Visitor Agreement.
Please contact me at todd.plunkett@relizon.com with any questions.
Regards.
The T1 class is the most stock class in Dakar. It is for unmodified, gasoline powered, production 4x4s. As a matter of fact, Nissan Pathfinders put on a tremendous showing, also placing very high in T2 (improved 4x4). You've got to be building a pretty good product to place well in the T1 (or T2) class in Dakar. An MB M-Class took the T1 last year...better luck next year Drew :-)
http://www.escribe.com/automotive/european/mbmc/m12101.html
http://www.escribe.com/automotive/european/mbmc/m12132.html
http://www.escribe.com/automotive/european/mbmc/m12090.html
I was impressed that Jutta Kleinschmidt won the rally with her Mitubishi Pajero. She was never the quickest, but waited for all of the aggressive (male) drivers to knock themselves out. :-)
Drew
Vans and Aftermarket & Accessories message boards
BTW, have you found a decent site on the Dakar Ralley? The official site (dakar.com) really bites.
I have emergency stuff in the little storage compartment under the rear floor. And I don't like leaving the head rests behind in the garage.
Going to Home Depot every weekend has taught me that the best place to put them is actually in front of the second row seat.
Working from memory (I had a '97 PF SE):
1. Pull the headrest out.
2. Start to pull the bottom seat cushion up.
3. Before you complete pulling the seat cushion forward, slip the head rest *upside down* in front of it, behind the front front seat. There should be enough room. If not, slip the front seat a tad.
4. Fold down the rear seat back as usual.
Hope this helps.
TC
Nissan better make sure that this thing can tow at least 7200 lbs. I will need a bigger tow vehicle by then.
Where do you race?
I race in the NE: Watkins Glen, Lime Rock, Pocono, Summit Point. New tracks for me this year will be NH, VIR, Rausch Creek, Mont Tramblant and Mid-Ohio.
Cheers!
Amsoil also sells one.
RCSutton
S.Fl
Z
Love it!
yes-VERY fun to drive!
I handles like a dream!
It still tows great when needed.
I would get the stick again in a second!
But I do realize that they are hard to find. Of all the dealers I surveyed, manuals were under 5% of the units in stock. But as most of you know I went to Canada to get my Path. Found the 5spd I wanted and saved a bundle of cash too. Figure about $24,500 for a 4wd 5spd with sunroof pkg and limited slip.
-Jon
The extra horsepower is traded for torque. The 240hp auto has more 25 lb-ft of torque. I think it makes the auto a little more driveable because you get more power at lower RPM where you seem to be most of the time with an automatic.
As I understand the towing capacity is reduced to maintain the life of the clutch. Did you ever tow something that weighs 5000 lbs up a hill? It takes a little to get going!
Did you ever find a way to control the DRL's and the foglights seperately?
Since I am talking about lights, I finally put the PIAA super whites in that I got a while ago. I wasn't expecting all that much even though I think I paid about $50 for them. Other posts indicated that there wasn't that much difference. There is no doubt that the light is whiter. They do make the original halogens look yellow by comparison. The brightness wasn't hugely increased but It is a little better. One thing I noticed with the originals was that it seemed like they needed to be adjusted up a little. Others have made that same comment here. With the PIAA's the light does seem to reach farther and it doesn't seem like it needs an up adjustment anymore. I am wondering how the rather expensive PIAA's compare with some of the other low priced brands that are out there.
I'm trying to decide if this is the best route to haul around my growing black lab pup, and would appreciate any feedback. I've checked out the two accessories at NissanParts and they seem to be a decent deal, but I'm looking for any pros, cons or alternatives that you've tried. It does need to be the metal divider, because the pup would chew right through the mesh ones. (the joys of puppy ownership :-)
Jerry
Foglights (for US and Canada). The electrical schematic shows it will be very easy for the SE. Just change a wire at the relay. The LE is more complicated though because of the auto-headlight circuit. Will need to study it more.
DRL's. Just pulling the one wire we talked about should disable them. Inserting a switch will allow you to control them.
I have not tried either yet. Excuses so far: Coldest and snowiest December on record, relatives at holidays, house remodeling, broken garage door opener,..... Maybe this weekend since I've been prodded.
-Jon
Yes, I have a 01 Canadian LE. The headlights I bought were 15660 PIAA's. I got them from Carparts.com and they were 59.50 minus 1/3 off for the e-coupon (the number is 1963005), plus shipping. I don't necesarilly reccomend Carparts.com but they may be the cheapest. Just be ready to wait and don't expect them to tell you how long.
