I need you help.
I have a 99 ML 430 with about 32K miles. Lately, my "AS/ESP" light would come on during a 1 Jr or so trip (and stayed on until I re start the car). I have made two visits to the local dealer, but so far, it is not fixed yet.
Would anyone have some ideas on what I should look for?
Thanks in advanced.
great avi drew, thanx !
dt77
Yup, they only charged me for the labour and the oil filter (for the early unscheduled change). FSS A is the only free service for Canadian vehicles.
I'm surprised that the dealer couldn't find the problem. An error code (hence the idiot light illuminating) will usually tell them what area to look at for problems. Did your previous work order indicated if they changed anything? Possible problems may be a malfunctioning steering wheel angle sensor/lateral sensor/yaw sensor, or wheel speed sensor. The worst case scenario would be if the ABS/ESP computer had an intermittent problem.
Good luck and please keep us updated!
Drew
Vans and Aftermarket & Accessories message boards
didn't work as what the manual said. light still comes on, then I took it to the dealer a couple of weeks ago. The work order said they replaced the brake switch, which I don't know if its true.
Since then no more light flashing on my eye every time I drive my toy.
Take it back again to your stealer(dealer) and tell them about the brake switch. Good Luck
Robert, any theory on why Omar's and others on the mailing list needed to install 15 amp fuses? I know that both yours and mine, with the jumpers, worked fine without having to change the fuses. Interesting....
Also one of my first lights was damaged as the others have seen as well. The box's are fine it's the inner packing that is making the ends break off, I'm sure with all the claims they must be seeing it will be fixed soon.
In previous posts there was mention of buying a vent hose, I'd like to have the MB dealership do that.
Time of Fluid change - I was about 800 miles over the flashing light. but remember this... @ 1K I switched the oil and gear oil to synthetic.
I am using 30 weight Amsoil - then the recommended gear oil - just synthetic.
My synthetic oil user friends advised me I really did not need to change the oil, I just couldn't let it go though - too old fashioned for the technology.
MB dealer switched the FSS and the next service shows 10,000 miles.
Mike
Let us know what you think of the lights at night. I'm sure you won't be disappointed. Do remember that warmup time is about 30 seconds to a minute.
Drew
Here's what I know of it. I haven't done this yet. It's still on my todo list.
I've been away from this forum for quite a while, and now have a little over 3,000 miles on my '01 ML 270 CDI. Some impressions:
It's a pleasure to drive - IMHO more so than my '99 ML 320.
On hard acceleration and while still cold, the engine is more audible than on the 320, but once up to speed, the truck is definitely less noisy (the 320 had the ___///-roof).
Fuel consumption is WAY down, with no significant performance penalty, except for pure acceleration - I can live with that. Because of the reduced consumption, I now only have to stop ONCE for fuel on the 1,200 kms trip to our vacation home in SW France - instead of twice. And the diesel is quite a bit cheaper, so :-)
Quality has improved over '99 - but is maybe still not quite perfect.
The Desert Silver color (with tan interior) looks nice, and stays acceptably so even when dirty.
The Comand system is OK, but the TeleAtlas software is far from perfect. Coverage on the French disc is lacking, and plagued with too many errors.
The truck was to my great surprise (and initial disappointment) delivered on Generals (size 275/55-17), but they are in fact better for my use than the Dunlops.
Lighting was a definite problem on my '99, so much that I'd seriously considered fitting Xenons. While still not perfect, the '01 is quite a lot better in this respect. I've fitted Philips H7 VisionPlus and Osram H1 "+ 30%" bulbs, but the explanation can't all be there. I guess some modifications have been made to the reflectors.
Incidentally, my manual shows Xenon headlights with H1 hi-beams AND integrated H3 foglamps (I'll get the relevant pages scanned soon).
All for now - I'll be back soon with a comparison of fuel consumption of both trucks over the same distance.
Birger
Sorry I must have missed the original post about the battery. Is there a problem that I should be aware of/look for?
How do you like the COMAND's DSP settings? Effective or not so good?
Looking forward to your scanned pictures!
Drew
Jamie
I know that you live in the Chicago area. Can you recommend a good dealer for service in the area? As I feel that I might want to take my car to another dealer.
Jamie
I'd suggest trying another dealer first though...
I would like some objective information/feedback regarding build quality and reliability of the U.S. built Mercedes ML-Klasse. I've experienced the Deutsch built Mercedes and wonder about the differences in selected materials.
Thank you,
-C
For 2001, the changer is fully optical. Someone on the M-Class list installed a Becker successfully. The Crutchfield ones don't work on the 2001. You can also get the MB OEM changer from Clair, but it's pretty expensive at $600...
Drew
I had a discussion over the weekend with a friend who has an '00 320 and was at the dealer for oil change (to put Mobil 1 at 5k miles). The dealer obviously refused to cover the cost - he recommended instead a free dino oil change at 10k miles or whenever the FSS target would be (less than 1k miles from it). My friend is into high performance cars big time so he requested to see all the literature that the dealer has on oil change while the truck was being serviced (at his expense). He told me that he found with the service manager a memo from MBUSA which indicates that at least for the 00 320 model the engine comes from the factory with Mobil 1 and thus the subsequent free service must include Mobil 1 (something that the dealer initially refused and then accepted). IHMO 10k miles is still too long to wait for an oil change even for a synthetic oil, so I do it at 5k intervals with Mobil 1 (I have a '98 320). My friend started doing the same even at his expense. It is a small price compared to the price of the truck. I believe that it would definitely be damaging to the engine in the long run to keep a 10k oil change cycle (especially with dino oil).
