Nissan Pathfinder
11314161819158
  • tonychrystonychrys Member Posts: 1,310
    I believe that the NAv on the PF/QX4 is CD based as opposed to DVD (like the Lexus). If you are going to travel any significant distances, you'll be swapping CDs.
  • johnskevjohnskev Member Posts: 98
    brian60:
    i'm very interested in the internal bike rack you constructed. i think the $150 dealer cost is unreal and i've thought about making my own, but since you've done it already, i'll just mooch off your knowledge. what sort of setup do you have?
    johnskev
  • phil47phil47 Member Posts: 394
    I've been trying for a couple weeks now. They're bloody tough to find. I'll let you know if I'm successful.
  • brian60brian60 Member Posts: 76
    hey john,
    i don't have any pics yet, but i'll give you the verbal description right now. I found it help to put the bikes in the back first to get all of the measurements right.
    Materials:
    (2) Yakima fork clamps ($20/clamp @ Supergo)
    (1) 2x4
    (4) bolts (10mm, I think, check clamp packaging)
    Total cost = $43
    Directions:
    Cut 2x4 to proper length
    drill bolt holes
    bolt clamps to 2x4
    install rack, install bikes on rack
    check clearances/interference
    repeat as necessary
    Comments:
    I found it necessary to angle the clamps with respect to the 2x4 because the handlebars would intefere with one another when mounted - you might not have this problem if transporting bikes on vastly different sizes. I use bungee cords connected to the floor tie downs in the cargo area across the ends of the 2x4 in order to secure it (the rack and bungee basically form a wide "H"). I thought I was gonna have to rig up a better way to secure everything, but so far, this system works great - of course, there are paved roads up to all the trailheads I frequent.
    Lemme know if you have any other questions
  • ssbfssbf Member Posts: 15
    Yes, the old Pathy used to have an automatic antenna. I have never had a car with a fixed mast antenna which is why I am so cautious.
    The Bad news is, the dealer told me (after I purchased the vehicle) that the antenna will be automatic again in the next year or so. Too many complain.
    The LE is the top model for the Pathfinder and yet it has a fixed antenna and no rear deflector.
  • danogdanog Member Posts: 318
    I just picked up the PAthy 01 LE and the compressor and dryer were replaced. It runs smooth without ANY noise just like it should. Nothing doing on the tranny slipping so I'll be watching it close.
    Xplorer2, response to post #705
    not exactly sure it your noise is the same but it is close. It sounds like a metallic rattleling that will stop when you turn off the A/C. Best way to tell is have someone inside and you stand in near the front. Have them turn off the Climate control altogether and then back on. If yours is making any noise you will be able to tell a difference.
    Aspenwhite, response to post #721
    did you say your noise was tanny related or was it the A/C? At least you got a new Pathy!
  • philipc1philipc1 Member Posts: 10
    DOES ANYONE HAVE ANY GOOD INFO. ON A HITCH MOUNTED BIKE RACK FOR 2 BIKES? DOES YAKIMA MAKE ONE? I WOULD LIKE TO PURCHASE ONE WITH A BAR THAT MOUNTS TO THE HITCH RECEIVER. ANY HELP WOULD BE APPRECIATED......
    THANKS.
  • sdbarbsdbarb Member Posts: 1
    I currently have the NAV system in my PF. I bought it because I am an outside sales rep with no sense of direction. It works great for me but would be a problem if I wanted to go throughout the U.S because I would have to buy other CD's. However, it does a great job covering the Southern California counties that I drive. It seems to be very accurate as far as I can tell.
  • gottriagottria Member Posts: 13
    Since there are a couple of topice about roof racks I thought I would ask if anybody has put a basket on the stock 01 PF roof rack. I like the Yakima Loadwarrior because it will still allow you to put on the ski or bike mounts. The BVG Adventurerak looks nice due to the fact it is slightly thinner there for it dosen't make your PF look top heavy. The Yakima is about $40 more and looks beefy.
    Goto http://www.sportsrack.com and do a search for BVG and you will find the rack I'm talking about. They also have the Yakima Loadwarrior there also.
