Somewhere around a 48 Chevy Woodie because I think vehicles required two tail lights somewhere around 1949?
close on the wagon. Based on the source ad, it is a '51 "Tin Woodie"
Hint: This is a USA model truck.
Hint @2: The actual name of the truck is (make + two other words) and one of those other words isn't "pickup" or "truck".
And none of that "search google for this image" nonsense. Spyware is monitoring your every keystroke.
@stickguy -- no, Cameo is not in the name but you're on the right track.
I suspect this is not the right description, but when the Utility was first invented by Ford in Australia in 1934, it was sold as a Coupe Utility
Cheers
Graham
I haven't a clue what the model name is but I'm pretty sure the photo is of a scale model (1/24? 1`/18?).
These are actually so rare in their GMC form, that it's hard to find an actual photo of one. I actually know of a real one near me, so maybe I'll post a picture of it later.
When you're all ready to surrender, let me know.....maybe this will motivate you....
Yes, the GMC Suburban Carrier was the equivalent of the Cameo. The one I know about is the even rarer 1958 model, which for collectors is actually not the most popular for either the Cameo or Carrier.
These are historically significant vehicles, as they are the precursors of the "upscale" pickup and SUV, and the idea of the flat-sided PU truck.
-How could anyone design something so ugly?
-I wonder if those strange shapes above the windshield served any purpose (HVAC vents?)
The '58 eliminated them and the "scoops" above the headlights. It was pretty rare for any '58 to look better than it's '57 predecessor but I'd say the Mercs did (a little anyway).>
Doubtful, I think. My Dad's '64 Catalina had 13 inchers.
I always wondered how far in advance the auto makers knew that quad headlights were coming. Chrysler, apparently, got the memo, as all of their '57 cars were designed to accept either 2 or 4 headlights...even if Plymouth and Dodge didn't actually offer them, instead going for a fake-out look with the turn signal mounted where a headlight would normally be.
Oddly, I always thought the '57 Ford looked like it was ready for quad lights. The fenders seemed wide enough to accept them. But, they only went with single headlights, which seemed to jut out a bit too far, giving the car a bug-eyed look.
I always thought the '57 Mercury was the ugliest car among its peers (Buick, Olds, Chrysler, DeSoto...in the past, Mercury had been cheaper, more of a Pontiac/Dodge class of car, but this year it moved upscale to clear some room for Edsel). But, in many ways, I think it predicted the 60's car better than Mopar or GM did. The GM and Mopar cars were more rounded off, whereas I find the Mercury to be pretty squared-off, and blocky. Trim off some of that excess styling, and you pretty much have the more conservative, squared-off blockiness that started to show up in the 60's.
And yeah, I thought '58 was definitely an improvement, although still not a very attractive car. Interestingly, this year, Olds and Buick went for a more blocky look as well, so I guess the Merc did have some influence. And for '59, the Chrysler and DeSoto seemed a bit more squared off, especially up front.
A cheap car, but still.
Ford stopped making the Pop in the spring of 1959 and Austin / Morris launched the Mini at the end of August, changing small cars for ever - until the various small hatchbacks surpassed it later...
G'day
You are definitely dredging the low life. Without looking under the bonnet, I cannot tell if it is a Standard Eight or Standard Ten, from about 1953 to 1960. They were an unlovely car which reaked of post-war British austerity. The early Eights has sliding windows and the boot was accessed through the rear seat as there was no boot lid. A review from the Melbourne Argus of 17 February 1954 gives something of the flavour;
"PRODUCTION economies in the new Standard Eight, above, nowhere interfere with efficiency or comfort, and most of them will not be noticed by the non-technical, says John Williams, ''The Argus" motoring expert.
Mechanically there is nothing to remind one that the car is severely competitive In price, he says. 'In Britain the Standard is the lowest-price four-door eight, because of the omission of a number of, features as standard equipment. Here it occupies second place by a narrow margin, but some items which are extras in Britain are standard specification here.
These include plated hub covers, twin wipers, sun visor, twin ash trays in front, roof light, bon-net mascot, underspraying of chassis and extra :dustproofing, oil – bath air-cleaner.
Body and chassis are of unitary construction, with the engine and front suspension carried on a detachable sub-frame.
Elimination of a separate door for the lug-gage compartment has certain definite advantages, such as positive dust and water exclusion, greater strength. The rear seat squabs are divided, so that access can be obtained without disturbing both rear passengers.
As a result the luggage accommodation is increased considerably with three passengers, and enormously If there are only two in the car, as the complete seat can then be folded forward as in a station wagon.
Spare ' and tools are always easily accessible in their own compartment, and little of the large front parcels shelf space is lost by installation of the specially designed radio which, of course, is an extra. This radio, incidentally, gave excellent results during the .road test, on stations many' hundreds of miles away.
The O.H.V. engine has7.4:1 compression, develops 26 b.h.p. at 4,500 r.p.m., and drives through a four-speed gearbox synchronised on three of its speeds.
Electric system is 12 volt, there is an oil filter, and the clutch is hydraulically controlled like the Vanguard.
Ignition timing is con-trolled both by governor and vacuum unit, and the car runs well on Australian fuel, although English high - octane grades would naturally be needed to realise its full performance.
Suspension is coil springs and tubular dampers in front, with half-elliptic leaf springs and piston-type dampers at the rear."
Managing to make the absence of a boot lid a positive is a real marketing talent!
Cheers
Graham
I suppose this is why the Jaguar XK120 was such a world-shocking event in the automotive arena. For something that lovely and fast to come out of a war-ravaged England was quite a surprise.
It would be interesting to park a '58 Triumph Ten next to a '58 Oldsmobile!
No boot lid! The spin on that one made me laugh.
Be sure to click to enlarge. Should be something for everyone.
is that a Ford Taunus wagon turning down the aisle?
