The cylinder head cracked and the radiator had to be replaced. I am not an expert on Land Rovers but I am not sure they are much better than the earlier MLs. As we all know, the service department cannot make a silk purse out of a sows' ear, but they can try to.
At 4yrs or 100K mi the spark plugs should be replaced. They can probably go closer to 100K mi if you wish and are having no check engine light on/flashing. They cost about $115pts/2.0hrs lbr. Make sure the crankshaft pulley/harmonic balancer has not begun to come apart. There is a campaign on this part. When it lets go, it eats up the upper oil pan and timing cover. Also, if you are driving it at the time it goes away the steering becomes very hard since you lose power steering caused by a loose belt. Other than that you may get an air filter, that's about it. The dealer can give you an estimate, whether it's the official M-B maintenance or the dealers' "modified" service.
The power steering failure problem due to the hose coming loose has discussed a lot, and while I'm sure it is no fun to have the problem happen, people who have done tests have found that the ML's steering is essentially the same as every other car when it loses power assist - the effort goes up, but the car remains controllable and steerable, albeit with a higher effort. The effect is exactly the same as if the engine stalls.
- Mark
My Land Rover dealer offers loaner cars when you drop your vehicle off for warranty work. I'm not sure how this compares to the M-B 300D story? We are just talking loaner cars here, right?
I don't live in the country, I got 46,000 miles out of the original rotors and pads on my 2002 ML500 and the "pad replacement light" had not come on yet but probably was getting close. My ML500 was a very sturdy reliable vehicle as it started every time and never left me stranded in 4 years. I can't say that about my two previous Jeep Grand Cherokee's ('96 & '99).
Mark
I bent one of the struts that hold up the rear hatch(dont ask me how)..I was able to remove and straiten it but a month later I just heard it lose pressure and now its dead...Does anyone out there know where I can get a pair of these for a fair price and have a part #?? Should I just get 1 or 2? Will the dealer,UGH, be the only place to get them besides maybe a junk-yard? Trying to save some money but I do need it soon!!!! Thanks in advance....Kevin
- Mark
My Mom bought one of the first 98 ML's when they came out. Great vehicle at the time. She only drives 3k per year and has had few problems though both the gas gauge and trip odometer have recently stopped working over the past year. She really likes the ML otherwise and wants to see the new ML.
I have to say, after hearing the complaints from people, and knowing about the ML's poor reliability history, I see no reason to even consider a new one, unless you lease one at an attractive rate. I don't know how other M-B vehicles are doing, reliability wise, but so much for "Built Like No Other" or whatever their slogan they used to use 15 years ago. What a sad downfall for one of the most prestigious brands in the world.
In most vehicles, you always need to press the clutch button or forcibly maneuver the shifter between the zig-zag notches whenever you are shifting from NEUTRAL TO REVERSE. The ML does not seem to require this. Just a firm tap on the shifter and it can go from DRIVE to NEUTRAL to REVERSE!
I found this out as I was test driving. I inadvertantly up-tapped on the shifter thinking I was turning on the left-turn-indicator. And, guess what happened? The engine revved as the car got thrown into Neutral and then with a lurch stopped as it went into Reverse. Thankfully, the vehicle was only at 5mph so nothing else happened. During all this time, my foot was neither on the brake nor on the accelerator.
Does this describe a true situation with the current MLs or did I miss something?
What might have happened is that you bumped the shifter from D to R and the system decided going into N was Okay. Then when you braked to a stop, it decided R was Okay since you were stopped with presumably your foot on the brake.
I'm not a fan of these shifters either, but they're here to stay and I suspect you'd adapt to them. With the computers running things, I doubt there is a safety issue, but I certainly haven't driven one to see for myself.
- Mark
Actually, MB considers anything up to about 1 qt/1K within normal bounds, although if you make a stink about it, they'll sometimes intervene before this. There are a lot of complaints about high oil consumption on this engine, although typically with the 98, 99, and 00 models. Some of this may be due to MB's bogus original recommendation to use conventional oil with the long change intervals recommended by the maintenance reminder system. This turned out to be bad idea and they settled a class action suit about this which gave owner's a 100K warranty. But by the 02 models, they were going with synthetic across the board so it's not applicable to your vehicle.
- Mark
If you buckle up before you start the car, it shouldn't make a noise at all.