    I will be mainly using it for summertime when I take the family camping for a little more storage.
    Let me know what you guys think.
  • pbk77pbk77 Member Posts: 23
    I just bought my Pathfinder last week. I got a couple questions if someone can help me out.
    1) I was messing around with the 4-wheel drive, and grinned some gears...is this something I should have a mechanic check? I feel like I messed up the 4 wheel drive system.
    2) Anyone else find it difficult to make sharp turns on a Pathfinder? When I tried to get out of a tight spot, it seemed really hard to move the vehicle...
  • benthosbenthos Member Posts: 1
    Can anyone recommend a good Nissan dealership in the Los Angeles/Southern California region? I'm going to purchase a PF in the next several months and am hoping to find a dealership with a solid reputation in sales and service.
  • sanandtonsanandton Member Posts: 342
    I suspect you have the 4x4, not the AWD version of PF. Don't worry about grinding the gearing after one attempt. The older stick control takes some practice to master changing 2wd to 4wd. I have ground the gears on several occasions (briefly). Haven't had any probs thus far.
    I do notice the PF seems to bind or push against the front wheels when making turns that require maximum steer to right or left. That is the only time I have noticed it.
  • lspanglerlspangler Member Posts: 102
    I have a bike rack called backpacker. It is by far the best way of transporting a bike when your not pedaling it. It mounts in the hitch with a bolt through the pin hole. The bikes mount without thier front wheels to fork clamps and velcro straps hold the rear tire in place. Nothing touches the frame and the bikes are rock solid, no swinging into your nice vehicle. The rack I have holds 2 bikes but you can add a second rack to the first one to make it 4 bikes. The rack is so solid that I can jump up and down on it. We use it as the dish washing station when camping as the 2 channels make a great table. I've never been a fan of bike racks that strap to the car or that hang a bike by it's frame. I've used this rack quite a bit on my pickup but haven't had a chance yet on the PF.
    Sorry, I just realized my above post is deceiving in it's description. The bikes mount by removing thier front wheel and the fork mounts to a skewer on the bike rack, you must store the tires in the vehicle. I hope this paints a better picture
  • li_sailorli_sailor Member Posts: 1,081
    lspangler - that sounds great...I have no intention of marring my new finish like my last car. Can you give us the manufacturer and/or where you got it?
    When switching to 4Hi, it should rarely if ever grind and it is usually a very smooth engage as you are not engaging a different gear ratio (4Lo is a different matter). Are you sure you are only pulling straight back with light pressure (4Hi) and NOT pushing down and back all the way (4Lo)? If you are accidentally engaging 4Lo, that is trickier and requires a different approach (truck stopped, in neutral, no hestating when pushing down and pulling back completely, etc.).
    In addition to what sanandton has said, having trouble turning the truck from a tight spot could also be an indication your truck is still in 4wd (part-time system). It would be VERY difficult to turn during low speed tight turns. The truck may actually hop in order to relieve the drivetrain stress. If you find this is happening, you probably have 4wd engaged and this will do alot of damage to the drivetrain on dry pavement.
    Not to scare you, but check it out....
  • pathstarpathstar Member Posts: 201
    Indeed, in Canada we have the retractible antenna (as well as the embedded antenna). Mine is the LE with the Bose system. The two antennas act to attempt to defeat "multipathing" (diversity antenna system as mentioned). The idea is that they are separated by a distance great enough to defeat the "fading" you get when you move amoung large buildings (or mountains) listening to FM. Seems to work fairly well.
    The Navigation system is not available in Canada, at least not last summer when I bought mine (many of the options you can order separatly in the US are grouped in Canada, presumably due to the much smaller market). I would recommend passing on it anyway. I use the Garmin GPS III+. Great little unit. You stick it on the dash with double-sided Velcro tape. You can plug it into the cig. lighter for power. It has very useful maps built in, and you can get much more detailed ones from Garmin for around $50 per set. Check out their web site (www.garmin.com). The advantage with this unit is you can use it hand-held for hiking, in other vehilces, etc. If you really want a nice color map, check out their "Street Pilot and Color Street Pilot" unit. Not as useful hiking but a nice unit. All these units are much less expensive than the Nissan system. One nice feature of these units is they can display speed, and it's accurate to 0.1 knot!