I didn't replace the foglights (yet).
Running Perfect with No-Shimmy (that I can tell anyway), as I have been really looking for any shimmy hard after reading of the shimmy troubles had by others in this thread:)
I just hit 3,000 miles (YES, ALREADY!) and had my 1st oil-change/check-up 2 dyas ago at Pat Peck Nissan in Gulfport, MS. While I was there I picked up both the Rear & Side Wind Deflectors and had them installed as well. I also purchased two metal Lisence plate brackets/holders (one says NISSAN and the other says PATHFINDER accross the bottom-center of the bracket. My PF looks pretty sharp now with these accessories, I must say!
Just wanted to give a quick update....gonna go for a drive now along the Gulf Coast in Biloxi and Gulfport, MS. Honk if you see me!
Mike
b) thick [?] 2" high [?} rubber bumper stick on's for preventing damages to bumpers by those who like to park behind or in front of me using the "tap in or tap out" method....some can't park a vehicle in a spot unless they touch the one in back or in front of them.....JC Whitney has something that may work; "bumper protector"
28 1/4" long; 2 3/8" high; 3/4" thick, which can be cut in length for $ 21.95/pair....a lot cheaper than paying for body shop work to "plastic" bumper cover on PF...
c) seat cover for back seats....do they exist ?
Any ideas ?
X2
1. I want to have remote start on my next vehicle. Is this possible on the new PF's, because of the chip-in-the key thing?
2. What things should I look out for before buying a new pf. So far, I'm on the look out for the shimmy. Anything else?
3. Is it possible to replace the factory stereo and still have the steering wheel controls work?
4. Does anyone have pics posted of their new PF's anywhere?
Thanks a lot!
PYRENUS
Side moldings -
I was in there getting the clear vinyl headlamp protector material put on the sides of my PF (6" wide down both doors between the creases) as well as hood protection and headlamp protection on the headlamps.
Remote start -
While there the remote start guy and I discussed putting one in. He said I would have to sacrifice a key (which he would hide inside the steering column to enable start). I don't think it's a very good idea. It would disable the security system. I wonder if the vehicle could be push started with the ignition wired on. That's how many thiefs bypass start inhibit on aftermarket alarms.
TIA
TC
Something about this just doesn't click with me. Maybe 3M has photos on their site, I'll try to search.
After a full year (including a tough winter), it came out looking mint. It also lets enough UV through to allow the paint to fade under it so it continues to match the paint not covered by it. I will get it done to my 2001 soon. I would recommend it (although costly, it was around $120 CAD installed).
I had the same material installed on my foglights (because they're glass). For my headlamps, I use the FOCUS clear headlight guards. Very good fit and look, and very quick to put on and take off (snap on, snap off, no mods required).
I checked the factory shop manual. It has a good description of the circuit that ends with saying the lights will come on when "outside brightness is darker than a prescribed level". Does not appear there is an adjustment on the sensor. It has three wires: power, ground, and output. Very little else to guide you from there, but I will assume that it is a voltage output. You would need to monitor this line over a range of light conditions. Could be possible to add a dropping resistor if the voltage needs to be lowered. Would have to add an amplifier if it needs to be raised.
The auto light control is just under the passenger side dash. The output from the light sensor is the white/green wire.
Or the much easier, much lower tech, much more reliable solution would be to put a small piece of tinted film over the sensor. It's on the dash, up against the windshield.
-Jon
I have one question. When I turn on my climate control, and the fan is on a low speed, I can hear the fan making a kind of high pitch whirring sound. Has anyone else experienced this, and if so, what was the fix ? I haven gone to the dealer about it yet, I thought I would get some info from you first
kj
Pathstar, I agree with you on the time delay. I've noticed other SUV's lights come up earlier than mine, say going through a tunnel at the same. I doubt there is an adjustment for that too, but maybe someone can confirm this.
Update on the cracked windshield: Not under warranty because it was due to a ding, however small. Getting it replaced tomorrow. I checked that I am getting a NISSAN windshield, none of that after market stuff. Can someone suggest anything else I should look out for? Thanks
Also, received the replacement stanchions to install the rear deflector last week. Will try to install this weekend (after a nice car wash-the poor baby has been neglected long enough) and will let you all know how it looks, plus the sunroof deflector and side mouldings.
BTW on my shimmy. The dealer here balanced my tires and it is 95% gone. It is now only noticeable on rare occasions. I think I will plan to go ahead with the index balance as per the NSB covered on post 538 here. My dealer did admit the NSB and the next step was index balancing.
