I have a 2006 Solara and yes it is diffenitly plug and play so somethings wrong hopefully they can help you out
Marc
I mounted the camera on the vinyl bumper cover behind the license plate. I cut out the "C" in Michigan at the top of the license plate and have the camera looking through the hole.
I made a small clamp-on aluminum bracket to minimize hacking on the car.
The installation is nearly invisible--you have to be looking for the camera to see it.
I found that a tiny tab added to the top of the license plate bracket eliminated a bit of fogginess at night, coming from the license plate light. (A bit of electrical tape on the light lens would have been nearly as effective.)
Routine car washes has kept the lens clean and it has required no additional attention.
I hope that your experience with the camera has been as good as mine!
Which camera are you using? Thanks for the info...
ciao,
Marc
I have never used the camera to align a trailer hitch, but would expect it to be extremely effective if it is mounted behind or near the license plate.
I have been impressed by the width of the field. As you back up to another vehicle parking, you can see the complete front end until you are within a couple of feet of it. If you can't see it all, stop!
Best of Luck--Bill
I have intention to install on the back bumper of my car a sensor that detects the obstacles; the last time I was reversing I did 250 $ of damage, therefore sailing on internet I found two typologies of sensor: one with four ultrasonic transducers, and another with only an aluminium tape. Owing to the fact that I have not intention to do holes on my bumper I would prefer the second invisible solution. For this reason I wish ask first a your opinion.
Here is the link of the producer: http://www.proxel.com
Waiting for anybody who can give me an answer.
Bye!
What about that neighbor kid?
And the distance it shows is awful tight.
80cm is less than 3 feet.
You might take a look at this one.
obstaclesensor
It is a license plate frame unit that mounts easily.
At 6' distance, the sensor will be active in a 6' area.
Most of our drivers like the Smart Alarm SA917, because it tones down in quiet areas.
And they have a lifetime warranty.
And I want to buy the wireless parking aid for my brother.
The carsda guy said currently the wireless parking sensor systems is with a wireless display, that is, there is no wiring between the display and the control unit. much easier to install .
But i am afraid that is it able to work as well as the common ones?
Anybody has the experience ,please tell me . thanks !
I purchased a ear view mirror last year from here: http://www.espow.com/wholesale-car-electronics-parking-sensors.html and installed in 4Sstore. It is also working perfect now. Did help me a lot when reversing.
really it makes me a little bit uncomfortable, sometimes i want to change a new one with night vision, like my neighbour's. but maybe i should better resist myself on this, after all, it's not a good thing to build up a reliance on these digital ears or eyes.
