Visitor Agreement.
At time of third and warranty rotor replacement at 19500 km, I specifically asked my rep. to make sure they use torque wrench to tighten nuts ; he defensively said they always do that.
I retraced the events that happened ever since I p/u my 2000 GCL last Sept. -- first the dealer upgraded my tires for free so the factory torque specs are not followed, which may have led to rotor warpage at 6000 km and 12000km ( the tire rotation at 10000km was done at a tire shop and torque wrench wasn't used for sure--I watched)
Now last week I check the last rotor replacement and guess what? The nuts were so tight it almost bend my back to loosen them. I retighten them by the historical way . I am observing how long this set of rotors will last. So far only 1200km had accumulated and hard to tell whether overtightening the nuts caused rotor warpage -at least for the GCL..
Will report to board .
note: manual spec around 185 - 225 ft pd.
I just clicked over 98k this past weekend. I do keep it well-maintained and serviced from a friend of mine whom I met before I knew he was a Jeep mechanic at Nalley Jeep in Roswell, GA.
I run nothing but Goodyear Wrangler HPs on it and I normally get at least 25-30k on the tires before replacement (39k on two of the originals). I usually find some way of puncturing at least one tire just after I purchase four new ones. If the Jeep your looking at is a 4x4, then have all of the tires replaced at one time and keep them rotated accordingly.
Yeah, I have the gear whine. But the stereo is awesome and will drown out the noise if you let it. It's a 4x4, so the noise comes with the territory. If you think the whine will be an issue, then you might want to consider a 2wd.
Maintenance isn't cheap, but I've had a blast with mine.
FYI, it's never jumped out of park.
Thanks for letting me know the mistake.
sorry folks,
Thanks again
The un-even or overtightening is more likely IMHO. The '99 1st warped rotors came soon after the dealership had the front end aligned...don't remember if they rotated and balanced while they were doing that. Second warped set came 15000 miles later after at least 2 balance and rotations. Traded for a '00 when they would not talk about replacing second set of warped rotors (had several other problems fixed under warranty). At 14,000 miles the '00 rotors were warped, maybe a couple thousand miles after first rotate and balance. DC would not even consider replacing them under warranty. Filed case with customer service, dealer rep. called me and basically blew me off. I bought a set of rotors from Autozone (about $100 including tax) that have a 24,000 mile warranty.
Just got my survey from the service where they fixed the fuel pump and blew me off on the rotors. I am rating them way down and getting some shots in on DC Customer service non-response.
The first time they replaced the rotors at about 15,000 and I was told that the pads didn't need to be replaced.
The second time, I had already looked up the TSB below, specifically listed it in my work order and they replaced the rotors but not the pads. I didn't have time to fight with them then, and I knew that I had to come back to get the from differential overhauled.
When I came back the third time after about 1,500 miles, one of the rotors was already showing abnormal wear. I again specifically mentioned the TSB. They said that they would replace the pads but they would not be covered. I pushed on this and the service manager did replace the pads and also put on new rotors again at no cost. They said that these were the 'better and more expensive pads".
The TSB says that the pads have backing to keep them from sitting on the rotors.
It appears if you have the TSB info and push it, they will cover this. At least they did for me. I hope this is a real fix.
I also pushed on the from end whine on my I6 select track. They finally overhauled it.
The TSB for this is 03-05-99 (Sept 24, 1999).
It's too long to include.
Here's the TSB on the rotors.
"Knowlegde is power"
Brakes - Roughness or Pedal Pulsation
NUMBER:
05-01-00 Rev A
GROUP:
Brakes
DATE:
April 14, 2000
SUBJECT:
Brake roughness or pedal pulsation when the brakes are applied.
MODELS:
1999 - 2000 (WJ) Grand Cherokee
OVERVIEW:
This bulletin involves installing a brake pad repair kit and turning the brake rotors with an on-car brake rotor lathe or replacing the rotors if on
car equipment is not available.
SYMPTOM/CONDITION:
Customer may experience a vibration of the steering wheel, floor, seat, instrument panel or a minor pedal pulsation (brake roughness) under light
to moderate pedal application. This can be caused by excessive thickness variation on the rotor surface.
DISCUSSION:
A new brake pad repair kit has been released which contains an adhesive backing. This will provide for a more positive release of the brake pad
when the brake pedal is released. This, in turn will move the pad away from the rotor, resulting in less friction and wear, which resulted from the
pad resting on the rotor when the brakes were not applied.
The preferred method to reduce any variation at the brake rotor surface is to resurface the rotors using an "On The Car" brake lathe such as the
Pro-Cut lathe which is available through Pentastar Service Equipment. This equipment does an excellent job of correcting all variation at the
rotor surface. "Off the Car" equipment can correct variation on the rotor surface but does not correct for variation on other rotating components
such as the hub. Situations can occur where a rotor and hub, mounted together, both within specifications, can stack up tolerances resulting in
lateral runout, which can cause a pedal pulsation.
