How much does maintenance on a 2004 Audi A6 2.7T S-Line cost?
I recently purchased a 2004 Audi A6 2.7T S-Line and the 75K mile maintenance is coming up. Anyone know the approximate cost? Nearest Audi dealership is in the Twin Cities, MN as I refuse to go to the dealership in Sioux Falls, SD.
Last time I went in for an oil change, they inspected my car and found that the oil valves in the engine are leaking. Anyone know the cost of that as well?
Any help and input is appreciated! Thanks in advance!!
Best Answer
brian125
Member Posts: 5,244
Call the Audi dealerships service dept. Ask them what the 75k or 80k mile maintenance Consist of ? How much that service cost ? With the assumption they find no other problems. Then go to a reputable mechanic shop in your area and have them do the work. You will save more than half the money spend over at Audi.
Another thing you could do is have Audi inspect your car. If they find a lot of problems have them give you a written price quote then take it to a reputable mechanic shop probably for half the price. Simple tell the dealership money is tight right now you will decide if you can do the repairs sometime soon.
Good luck23 Telluride SX-P X-Line, 23 Camry XSE
5
Answers
Apply the same for that 80k
We have a disconnect somewhere since the Guide's numbers are way less than Shifty's quote.
Going by what we say, it looks like the 75k service is just a tire rotation (~$20). The 80k service is a major one - the Edmunds Car Maintenance Guide estimates that should cost you around $360.
By all means, shop around.
Someone else will have to weigh in on the oil valves.