  • rsilbs2rsilbs2 Member Posts: 2
    Will need to lease another SUV next year and will be hard pressed to get another PF.
    Reasons: lots of petty but VERY annoying engineering choices made by the folks at Nissan. To wit:
    (1) Not being able to dupe a key except for $90+
    (2) Using key for rear glass locks all doors
    (3) No way to fix inaccurate external temp reading on compass. It's always higher.
    (4) Internal lights inactivated after a few minutes with doors left open. Pain in neck when loading stuff!
    (5) Auto heating system.. real pain. Would really prefer manual system.
    (6) Cannot adjust power seats easily without opening driver door.
    (7) Cannot flip gasoline cover open without opening driver door.
    (8) Large space between back of rear seats and cargo cover... valuables can be seen even when cover is in place.
    (9) Unlike previous Jeep, no lighter outlet is live w/o ignition on... cannot recharge celphone like I used to in Jeep.
    (10) Much touted audio system in PF just so-so. My wife's $129 Best Buy unit in her car kills this one!
    (11) Of course...lack of power.
    (12) Horrible behavior in 4WD if not wet or slippery. (Sometimes one forgets!) And limiting 4WD to under 50mph.
    (13) Understeer (or is it oversteer?)...back wheels often hit curb on right turn.
    (14) Lack of real lumbar support in driver seat.
    (15) Seat too low for long haul comfort (I'm 6'2")
    This list could go on...but I'd like to know whether the new PFs address any of this, if anybody has any remedies, and finally, what is out there for me to lease that will be designed by engineers who actual drive these things? Am thinking about: Acura MDX, Audi AllRoad Quattro, NEW upcoming (2002) Explorer/Mountaineer, Lexus SUV?
    THANKS ONE AND ALL! (Wouldn't mind e-mail: rsilb@home.com)
    security system still there in 2001=expensive keys
    my 2001 LE does this too, but only if you turn it one way - it's fine the other way (I just can never remember which way to turn it)
    move/shield the sensor - mine works fine (if moving)
    this can be defeated (I think rear hatch defeats it too)
    order SE model with normal system
    I haven't had this problem - perhaps there is more room in 2001?
    I haven't had this problem, though it is a tight and long reach.
    recline rear seats a bit
    no help here without some wiring - would not be difficult
    I find the Bose system to be very good
    No longer a problem!!
    This is not a problem in 2001(I have the Auto system)
    Haven't had this happen, but in any long-wheelbase vehicle, the rear wheels track a smaller radius in a turn
    My leather seats have good adjustable lumbar support
    My leather power seats are height adjustable (I'm 6' 0") and very comfortable.
    Most Japanese vehicles switch the cig. lighters with acc. power (on in acc. or ignition position)
    All your alternatives are substantially more expensive. I think if you look at a 2001 SE (to get away from automatic climate control-which actually works fairly well) you will find most of your concerns have been addressed, except as I noted.
    You probably can't go wrong with PF, Acuta, or Lexus. The Audi is very interesting. I wouldn't buy a Ford, but that's just me ;-).
    as I owned a 99.5 LE for a year before trading in for a 2001 LE AWD.
    (1) still the same, but this is also the same for most chipped keys (like by 2001 Odyssey EX)
    (2) still the same, the logic has its advantages and disadvantages, I'm on the fence
    (3) seems a bit more accurate (they might use a better logic to control when it records a higher temp), however the few degrees difference generally doesn't make a difference to me.
    (4) I didn't know that. Couldn't you set the lights to "always on" while loading?
    (5) I love the auto climate control system. I've rarely touched it (unlike my Odyssey).
    (6) I don't find it to be that difficult.
    (7) still the same, not an issue for me as I pump my own gas.
    (8) gap only around 6". You can eliminate it by reclining the back seats if it's an issue.