PARTS REQUIRED:
1 05018592AA Brake Pad Kit
AR 52098672 Rotor
EQUIPMENT REQUIRED:
Pro-Cut on car brake lathe (or equivalent) if available
POLICY: Reimbursable within the provisions of the warranty.
What amazes me is that anyone would take a chance on a Jeep vehicle. The problems with the GC have been around for years, it's not like it's new. Now there is another problem with the tranny coming out of park for no reason. This on top of all the other problems. I also feel bad for the ones who couldn't wait to run out and get a new Jeep Liberty. Based on Jeep's poor track record they too, like all other Jeep products, will have a very poor resale value. The only way Jeep will get it's act together is if people demand a quality product. How? Don't even consider buying inferior vehicles, no matter who makes them ! Let the buyer beware. Shop smart !!!
Anyone has similar problems and know what was repaired. If possible I would really like to do the repair myself.
Thanks in advance.
As far as Consumer Reports go, I would disagree with you. I have used them, in conjunction with other information over the past 20 years and have found them to be very accurate and impartial. You state that they rave over the Triscape twins but the forums here show a different story.
CR wasn't reporting on their reliability only on their road test preformance as they don't have any information as to how they will hold up over time. The forums here, to a large degree, reflect the reliability issues that some of the owners are having. Wait until the April 2002 auto issue of CR comes out. I'm fairly sure that will reflect the Edmunds forum in terms of problems just as it does with the Jeep GC. CR rates that vehicle 'much worse then average' something that seems very accurate based on the forums here.
I will agree that the TriScape twins are very cheap feeling vehicles so I quickly eliminated them after my road test earlier this year. The five recalls plus the continued problems they seem to be having makes me very comfortable with that decision. I read the report on the Montero and didn't see anything vague about the reporting. I'll have to take another look though.
American car owners generally don't care for CR because, in my opinion, they tell it like it is and as a result those cars don't fare too well against the imports. Those reliability ratings, by the way, are based on information sent back to CR by consumers. CR only reports the information. I like the fact that CR doesn't accept any advertisements that could somehow affect how impartial they remain. How many magazines can you say that about? The major car mags are generally very 'nice' in their car reports, addressing preformence issues, almost never touching the issue of reliability even in their 'long term' reports. I find a big difference in reporting 'style' between them and CR. I prefer the truth, not something sugar coated. I certainly don'y use just CR for my information. As you well know, thanks to the internet, there are many places to go to find out information about a vehicle including forums like Edmunds, NHTSA.gov and so on. When you get very similar feedback, well, 'if it quacks like a duck.....'
In any event, I wish you the best with your new Liberty. As long as you're happy with it, that's all that really matters.
As a consumer, I do my homework. I follow the media and this message board for information about JGC.
You are absolutely correct that people should demand a quality product. Your solution assumes: 1)that ALL Jeep products are junk and therefore should not be purchased. Jeep gives owners 3 years/30k miles to work out the problems. Like all durable goods producers, auto manufacturers must rely on their reputation to encourage repeat sales and references. The consumer still has the final say.
2)people demand perfection. Certain vehicle parts are made to wear out and be replaced. SUVs (especially 4x4s) have more working parts than autos. So, more maintenance is needed. I accepted that fact when purchasing the JGC. The expectations of many people are too high.
I don't see people flocking to this site, or anywhere else, saying Jeep Grand Cherokee is awful so don't buy it.
All I see is you making an inflammatory statement based purely on speculation about a subject of which you have no knowledge. Ford Explorer has many problems, too. Look at THAT message board. Finally, if you something constructive to say, let's hear it!
I hope we are right about the liberty. It is the first jeep product I have owned so I guess I'm taking my chances based on past history. I will be the first to critisize jeep if owners start reporting problems in droves. Since there is not a whole lot of history with this vehicle, I can only comment on the quality of the build components and the fit and finish. Both appear to be excellent so far. I have a limited w/the G package, and compared to a comparable tribute ES interior, the liberty is noticably better.
give it a year or so & the mechanical reviews will start coming in.
I saw several today. 4x4 badge is now under Jeep badge on the tailgate. Roof rack croos bars are missing. The base price seems to have dropped quite a bit (around $2K?). Full-size spare is now standard.
Bob
The one that I looked at was missing the roof rack cross bars and protective rubber strips on the roof.
Comparing factory window stickers from identically equipped 2001 and 2002 models, I noticed the gas mileage ratings for the 2002 were 19 hwy, 14 city for the V8 - a little lower than the 2001's. The cargo net feature was not listed on the 2002 sticker (it was specifically listed on the 2001 sticker). And the MSRP was less for the 2002 model at $32,665 vs. $35,845 for the 2001.