Mark
So far... this suv is a big improvement over my wife's previous one (2002 RX300). There's LOTS more room and it drives very smoothly with a powerful oomph. No complaints so far. I am crossing my fingers that this SUV will be as rock-solid reliability-wise as the Lexus......
Yes, as long as you are under 10 mph, the arrows on the shifter display allows you to shift to Park or Reverse even while the car is still moving. You don't need to have your foot on the brake to shift to Park or Reverse.
If you are in Park, you must step on the brake to shift.
You can also take the key out while the car is still moving. The automatic shifter will attempt to shift to park, but if the car is moving, all it does is grind the gears.
These are minor compared to problems with the transmission jerking me around with hard downshifts several times a day.
I'm in shock. For 3K I can buy a top-rated cell phone with cellular service for life!
I was willing to pay up to 1K for a dealer-installed phone with warranty, etc... but 3K..... I just cannot bring myself to writing that check for a cell phone.
Good luck, Mark
I just bought a used, "dealer-driven" 2005 ML500 (12k miles) around Christmas from a respectable MB dealer. During the test drive, there was a very loud squeaking from the Brakes (usually only when I was coming to a complete stop.). At first the dealer gave me the song & dance about "build up" from the car sitting, etc. But I insisted on a brake inspection as part of the sale.
The dealer inspected front & back pads/rotors and said "there was some scoring, but overall looked okay". But they offered to change the front pads/rotors for free in good faith, leaving the back as-is. Things were great for about 2 days, but now the consistent loud squeaking is back.
We've gone about 500 miles since then and nothing had changed. I've tried car washes to clean the wheels, no luck. If this had been my old SUV, I would have sworn it was metal on metal sound of pads on a rotor. But overall the ML500 brakes great and I never hear the noise when just slowing down.
Since this is my first ML500, is this normal?!? While my MB dealer tells me everything looks good, I've never heard any SUV ALWAYS SQUEAK SO LOUDLY when coming to a complete stop. Do I need a second opinion? Any suggestions would be greatly appreciated!
Sam
Chicago, IL
If you can get them to agree that the squeal is excessive, then you'll probably have little issue in getting them to take things apart and see if all the squeal reduction measures are in place.
Or you can learn to live with it. It may go away on it's own. Pretty much up to you whether you want to go to the matt on an issue that is annoying but probably not serious.
- Mark
I have the same problem in my ML 320. I had Midas and BrakeMax check the rotors and break pads and both told me I have about 50-60% of pads left on the front wheels and about 70-80% on the rear. Sometimes the squeals or squeaks maybe due to the hot weather (I live in AZ) - BTW am going to see if my dealer can do something about it. I doubt it, but hey there's no harm in trying.
Your answers are awaiting you at ==> http://www.carbuyingtips.com
This website is incredible and I don't want to spoil it for you, but you will learn all the tricks of the trade and how not to get ripped off as well as buy your new ML at invoice or even below invoice....make sure you are aware of the dealer holdback and any incentives currently being offered by MB - I hope that helps...let's know how you fare.
Good Luck.....
Any cons or pro between 320/500 or MDX.
What should I pay for these vehicle.
I am seeing the prices ranging from $20K to $25K, 38K to 55K miles on them.
Also which is the best Extended warranty available for these vehicles should i get that too and what should i pay for it.
I am in chicago mkt and looking on Ebay and some local dealers.
thanks.
Don't go older than a 2002 ML; the 2002's received the mid-model-cycle update and it was significant (e.g. side curtain airbags).
Also, I forgot if the 2003 MDX's had side curtain airbags or not. They definitely weren't there for 2001 and 2002.
I will be buying 2002 ML500 soon with ~45K miles. Can I get them from online or should I go with Dealer offered warranties.
i have a 2003 ml500. its really something - my dealer had also told me that i should get my brakes done at 24000 miles. i took the tires off, they still have alot of life left on the pads.
the problem i have is that the tires have alot of uneven wear, they already did alignments 3 times. they tell me the struts are fine. on these trucks tires only last around 15000 miles.
i can't blv this. any ideas?
another problem - alot of times ithe car would not start. i put the keyy in, turn it, nothing hpns. i turn it back and the car stoats fine.
thanks.