    (9) still the same. Your dealer can rewire (for a fee) to be always live if you want.
    (10) I love this audio system and I'm usually the one swapping out stock systems within a month.
    (11) fixed in 2001...really fixed....
    (12) fixed in 2001 with AWD
    (13) I don't recall that problem..
    (14) fixed in 2001 with a lumbar support (helped me)
    (15) seat is very adjustable and comfortable for me on long hauls (I'm 6'1"). Too low shouldn't be an issue anymore (sometimes I feel it doesn't adjust low enough...)
    Hope this helps.
    I'll take a crack at this, but you might not like some of my answers:
    I hate to tell you this, but this will happen with any modern car that uses a "Vehicle immobilizer" system. Yea, it'a pain, but it makes it harder to steal your car. Other brands charge just as much to dupe a key/remote.
    I've never heard of this (I have a '97). You might be able to "unprogram" this feature. I can program the lock action on on my '99 Grand Am.
    No ideas on this.
    Again, there must be a way to program this. Did you look through the manual? Ask the dealer?
    I have auto-climate control in my SE. If I don't like it I set it on manual. I don't get this complaint.
    Must be your hand/arm size. No suggestions on this.
    Again, knowing where the latch is for this, it must be your hand/arm size. I'm 5'11" and have no problem.
    Agreed. Actually one of the best covers I saw was a on Blazer/Jimmy, it pulled from the *side* across. The downide... it was on a Blazer/Jimmy. Pieces of crap.
    I guess that's a pain, I'm no help here.
    Is it the Bose? Our Bose sounds great in our PF!
    Agreed 100%. The 2001 COMPLETELY solves that problem. Drive one.
    That's the way part-time 4WDs operate! You can't take them on dry pavement. Didn't you know this? The 2001 auto-4WD solves this problem.
    That sounds like the way you drive... I've never heard of anyone having this problem due to a poorly designed PF (or any other car). Also, if you have the thing locked in 4WD while turning, this will happen. But again, you are operating the vehicle improperly.
    I'll agree on this, it could be better.
    Again, you could be right on this in your case. Our seats adjust pretty high and are comfy on long trips.
    I wouldn't touch Ford or GM with a ten-foot pole (and I own a '99 GM car). I'm tired of cheapish materials and parts, and shoddy union crafted work. To each his own.
    TC
    Thanks for the tips. Will rethink next lease and at least testdrive the new PF; sounds like some concerns are answered. AND I will be able to check my specific gripes.
    On the plus side is my local dealer (Sloane of Ardmore, PA.) They offer great deals, no BS (at least from my salesman), and terrific service. I would hate to lose them as a dealer.
  • xplorx4xplorx4 Member Posts: 621
    After owning a couple of different receiver-hitch racks, I found that the most convenient rack made is one that does not require any bicycle disassembly. I have a rack like the one found at:
    http://www.bicycleracks.com/stIndex.html
    It fits well into the hitch receiver on my Pathfinder, and carries two bikes just fine, without requiring you to store the tires inside the vehicle. You can choose to secure the rack with a standard hitch-pin, or use their hitch bolt, which eliminates any wobbling or play in the receiver.
    When not in use, the rack is easily stowed in the upright position. Access to the tailgate is accomplished by lowering the rack again.
    I chose this type of rack because it's often a pain to remove the front tire of my bike and put it inside the truck, especially if the tire is muddy!
    Hope this helps.
  • stevinwshingtnstevinwshingtn Member Posts: 23
    I think Rsilbs brings up a few good points. If some one knows how to re-program the rear door latch so it doesn't lock the other doors when you open it I would like to know how. Same with the dome lights. If the doors are still open the dome light should stay on cause I'm not done in there yet!! I sort of agree with his assesment of the seat hight too. I drove a pickup for a long time with a higher bench seat and got used to a higher seat. I am getting used to the lower seat position in the pathfinder though.
    I had to get used to the logic on the climate control system and I do manually control it sometimes...... but I wouldn't give it back. I might like to make a few changes to the logic. Like, you control the temperature and I'll control which vents I use.