I am unable to find very much info on the internet for the 2002's yet. Maybe someone can explain the missing cross bars and cargo nets, and the mileage and MSRP differences?
I wonder what else they cut out, in order to lower the MSRP? I'm glad to see a full-size spare as now being standard.
Bob
I'll try and address the questions and comments you made: As far as where I would go if I had a problem with my Highlander not found in any literature....I would do what everyone else has done here. Post a message asking if anyone else has had the same problem I was experiencing. Yes, I do value and give much credence to the posts at Edmunds. Why? Because the sum total of so many experiances, both good and bad, is invaluable information when thinking about purchasing a vehicle.
No, I haven't read all 518 posts but I've read the vast majority of them here as well as most of the others in the SUV forums. I didn't have to read all of them here to discover the same thing you did, namely the patterns emerging that you mentioned for specfic problems for specfic model years.
You seem to imply mostly negative comments are written here about the GC, "if it ain't broke, don't fix it", and you state that the comments here are skewed towards problems and solutions. There are some people who are happy with their GC. Not all the posts are negative. My point is that there seems to be a much higher amount of people with problems then a lot of the other SUV forums. Let me ask you this? Why aren't some of the other forums skewed toward problems and solutions? The answer.... Much better quality therefore less problems. Please, don't mention the Ford Explorer. I consider them in the same arena as the Jeep GC, just as problematic, again based on available information from different sources. The Ford Escape? Five recalls? Sorry, no excuse for that. There now appears to be a problem with the engines dieing for no reason while being operated. Check out the Escape forum for more info on this.
Regarding your GC you state " Yes, it needs repairs again and that's why there is a warranty". This is what I don't understand frankly. You sound so complacent, like this is what is supposed to happen with all 4WD vehicles. That the same parts are suppose to break down and that, ol well, it's under warranty so who cares. Guess what? It's not. A warranty is to cover mechanical failure within a certain mileage/time frame. If the same parts keep failing what happens after the warranty? Better yet what happens when the same parts fail and Jeep decides that it will no longer cover the repairs even though it's within the warranty period?
The rotors are a good example of this. Rotors going after 3-6000 miles is normal? Can all those people who posted here be wrong? Can all those who complained to NHTSA be wrong? I've read a lot of posts about this problem as well as the gear whine, the death wobble etc...I have three friends at work who have GC. None of them is happy and the list of constant problems and repeat problems is too long to list. There experiances are in line with what is posted here as well as what was reported in CR. That the Jeep GC seems to have an inordinate amount of problems, say a higher percent of problems as compared to others.
Why would a person tolerate these problems is what I can't fathom?
I never said that ALL Jeep products are junk. Just that based on ALL the available information, they seem to have a much higher incidence of problems then some others. Yes, Jeep does give you a 3 year/36,000 warranty. I thought that was to cover the occasional problem that might pop up not to cover the same problems repeating themselves over and over until Jeep decides it won't cover it anymore because they realize that they can't fix it. Not to mention all the aggravation of getting the vehicle repaired and the down time. Sorry, but my time is too important wasting it waiting for my vehicle to get repaired . Again.
As to your comment that people demand perfection...you are kidding right? I don't think anyone expects perfection from any car model. How about that the same parts don't fail? Or maybe when they are repaired, they stay that way? How about not having a laundry list of problems over the life of the vehicle? How about if a part can't be fixed (say brake rotors) that the manufactor issues a recall for an obvious defect/poor design instead of telling people they won't cover it anymore, sorry. For a $30,000 plus vehicle, is that really too much to ask for? I don't think so.....
You say more maintenance is required with 4wd's. I agree with that. You seem to equate maintenance with defective parts and poor workmanship. There is a huge difference. You say that the expectations of people are too high? Again, you have to be kidding..... I EXPECT a quality product, one that will last without the same problems coming up again.....I EXPECT the manufacturer to respond to any problems I might have in a fair way....I EXPECT decent resale value when the time comes to sell it and I EXPECT an enjoyable experiance while driving it. Is that really too much to ask? I agree with you that consumers have the final say. That is why DC has had massive layoffs, declining market share, and loads of 2001's on the dealer lots that they can't get rid of.
I don't think anything I previously posted could be considered inflammatory. Not sure where you got that from. Could you be more specfic? Speculation? The negative posts here are speculation? CR and NHTSA speculation? I don't think so. A subject of which I have no knowledge? Because you own a GC that automatically makes you a more informed person about cars? Maybe about getting repairs done (sorry couldn't resist that one ). I seemed to have hit a nerve with you re: my last post, why I'm not sure. As I told winbro, as long as you are happy with your GC, that's all that matters.