It seems that most MB dealers have not adjusted to the fact that their customers nowadays are much younger than in the past and have more technically involved inquiries. At the end we will probably be the ones that pay the price down the road.
Cheers
TJ
This is the first time I've heard of this. Any chance your friend could get a copy/scan of this memo? :-)
Not sure if the dealer may have aimed them a little to low, or it's just me getting used to the new pattern, but I think they should be a little higher then they are. I'll give it a week and if necessary tweak them myself a little higher.
My next project is a set of Hella FF100 fogs or a set of the Micro DE's If I use the Micro DE's I may try to mount them in the outer brake ducts in the front valance. Although if I can get the FF100's in a good spot it appears they have a better pattern.
-John
MotorwerksIt may be a streach for you but MotorWerks is GREAT! I have never had a problem with them Tom Healy and Nickey Duax are great to work with. The other guy Dave Moritz, good guy but kinda forgetful sometimes. They have two bays for MB ONLY, the other two garages are for the Porsche, Cadillac, BMW, Infiniti, Honda, Olds, etc. They know how to treat the customers. And if you complain... They listen. One of the reasons that I go to them despite the distance is how they handled my accident last year. They helped me get all the right people to do the right stuff for my car. If planned ahead, they give 230K loaners which are pretty fun.
Loeber They were Okay. It is what I would have expected from a downtown dealership. No real complaints, they were cut and dry. Come in , drop it off, tell them the problems, pick it up. No real Customer Service. I feel that they did not fully investigate some of the problems that I was having. Their parts counter is another story -- sux. They will give you an oldsmobile loaner. When you get there you will be turned off by the fact that you will have to drive up three stories to get to the service bays and you pull right in to the service area. (but, HEY you are in downtown.) While I'm not going to make excuses for them, I do get there right as the doors open...
Mark Motors, Arlington Heights, they were okay, I dont like the sales people because they treated me like crap because I look like I'm 19 (I'm 24) and just wanted a free ride. Pretty snobby. The service people are good, and very helpful. They did everything they could to accomidate me, but still not as friendly as MW. These are the people who got me my HIDs, and very reluctant to sell them to me. Since they are one of the smaller dealerships, they are the easiest to get appointments with, they give Intrigue loaners.
Knauz I havent tried Knauz yet, but I am interested to try them. I have heard good things about them, but mostly on the BMW side. If you try them, please let me know.
CS is a BIG part of my car. Even the porters at MW were really nice! They drove the car up to me like it was meant to be driven. As you can see where I am biased towards. It may be a bit far, but the service is excellent. Definatly make an appointment.
I go to Loeber as a Convenience because I live in the burbs, but work downtown. Mark Motors as a secondary backup because it is close to the train, and easier appointments. Otherwise its MW.
Unfortunatly I think that some of the service people take on an attitude when they see a younger folk driving a Benz. They think that daddy bought it for me, etc. (not true) So it may be a different experience for a more "mature" folk. BTW I experienced the same snobbery when I took my father's previous gasp! lexus to Fletcher Jones in NV. But I recieved royal treatment at the Fletcher Jones MB, but I was also driving the CL500 at the time. . .
For the record, I have had good treatment at Fields BMW! (Drew you and some others may know what I'm talking about as the topic has been deleted)
DT, Any related experiences?
Robert
I also contacted my dealer today to make arrangements to have my (infamous) squeaky steering wheel fixed on my 00E320. While on the phone I asked about oil changes on service A.
I told them that I had switched to Mobil 1 at 5k miles and that when I come in for service A, what would be my cost? They said that seeing as though MB covered the cost of regular oil, the only thing that I would pay for would be the difference between the cost of regular oil and Mobil 1.
This certainly seems fair to me.
Don't know why everyone else on this board is going out and buying their own Mobil 1.
BTW..My wife absoulutly loves her 00 ML430. She says it "just glides". ;-)
That is very interesting. I have never heard of a dealer doing that. OKAY I never tried, but I sure will next time. All I can say is make sure you know who you talked to, and if indeed this is true many have wasted $$. However I do believe that this will differ amongst dealerships and definatly not a dealerwide program much like signing the "promise not to export paper"
Robert
It used to be a paper saying that the customer would not export the ML. Some accross the board have signed it, others havent. I was just wondering if it has changed since the evolution of time.
Robert
I just passed 1k miles and am ready to convert over to mobil 1 synthetic.
Just had another somewhat of a snow/rain storm here in the New York (5 inches of slush). The more and more I drive....The more I Love MY ML !!!
Thanks for all the info.
Danny d:)
Danny d:)
01 ML 320
Thanks quite a bit
Jamie
As a result, I am now about $265 short, but I got to drive a 2001 ML loaner.
My car is only 16K, though. At this rate, I'd be interested in learning how to change the pads myself.
David
WRT the torsion bar squeaks (it only happened when very cold in my case), I mentioned this at my last service and they added torsion bar shims in addition to lubing the area. Anyway, problem solved.
Will you be attempting the oil change yourself or going to the dealer? There are some great DIY instructions here.
Drew
Robert
They did replace the rear pads some 2 months ago.
The squeals came back, and now they thought the front pads were the culprit.
David
Regular = 1 USD @ discount stores
So the difference at Walmart is ~ 3 USD.
With markup, I'd not be surprised if the difference at the dealership level comes out to be 4 USD out of the customer's pocket.