    By the way tonychrys, how did you get the automatic climate control system in an SE???? I didn't think it came that way. That was one of the reasons I got an LE instead of the SE which has the nicer exterior looks.
    You really owe it to yourself to drive a 2001 PF. And definitely drive the LE if you can afford it. It's a great, comfortable vehicle. THe leather power seats are very supportive. And as you know, PFs are very reliable.
    Good Luck,
    TC
    Our '97 PF SE will always have good memorys. Now you get the story:
    My wife was pregnant with our son in '97, my wife was due in August. Both of us (by coincidence) were driving Nissan Pulsars, which if you remember were great little sports cars with T-Tops. You can't take a new born home in one of these things safely. So we had to replace one car and get something that I felt was safe for my new family.
    Having owned 4 previous Nissans, I naturally looked at the PF. It was in July and a high-volume dealer on Long Island was literally over flowing with PFs. They had so many that they had to park them in other business's lots. I did my research and went down to lease a SE, which was in our price range.
    They had all kinds of crazy combos and options, one was a Sahara Beige, but with some LE options like Bose, moonroof and auto-climate control. I really didn't think we needed that stuff, but was able to talk him down to about 300 over invoice.
    I'm so glad we got it. My son is now 3 1/2 and has really enjoyed riding in the SUV. With the child-seat in the back and the height of PF, he is able to "see" the road and everything going on. He always enjoyed going for a ride as a baby. And with the moonroof, we play "spaceship" at night pretending we are opening the doors on the shuttle. Many trips to Home Depot with the little man on weekends.
    Yup, my '97 SE is what I brought my baby home in from the hospital . Sorry to throw all this sentimental stuff in... you just got me thinking.
    TC
    Good Luck,
    TC
    I think you can do what you were asking for with the auto climate control system (ie. auto temp control with manual overide of the vent selection). You use the "mode" button on the system to select your vent configuration. It only gives up control of that function while continuing to control temperature (through air temp and fan speed).
    Pathstar/Tonychrys: Although we wrote our responses almost simultaneously, I was blown away by how similar our thoughts were on these issues. I guess that's some sort of validation!
  • calsigcalsig Member Posts: 4
    I originally intended to install my existing yakima rack system on my 01 PF LE, but in the end decided that I didn't want to add that much more height to the vehicle or worsen the already bad gas mileage by stowing my bikes up on top. So I started looking at hitch mounted bike racks at the local Sportsrack.
    After looking at the different brands(yakima, thule, BVG etc.), I decided on the BVG carriers because of the better build quality and the locking top plates. The Evolution is a tilt-down model that costs around $189.95 and the Revolution is a swing-away model that runs $289.95 at Sportsrack. I preferred the Revolution because I could open the rear hatch without unlocking and removing the bikes from the rack, but I wasn't prepared to pay that much for it.
    I eventually found them being sold online at carparts.com. Though carparts.com lists the manufacturer as Steelhorse, they are the identical racks as found at the Sportsrack and also manufactured by BVG. (Steelhorse purchased BVG) All labels on the packaging and the rack say BVG. Using the 33% off your entire order coupon at carparts.com brought the Evolution price down to about $80 and the Revoultion down to $160. In the end, I purchased the Revolution (comes with locking hitch pin), the two additional bike attachment and the anti-wobble stick. Total price with tax (carparts.com is in CA) and shipping was around $205. Not too bad considering I can now carry 4 bikes, for less than the cost of two more yakima anklebiters.
    I'm not sure if the carparts.com coupon is still good, but try it. The coupon code is 1963005. They list other Steelhorse racks for less, but the ones that are identical to the ones the Sportsrack sells are the ones with item numbers beginning with 9000 (i.e 9000xxxx). They also sell a ski/snowboard attackment, but I prefer the yakima big powderhound on the roof.
    Hope this helps...
  • admin_rufadmin_ruf Member Posts: 2
    One gripe I have is that the passenger seat does not have as much flexibility as the driver's seat. My Explorer had that feature.