The Mercedes place told me that same thing about my brakes and tried to replace my front brakes at 26,000 miles, I said no. I figured that's why there is a brake pad warning light. The dealership fooled me at 18,000 miles to replace the back pads. I was getting ready to go out of town on a driving trip so I let them change the pads.
I drove the ML to about 44,000 on the original front pads (if I recall correctly) which gave me about 26,000 on the rear pads. I really believe the rear pads were fine at 18,000 miles. The brake light never came on. Since my local Mercedes shop tried to get me to replace my brakes to "profit-line" their pockets, I took the ML to a private shop and saved about $300 on a brake job. ($1,100, new rotors, pads, bleed and replace brake fluid, rotate tires)
The only complaint that I had with my ML was it just rode so rough. I would have considered the new smoother-riding ML but they didn't offer a third seat anymore. Mercedes wants the customer to move up to the R-class which looks like a Pacifica van to me, and, at $70,000?
The new Land Rover LR3 will seat seven and the rear area is huge! Also, the third seats fold completely flat and the ride is very nice.
I think I was rather lucky with my ML500, as it had very few issues, just a couple of plastic pieces (rear cup holder broke, front plastic trim came loose). I did have uneven tire wear and probably was my fault as I didn't get an alignment for a longtime because I had no pulling and the vehicle drove straight as an arrow down the freeway. I had wear on the inside of the front tires. After I got the new tires at 38,000, I got regular alignments.
Mark
I was looking for feedback on the ML55 when I saw your brake problems.
Porterfield Racing brakes in Costa Mesa, Ca. has a full line of Carbon Kevlar brake pads. I have them full around on my 4runner. They are nearly dust free, quiet, rotor friendly, and have almost no heat fade period. They were designed for racing, but they have street compounds. They have a website, check them out.
Gary.
The last 5 years the MB cars I have owned and driven and their many problems:
1. SLK230 2000 model - I bought this car brand new, after some months, some 10k miles the Supercharger started to miss-time, the convertible wouldn't close properly, the transmission started to slip and miss-time and cause abrupt shifting. NOTE: ALL MB cars have a transmission problem, bear with me I will reveal this here
2. ML320 2002 model: this is my wife's car, endless problems, Power steering failure three times, many different sensors mal function, ABS failure twice, transmission failure and had to be replaced at 48k miles. NOTE: the replacement transmission had the same original problem of abrupt down shifting, evident in most benz models. My last visit to the dealer the car was in the shop for a whole emonth, at Smythe European in San Jose, CA. The list was so long, the also changed the catlytic Convertor it was cracked. Everytime I got the vehicle back something esle was broken. During this one month that my ML320 was in, I drove three loaner cars, next I explain my driving experience with the three loaner cars.
3. Camry, loaner on week 1, great car, what can I say, we are dumb suckers for german Style, we are all bluffed. It is amazing. Smyth European of san Jose CA didnt have an MB to give out as a loaner, and everyone was really pissed at them. Anyhow, after a week, I came in to pickup my car for the original repairs, and saw the ABS light all on (not part of the original problem that the car was taken into the shop), next they gave me and ML350.
4. For another week I wan in the ML350, this car was 2004 model, and it too had porblems with Transmission down shifting and abruptly shifting, MB will bluff you and say that this is normal, but to all the owners out there please be careful, and ask your MB dealr, to drain the transmission and see if there is graphite sludge because that is what they found with my car (the ML320 above) and they had to replace it. In my opinion the ML350, suposedly a better car than the ML320, also had the same transmission problems, if the downshifting is abrupt it just goes to show how weak of a tansmission design it is. At this point I was thinking maybe it is just me (well I know it is not). The dealer Smythe European called me and said they have to urgently come in and pickup the ML350 loaner, because it was sold and it was not supposed to have been loaned out, man I feel sorry for the guy that bought it, I had put some miles on it. Anyhow they (smyth european) came and brought a brand new (5k miles on it) E350, and took the ML350. For the next 2 weeks I was in the E350.
5. E350 a real nice car, smoother and well performant, BUT it too had transmission abrupt downshifting and abrupt up shifting, although the problem is more prevelant in the downshifting. You can test this on your car, let say you have been driving for sometime on a highway and then you take your exist, and then slow down, say come to a traffic light and then you slow to a stop, lsiten in to the abrupt downshift, you feel the gears down shift and then you have to "extra-apply" the brakes. You have to test this when the car is normal operating hot temprature. This down shift indcates a failure in the transmission. This e-class shouldn't have this problem it is a brand new car, but of course the transmission on these vehicles is faulty and hence the downshifting.
