bought this suv based on its reliability and performance reviews. The only downfall is the gas mileage. I do about 700-800 miles per week between work and trips to the ski mtn. I love the vehicle, but $80-100 a week in gas is ridiculous.
    My 2002 PF cd changer is horrible. I have issues with different tracks skipping. I thought the cds might be scratched but once I removed them from one track and put them in another, they played fine. I brought it to a dealer and he tried to tell me that the cds had scratches. I informed him that they worked in other tracks and then they told me that they had a GM tech look at it because the nissan techs were out sick. He would notify me if he heard other complaints and then maybe they would replace it.
  • xplorx4xplorx4 Member Posts: 621
    Many people don't take lower fuel economy into account when making an SUV purchase, and express similar sentiments as you after their fuel costs double. The EPA rating is the largest thing printed on the window sticker. You do recall it reading 15/19, right?
    I don't mean to be callous, but welcome to the world of 4x4 SUV ownership. Have you considered buying a more fuel-efficient car for commuting to work?
    those who comment on the fuel mileage (or lack thereof) with the Pathfinder may also be taking into account the 91 octane fuel that's involved.
    Not too many other trucks burn premium.
    use premium??? the new ones dont require it.
    is recommended for Pathfinders with the 3.5L V6 (which means 2001 and up in N. America)
    read it again. it is "recommended for increased performance", not "required". regular is required, and does just fine. i wouldnt waste my money on the fancy stuff.
  • pcrowlespcrowles Member Posts: 11
    91-93 isn't required but you get MUCH better mileage with premium fuel instead of regular...the total expense is equal when you figure it out, but why put the engine in any type of jeopardy?
  • jiaminjiamin Member Posts: 556
    on my 94 Altima, 96 Maxima, 00 RX300 and 02 QX4 are all the same no matter I use 89 or 91. I compared so many times...
  • alwaysfords2alwaysfords2 Member Posts: 339
    In most drivers cases the difference in cost for premium versus regular over the course of a year is a couple of hundred dollars. I also believe ti says for "optimum performance" not increased performance. Optimum and increased are two entirely different things.
    the current generation is rated for 240 HP with regular unleaded.
    And your point is...?
    The hp rating alone really doesn't tell you anything. You could be rated at 240hp with a less than optimal condition as well as an optimal condition. An optimal 240hp rating might come at 3000 rpm while a less than optimal 240hp might come at 3500. The same could be true of any measure; mileage, torque, emissions, etc. The 3.5 has knock sensors that retard ignition. The optimal ignition happens with higher octane fuel. When the engine starts metering itself, something has to give. Not from personal experience but from others on the board who have worked over the fuel comparison long ago, usually it is the mileage that suffers. That is why the previous poster told you that the offset for the increase in fuel cost was an increase in mileage. This may not be the case for your normal driving conditions, but the majority of people who have reported it to be that way. If you want to run your 30k car in less than recommended conditions for the sake of $300 a year, have at it.
    can be debated ad infinitum. Fact is, many of us have found the increase in mileage using premium more than offsets the increased cost per gal. That is, the cost per mile is lower if you use premium. The engine also runs better. I found the same when I switched to Mobil 1 oil. It's much more expensive than "normal" oil, but again, I got an increase in mileage, which when calculated over the normal oil change interval (6000 km), actually paid me back 2 times the difference in oil cost.
    Yes, I found it amazing as well. Kind of like where it says in the owners manual you will save fuel cost by using A/C instead of opening the windows (on the highway). I also found this was correct (didn't believe it when I read it).
    Bob Chapman of Shell Oil claims the octane rating has no direct effect on gasoline mileage though it may affect overall performance of the vehicle. Efficient driving and good maintenance do improve mileage.
    We might tell the diff with some professional measuring devices between regular and premium gas. However I myself can't never tell. Still remember some experts said that gas grade is like a person's shoe, correct size is the best, not the bigger the better...
    RX300's engine has higher compression ratio than Path/QX4. RX's recommended gas is 89 therefore I believe QX4 using 89 is of no problem at all. With 89 I never have pinging problem. Idle smoothness, acceleration, MPG (calculated 89 and 91 for so many times and got bored and quit), whatsoever, I simply can't tell the diff. The only diff as someone else said is the money in our pocket...
    Personally I don't want to pay more just for some peace of mind
  • iontrapiontrap Member Posts: 139
    Does anyone here have a higher mileage lease, ie 25k? What kind of deal did you get? I'm feeling a temptation to run down to the dealer today but I'd like to have some input before I go.