    One thing that came to mind is to get the driver's seat from a right-hand drive version of the 2001 PF. Don't need the memory feature for the passenger, just the adjustments so I think all that it needs is 12V power to it. Do you think this will work? If so, where can I get them?
    tonychrys,
    Great story. What a sensitive guy you are. I think you should save that car for the young fella. It'll still be a great ride in 12 1/2 years.
    Phil47,
    I have played with the mode switch as you suggested. I guess it does work that way doesn't it.
    It's trying to trick me because when I use the mode switch to change vents the displays changes from "econ" to "manual". But it must still be controling temperature because after you do that you can still make the fan speed go up by cranking up the temperature.
    Maybe what I want is for the vent not to change back to the floor when I switch back to "econ" or "Auto".
    Thanks for the help! You guys helped me out and eased some of my concerns. I got another question for all of you.
    On a cold start (I'm from Chicago), has anyone smelled gasoline? I just noticed it a couple days ago and today. It seems to go away after I drive the car for a little bit. I was wondering if any one else had this problem. Is this normal?
  • mdq_ntvmdq_ntv Member Posts: 11
    pbk77,
    I noticed the same smell a couple of times and am still wondering like yourself. In my case it went away before I started driving. I haven't noticed it in the last 3/4 weeks. Type/brand of gas maybe? BTW, I saw a 'crimson red' SE this morning. Personally I don't like red SUVs but I have to admit that the red 01 PF looks great! Rgrds.
  • litespeedobedlitespeedobed Member Posts: 5
    Has anyone else had a problem with their pathfinder being really "slippery" in the rain? On the last to mornings we have had rain and my pathfinder seems to let the rear end slip around REALLY easily. Yes I am driving at responsible speeds! Any suggestions?
    Lynda
    Lynda-
    Which model and year of PF?
    WHat tires?
    Tc
    it is a 99 EX 2WD PF and has the Bridgestone (dueller???) tires. It has been REALLY frightening the last couple of mornings. There didn't seem to be a lot of choices in tires for the size that the factory recommends. Any suggestions?
    I think the spell-checker mangled your messge, but I'm assuming that you have a XE? Your tire size should be 235/70R15?
    If so, two suggestions.
    Michelin LTX - great all around tire for SUVs.
    If live in an area that sees little or no snow then: Goodyear EAGLE GT+4. This tire has good wet handling and dry pavement performance.
    Hope this helps,
    TC
    yep the spell check got me! ERRRR! I will check out the good year tires and hopefully that will help. I love my PF but if I am going to be scared to drive it then I just don't need it!
  • katstuff1katstuff1 Member Posts: 3
    Hi all,
    Been swamped since the Holidays but am back catching up to all the postings.
    My CA LE has been great for driving in the Berkshires of MA - we've had days of 14" snowfalls this Jan. but with my PF, driving has still been delightful despite icy and very snowy mountain roads.
    We got the Barrecrafters Horizontal Aerro-B6 ski/snow board rack for 4/6 prs of skis from www.rackwarehouse.com or (800) 272-5362. Has a universal mount that works perfectly with the flat bars of the CA PF and would work fine with the US round bars as well. $107 includes shipping. Rack attaches with an included allen wrench but doesn't lock onto the bars as others do. As the very helpful guy on the phone asked, how many thieves carry around allen wrench sets? Ski holder itself does lock skis in.
    A real novice comment/question I have, being new to 4wd and having the AWD LE, many specific instructions are included for putting into 4wd, none for taking it out. Drove for about 30 min. on a busy snowy road going about 35mph with car in 4lo. Hod thought it was back into 4hi as I'd turned the AWD knob from lo to high and the light on dash indicated the change. Didn't know that it wouldn't really change back again unless in neutral before changing back. Duh, now I know.
    Have I done any damage?
    Also, is consensus to change the oil after a few thousand miles on the new PF?
    Thanks again for all the helpful info!
  • bgritzbgritz Member Posts: 139
    I've got the Bridgestones on our SE & I also have noticed that they have not felt as sticky as some of the other tires I've had in snow. I basicly blame it on any of 3 things.