Anyhow, after a week of driving the e-class the dealer calls me and says my car is ready, I come in and they say there was a leaking oil to tansmission connector, they fixed it and fixed the abs lights, then I take the car and the abs lights are still on. So I am back in the e-class (E350 loaner) for another week, then I call them and ask them to look into the downshift, they call me back 3 days later and said we replaced the tansmission with a re-manufactured one, ie the casing is old, but the parts are new. I took delivery of the car (ML320) and guess what, I have more downshifting problems than in the past, and I complained to the dealer and they said we cant see anyhting wrong with it, I am secheduled to have an independent look into this.
Mercedes benz, knows there is a real design fault with their transmission particulalry with ML and e-class, SLK. Note ML and E class are basically the same platform cars. However they shy away from making the offical announcement, you will drive it, and all the sudden at 51k the transmission goes out and guess what you will be left out in the cold. I can go on forever, I am angry and dissapointed at MB, it is a waste of money. When I was waiting for my car at the dealer (Smythe European of San Jose CA) I saw so many people come in, complain about sensor problems, one guy had an S class and the adviser said, oh it must be the water pressure cleaner caused some water to get into the sensor of the catylitic convertor, and we have just reset the computer and ignore the sensor warning. I guess another trick, how can they just ignore sensor warning, maybe they just didnt want to replace yet another Catalytic convertor.
There is more to report, but I am fed up of writing, mark my word, you are bluffed into paying for a MB.
PS ML320 98 97K miles..Had rear rotors and pads changed at 80k miles
- Mark
My 2000 E430 has been a very good trouble free car in the 6.5 years that I have owned it (bought new).
Granted, Mercedes-Benz have had their share of glitches, etc. but many owners have good cars. A friend of mine bought a used Mercedes SLK 320 and it runs like a champ. The top works perfectly as does the transmission.
Good luck in the future in whatever you decide to drive. Mark
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Keit.
Note that I stated "mechanically". The trim and body problems have been way more problematic. The black trim on the doors have been replaced several times, the black glass trim around the hatch replaced, the steering wheel replaced due to the leather flaking off, the struts for the back hatch replaced, and now the roof rack is starting to peel it's outer layer.
Since it been mechanically trouble-free, we're keeping ours until the wheel fall off, which will probably be many years down the road. Oil changes are still running at about 12k miles or so, and it will probably need it's 3rd set of tires in another 15k miles, so the upkeep costs are very low at this point. :shades:
Generally, I like to keep cars up to about 50,000 miles then trade.
Mark
Mark
Thanks, Pres. Bush!
How soon we forget. My last mercedes, a 1997 E320, was the deathnail to my relationship with mercedes benz. At 61,000, the car was BLOWING OIL out of the front main seal all over my garage floor. When I went back to HBL, Tysons, VA, the service advisor informed me someone must have put too much oil in the crankcase. The problem? They had just performed my 60K service($1800) less than 2 weeks prior, which included $500 for a mass air flow sensor, which had also "FAILED" at the 60K mark. I took the car to an independent shop and for a very reasonable $250 they replaced the main seal, which MBZ refused to rectify because the car was out of warranty.
Unlike many others here, I did not let this experience send me across the Pacific to the land of the rising sun. Instead I bought my first BMW. After 9 years, I traded this car in on an 06 BMW. The 1997 BMW still had the original headlights, brakelights, window motors, and AC compressor, ALL sensors, etc. So much for the urban myth of BMW's and electrical problems. I did nothing but put gas and brakes in this car for 9 years.
Now I am not saying BMW's are perfect. I am well aware of the nickasil blocks and the ZF transmission problems, but ask anyone who experienced those unfortunate incidents back in the 90's, and see how they were treated by BMW. New entire engines and transmissions installed by BMW at no cost to the customer. Why? Because BMW evidently still looks at a customer as a lifelong relationship. But it has been my experience, that instead of trying to build 15 different models and move 15 million units worldwide, they have concentrated on getting the small things right, and their marketshare and profitability have been rewarded as a result.
Just my experience over the last 20 years...