My point is that people, especially people who have purchased the same vehicle line all their lives, shouldn't just resign themselves to the fact that poor workmanship and inherent design problems are what's to be expected. (I remember one lady in the Ford forum state that "I've always purchased Fords so I guess I'll buy another". Gee, what a stunning endorsement!! If more people would stop buying junk, car makers would be FORCED to improve, thereby causing consumers less headaches.
Please don't take things so personal. They are only cars.....As to your last comment....I didn't think that saying something 'constructive', at least your definition of constructive whatever that may be, was a prerequisite to posting here. I thought these forums were for exchanging idea's, opinions and experiences. Did I miss something? :-) Good luck with the GC !!!!
Do they ever send feedback or customer surveys to HQ . With piles of defective rotors in the garbage bin at the back of service dept (as one reader wrote) , they are still making the same junk for the 2001 or maybe 2002. Do they ever learn from mistakes?????? or are we tolerating their mistakes ??? or they run out of solutions?? Or the waranty claims hasn't ding their revenue enough ????
Seems that the gear whine and the rotors are the two major defects GCL has, why don't they do something?????
WINBRO - Wind noise from the cross bars may be there but my vehicle is too noisy to tell. Unless they strap a rock band to the cross bars, I'd never hear it
I think anyone who wants to gamble their hard earned bucks on a Jeep product is nuts. I did test drive a Toyota Highlander and the difference in quality, fit and finish was dramatic. Talk about smooth. The GC is no where in the same class as this vehicle as far as the feeling of quality of a well put together vehicle. It may not be able to go everywhere the GC can, but that's not an issue for me as I've yet to go off road with the Jeep I have.
I like the the 4WD for the snow, not for any rock climbing. An article posted here at Edmunds stated that the 'experts' estimate that 95% of 4WD owners never go off road ! The Highlander ride is outstanding, and the drivetrain is silky smooth (the same drivetrain in the Lexus RX-300 including the 220 HP V6). I still have a few other SUV's that I want to look (including the Xterra) at but so far nothing comes close to the Highlander. Even the interior screams quality, not made up of cheap plastics that aren't put together right.
My friend, who is a big Toyota fan, told me that unless you test drive the Highlander and compare you'll never 'move up' to the next level, assuming that what's out there is good enough. Boy, was he right!! Toyota's reliability is already proven, about as bullet proof as you can get. When I think of all the time I wasted in the Jeep dealership, not only arguing to get the darn repairs done, but the time waiting for parts, the time waiting for the actual repairs.....I could scream!!!
Thank goodness this was a lease. I feel sorry for the person who buys it as a used vehicle. As for me, I refuse to a part of the 'Jeep Experiment', hoping that Jeep finally gets it act together AFTER buying their product. No, I won't walk away from a Jeep product, I'll run!!!! Fool me once, shame on you...fool me twice, shame on me!!!
I believe (at least on the Grand Cherokee) the 2wd and FULL TIME 4wd are marked in GREEN lettering because they are okay to use on dry pavement. ALL other positions are YELLOW thus grouped for loose surface only....
I have been told this is the case...
Anyone....
I'll check the Jeep site too...
To anthony921: now my eyes are open, and my foot removed from my mouth.
As for problems that aren't resolved, and when all recourse fails, call your state Office of Consumer Protection (Justice Dept., Agriculture Dept. in Wisconsin). If, & when, enough complaints are lodged against DC for its warped rotors and whining differentials, maybe a class action suit will evolve.
Don't forget to look into the Lemon Law. Each state varies a bit as far as how it's applied, but it might be worth a shot.
I wish you the best !!!!
later..
Saw your post on looking for the right SUV. After reading posts on this JGC board, I decided the JGC was not for me. Too many problems! I test drove a Nissan Pathfinder and fell in love with it! I've had it since April and haven't had a problem. This is one you should look at.
I can't wait to get rid of this over priced nightmare from hell Jeep GC. I really feel sorry for the person that gets stuck with it.
Thank goodness for leases !!! Yipeeeeee!!!!!!
Best of luck with your new Pathfinder !!!!!!
I asked the technical representative about the transfer case whine that has been reported on this board. He indicated the problem has been solved for the 2001 model year. He also said the rotor and disk problems date back to the elimination of asbestos brake pads.
Incidentally, with 13k+ miles on my 2001 JGC, it has yet to see the inside of the Jeep shop for any type of service. I put in Mobil 1 10W-30 myself. It's been great.
Thinking of getting a 5 year/100,000 mile warranty on my 1998 Jeep Grand Cherokee Ltd (now at 43,000 miles).
Just had the air conditioner replaced ($1,200) and anticipating other things going wrong in the future if I want to keep it.
All responses and opinions welcome!