  • lovejettalovejetta Member Posts: 4
    I don't really care about the gas mileage...I just love my Pathfinder and that is the only thing that matters to me. I bought it for the reliability and good looks. Reliability is important to me since I need my Pathfinder for my job...and I'm going to put good fuel in it to keep it purring...
  • jdd2004jdd2004 Member Posts: 1
    I'm considering purchasing a Pathfinder. Anyone familiar with reputable dealerships/salespeople in the Dallas/Fort Worth metroplex? Any specific ones to stay away from? Thanks.
  • floeva09floeva09 Member Posts: 20
    Does anyone have any information on the 2005 Pathfinder? Information like pricing, release date, and features. In the market for a new SUV. When I buy I plan to own for many years. I am taking my time and will research through the summer. Thanks in advance for the information.
    no pricing, release date somewhere between june and august, and features are at www.nissannews.com.
  • rctltrctlt Member Posts: 2
    I have a 94 pathfinder that is having speedo and tach problems, both the speedo and tach malfunction and read all over the place, sometimes they both peg to the end, sometimes they both read next to nothing, I have had several mechanics check this out with no luck at finding what is wrong, has anybody had similar problems with Nissan products, if so can you tell me if you were able to get it fixed and what caused the problem?
    the 2005 Pathfinder will be based on a larger platform (Armada) than has been the case in the past.
    Anything and everything that you've heard about the Pathfinder since it came out (in '86?) is irrelevant. Start following the Armada to see what to expect. Since it's a Nissan, the reliability is likely to be good to excellent, but the maturity isn't there in terms of little things.
    This is one of the main reasons I got a PF when I did -- have no use for the big one.
    ...will reportedly be similar in size, design, etc to the "Dunehawk" concept vehicle shown some months ago, with a possible 3rd row of seats.
    If you know what to do when buying the car then pretty much all dealers are the same as far as sales. Whether they are nice or not, be hard headed no matter what get what you want at the price you want. Other than location, service is the next indictor of where to go. I have personal experience with Don Davis Nissan Service in Arlington and it is a thumbs up. They follow up with customers and, for me, they state the honest truth on your car and don't push you for things you don't need. I question a lot and they are patient and respond professionally. Of course, things could change depending on the people. Overall, good place. Clean and professional.
    Let me know what your experiences are in sales if you go.
    2001 LE w/41K
    A preview and some details are available on the Official Nissan Website. 3.5 will be upped to 4.0 liters (read that somewhere, more power). I am assuming to slightly beat the 4runners specs. Independent rear suspension (am jealous), 3rd row seats, center seat head rests, more storage spaces....many other nice upgrades. Nicer looking than the similar looking Armada.
    www.nissanusa.com >> Future Vehicles
  • 03pathfinderle03pathfinderle Member Posts: 9
    According to our Pathfinder's owner's manual, the use of synthetic oil is NOT recommended. I was wondering if anyone knows why and also how many of you are using synthetic anyway and for how long? I'd like to switch our Pathy to synthetic (I prefer Amsoil) in the future (probably after the warranty is over), but I'm not sure it's a good idea because of what the manual says. I can't understand why it would be not recommended.
    Interesting; that's twice in recent days that someone has said a manufacturer specifically doesn't recommend synthetic oil in the owner's manual (the other model reportedly is a Mazda MPV).
    Maybe there's something more over in Synthetic motor oil.
    (Edit - here's one re an Infiniti: ryoken "Synthetic motor oil" Apr 10, 2003 10:44am)
  • smokey75smokey75 Member Posts: 434
    I have a 2001 PF LE and the owner's manual does not recommend against synthetic oil. Weird considering it's the same engine as the 2003. Anyway, I've used Mobil 1 with no problems.
  • sydney4163sydney4163 Member Posts: 18
    Just purchased my 2001 Pathfinder LE. Loaded with every option except nav. Love everything about it. We looked at everything out there and kept coming back to the Pathy. Looks, reliabilty, comforts, options, etc. Nothing compares. Thanks to all for your posts. I had been reading for a while to see what the likes and dislikes were. Looking forward to many miles and smiles!
    Do you mind telling us what you paid for the LE? What was the mileage? I have the same Pathfinder in silver with everything but the Nav as well. Just trying to get a market price on it. I'm not looking to sell...just interested. I love this truck.
    My Pathfinder is also silver with black leather interior. I paid $21K for the truck with 38K miles. I felt this was a pretty fair price considering the options it had, including the video system. I did a lot of research here on Edmunds and other sites, and this seemed pretty comparable as to what others were paying for similar vehicles.
    What's done is done, and can't be changed. However, I woudl like to hear from others. Was the price paid fair, or did I pay to much.
