Thanks for the followup. Glad to see that things have worked out. I noticed that mine does rev higher than normal for the 1st and 2nd gear change of the day (in "D") after backing out of the garage. However, it shifts smoothly into the next gear.
Drew
Townhall Community Leader/Vans Conference
long time no see... Too much travel lately...
My '98 ML is now at 30k miles (built May of '98) and had only minor problems. Still drives better than anything else in this class (especially the elevated Camrys they call RX300). It was in the middle of the latest Buffalo blizzard and handled it very gracefully. Even pulled some cars and other SUV's (yep!) out of ditches :-).
Some whiner mentioned recently that '98 MLs have no 4ETS. Come on! They do. In fact they have all the safety features of the newer models. The updates in newer models have been overall really minor, even the ones that MB calls "structural". Of course, MB would like to have you believe that hey are redesigning the truck every year so that you trade your old one in for a new one. That's called "business development strategy". You are smart guys and you can read and compare features I suppose.
COLD WEATHER TIPS:
For those of you driving in very cold weather: Make sure you ventilate your truck, i.e. do not drive around with recirculated air. This builds up moisture that can get locks (and doors) stuck due to water depositing there and freezing. If you get a lot of snow on your mats leave some windows partially open when you park your truck in your garage so the interior can dry out. Otherwise all this water will end up on places you do not want it to be when the interior of your truck cools down. Read your owner's manual and use some common sense. What you are driving is the best SUV on the road bar none.
Cheers!
TJ
What did you use to pull them out?
The only major safety features the '98s did not have is ESP and rear side air bags.
The only problems I've had were a bad fuel pump at 18000 miles (replaced) and a radio/nav system that died today. I turned the car off yesterday and the radio would not turn off. When I started the car today the radio/nav system would not turn on. Going to the dealer on Friday, he thinks it may be a fuse.
Has anyone had a problem like this in the past?
Good to hear that you have had only these minor issues. Could you tell us the build date of your ML320? It is printed on the sticker on the driver's side door frame (lower right hand corner with the door open).
Please let us know what the problem/solution turns out to be!
Drew
-mr whipple
Drew
Even though the spare tire is the same height, could the narrow width cause a problem with the traction control off-road, since it would be lighter in weight? That could be a nasty situation.
-thanks
Drew
Are others seeing brakes worn out at 25k miles? I assume those are not replaced under warranty, are they? TIA (2000 ML-320 12,500 miles built 11/99)
Jeff
I don't know anyone that has tried them. I almost traded up my Generals for them but Direct Tire (in the Boston area) claimed they cost $200/each to them, even though I could get them for $160 mail order.
primitive:
We talked about this a while back. Have you tried bringing along a big pillow to put in the middle? Most kids would rather rest their head on something soft versus a hard door :-)
Simple question can lead to simple answer. IF a Ford excursion runs a red light and T-bones the ML with littles ones in back, would you rather not have airbags between their little heads and the front end of excursion? Imho, most of problems are low impact deployment of airbags in front seat that does not have the 2 stage bags. The side bags are small and only offer a small buffer.
My kids are 9 and 6. They understand airbag thing as reason not to sit in front, and we explained airbags in doors as reason to sleep towards middle. They pillow up on armrest. Also very little chance getting t-boned on interstate. All statistical odds. Bottom line, in worst case scenario, I want them bags there.
Robet
Average price for ULR87 at the pump as of 12/4/00
USD$/Gal
Germany 3.52
UK 4.49
US 1.69
Now lets remove the taxes:
USD$/Gal
Germany 1.14
UK 1.14
US 1.28
So, gas is actually cheaper in EU. I wonder what all those blokes are complaining about ;-)
All joking aside, I am sure we, on this side of the Atlantic, always knew about the exhorbitant taxes on gas in EU, but I betcha we did not realize to what extent!
They gotta pay for their universal healthcare, etc. programs *somehow*. Despite what our pols tell us, nothing is ever "free" :-)
I certainly would rather have the airbag than nothing at all in a side collision, BUT I also would like to know the total risk associated with the airbag (deployment, injury, etc). It would certainly be a sad thing to be told that your child is seriously injured due to the bag when the side impact wasn't extreme. Same type of concern people had with toddlers with front airbags.
Sleep toward the middle...that will work when they first fall asleep but not when they "reposition" while sleeping!
It seems that the magic age is 9-12 years where airbags should not pose a hazard. It's that age between 6 and 9 that spawns my question.
Thank you for your responses.
I didn't know that the ML55 had a air compressor in the spare tire unit. I'll have to take a look again to find that. I'm guessing that it's just a can unit and not a powered air compressor unit.
And yes, if you ever have a chance to check it out, could you please find out what the prices are on those wintersport tires at your local tire dealership!
Jason
http://www.eia.doe.gov/emeu/international/prices.html
Tj98 wrote:
<<Some whiner mentioned recently that '98 MLs have no 4ETS. Come on! They do. In fact they have all the safety features of the newer models.>>
My response:
I'm probably the "whiner" you are referring to! I am surprised you are not aware of the significant safety features in the 1999+ models.
You were very mistaken regarding your misinformed post...ETS has indeed been standard on all ML's regardless of year..However, what was being discussed was ESP and BAS both technologies that were only available from 1999 on. These are very significant and you should do some research! Your 1998 ML does not have these features - read up before you call people names - ignorance is bliss I guess!
Cheers!
Regarding the Dunlop Winter Sports, I'll see if the persons that I've been in contact with at MB Canada HQ know the prices. If not, I'll check at the parts counter the next time I visit the dealership. In any case, I'll let you know as soon as I find out anything.
Drew/aling
Edmunds.com Townhall host
Yesterday, the ML townhall fell off from the Top 10 list. I think we shouldn't let that happen again. Agreed? : ) That is why this the 3rd contribution I made since then. Ha.
My wife accidentally activates the rear-window buttons on the BACK side of the center console (the switches for the rear passengers) with her elbow as she opens the center console box. Don't ask me how she can, but I have seen it many times. I suspect that you have similar "Gremlins"!
Drew/aling
Another related one is ROTFLMAO (Rolling On The Floor Laughing My A** Off) for times when it's more than LOL :-)
As far as trying to do the donuts in the parking lot, it was rather hard with all of the system engaged. I really had to push it into the donut. I guess if it wasn’t 4WD it would be easier. Even with the ESP off it didn’t slip much. Pretty good systems.
I still think that it would be wise to keep on the gas. In driving school they told us to let off the gas and don't touch the brakes, I don't think that is necessarily correct. Even with regular RWD cars I still keep some pressure on the gas.
Robert
Do you know the particulars of the accident, speed, etc?
Drew/aling
By the way, my 00ML320 was re-ended last winter, but pretty low speed at a traffic light, you may remember. We had to have the rear bumper cover replaced.
lol!!!