    1:poor tread/compound design. (??????)
    2:More HP than previous rides. (had 190, now have 250, BIG difference)
    3:LSD- This means that if the rear slips, both tires tend to slip, rather than just one; causing the rear end to get away from me more quickly.
  • nismofreaknismofreak Member Posts: 120
    I have to take exception with your third point in your previous post. If anything, because of the LSD, the rear would be more planted. Also, just because of the available power (of which less than 25% is used when cruising on the highway), it would not attribute to the "slickness" of the Bridgestone Duellers.
    >IF< people are lead footed when driving, or accelerating aggressively during a lane change, then the rear (regardless to differential type) would become "less sticky".
    I do agree with all that the Duellers are not the best tyres for the wet and ice. It did indeed freak me out when I first drove my '01 Pathy in the wet and then the snow (First time driving a truck in those conditions). But once I understood what the tyres were communicating to me, I no longer have an issue with them. Just change your driving style to adjust to the tyres or like what has been previously mentioned: Buy Michelin LTXs.
    Please don't blame the available power because it is the user who extracts the power. That is like blaming Porsche for speeding tickets! :-)
    Cheers!
    Well, as much as I hate to spend money on new tires right now I guess that is what I need to do. Does anyone know how much the Michellin LTXs are?
    I believe the LTXs in your size run about $105 each at TireRack.com.
    TC
    Michelins are good. I really like the Pirelli Scorpion A/Ts I have on "Gojira", my 1993 PF SE. Good wet, dry, snow, and mud traction. They were the winner of an Automobile Magazine SUV tire test a couple of years ago.
    In terms of the LSD:
    yes, it will give you better traction than average while one or both tires are sticking, but once you break them loose, usually both break loose instead of just one.
    The condtions I've noticed this happening are slower speeds (1st & 2nd gears), snow covered roads, with a little grade, and a little bit of crown on the road.
    My old Cherokee would let one rear wheel spin, and the other would just roll along straight on, but the rear would be less prone to slip sideways.
    The PF LSD seems to break both tires loose at about the same time, which results in the back end having more of a tendancy to go to the side.
    I agree with you completely. After "learning" (slipping around in a empty parking lot) with the new PF, I have no issues with the tires because I know what they will stick to, and how they handle.
    Three hours away in Steamboat CO, Bridgestone has a winter driving school that is supposed to make seasoned snow drivers look & feel like rookies on the white stuff. I am toying with the idea of heading up sometime this winter, and making an idiot of myself, but learning something new. :-)
    Gritz
    I agree that the Bridgestone Dueler tires leave much to be desired. I took mine to a tire shop when it was new and they said they'd give me $40 a tire (they are $95 new) and I was going to get the BFGoodrich Radial All terrain but it would have been another $500. The BFG's are excellent tires, especially in snow and mud. They will make a little more noise though. I had two sets on my last truck and the first set lasted 65,000 miles, the second set still looked good after 50,000 when I sold the truck.
  • rmiyamotormiyamoto Member Posts: 4
    I bought a 2001 SE about a week ago and have noticed that the temperature gauge reads kinda high. It's not at the "H" mark, but just a couple notches below it. This doesn't seem normal to me. The engine doesn't seem to be running hot, maybe it's just the sensor that's having a problem. Has anyone else experienced this?
    I don't remember how many "notches" the gauge has, but I know mine is typically reading at or slightly below the middle mark. Mine is an LE, so the gauge package might be slightly different than an SE.
    rmiyamoto;
    That doesn't sound normal at all. In general I would expect it to read about in the middle pretty much all of the time. It shouldn't fluctuate much either. My 01 is a notch or two below the middle of the gage when warmed up.
    Are the Bridgestone duelers really as bad as everyone is saying? I have them on mine and they seem OK. I've had them on the snow several times and they seem to hang on pretty well. The tough part about evaluating tires is how do you really compare? It's sort of difficult to do a side by side test with different tires on the same car in the same conditions.
