About the Maintenance and Repair Message Board
1246789
  • guitarzanguitarzan Member Posts: 873
    Well, I am not too familiar with pumps. However, I suspect if the pump goes bad, it might seize up. In which case, you can try to turn it manually with your hand and it won't move. Now if any of the belt driven devices on your car seize up, the belt could certainly be damaged.
    We all feel so dependent on mechanics, and many times afraid to ask follow ups. However, when they tell us that something is wrong, we should get into the habit of saying, "please show me."
    guitarzan
    Community Leader/Vans Conference
  • gusgus Member Posts: 254
    By the same token, mechanics should make it a habit of either offering to show a customer what's wrong, or just showing the customer what's wrong. I believe that many states require shops to keep a customer's old parts on hand until the customer comes to pick up the car, so the "please show me" option that guitarzan is speaking of is always open to the customer.
    If you sell it without doing that repair, you're going to have to sell it for less than its book value. This is especially so if the repair is what's prompting you to sell the car in the first place.
  • fairgerfairger Member Posts: 3
    Gee, Gus, I know that. We were going to get a new car this year anyway. I just wasn't sure if anyone would even want it. I don't know what my alternatives are. Salvage yard? Who would I get an unbiased opinion from? The car still rides great and everything in the interior of the car is in great condition. Are you familiar with the front power take off shaft problem? Is it something that is going to be fixed and stay fixed? Thanks for you input. Ger
    Well, it's good that you know that. In no way was I trying to be patronizing, I just wanted to make that fact perfectly clear. You'd be surprised at how many people want to sell a car (unload it) for book value without acknowledging that there's anything wrong with it. In fact, sometimes the diagnosis of a big-ticket item is the reason they want to sell it in the first place.
    Those propeller shafts don't go bad all that often. It's just your poor luck that it happened on your van. Will a replacement part stay fixed? Who knows? Here's a hokey analogy: Will the lightbulb you put in your lamp last night keep working for the next week? You surely hope so, but there's no way of knowing. If you buy a quality part for your van and have a trusted technician put it in, that's all you can really do, isn't it? It shouldn't fail, but there's always a slight chance that it will.
    Okay, I realize that also but, I guess my real question is , Is it worth it to fix this part on a car with 170,000 miles on it to sell it? Do you think I could get any kind of tradein if I did not fix it? Thanks, again. Ger
  • darylwdarylw Member Posts: 1
    Does anybody have any suggestions on a 1996 Jeep Grand Cherokee Laredo that vibrates at 70 to 75 miles per hour (stops vibrating before 70 or after 80) and could possibly have to do with the rear transfer case. Jeep has already put on a new rear transfer case, but the problem is still there.
  • acorn1acorn1 Member Posts: 6
    Should I consider doing my own maintenance rather than pay a dealer to do it? The car is still under warranty for another two years, but I feel perfectly competent to change the oil and filters, check the drive belts and all the other little checks that are needed at each 6000 mile service.
    I don't like the thought of paying a dealer a hundred or so dollars for each service when the parts and oil only cost about $30. And I think I can do a better and more careful job than the dealers mechanics. On the last service, my dealer overfilled the auto transmission.
    Will I still be able to claim any major faults under warranty if I do this type of maintenance myself? Have any of you done your own maintenance on a new car?
  • dlk9584dlk9584 Member Posts: 2
    I have a 1989 Pontiac Grand Am w/88,000 miles on it. Lately I've been hearing a noise coming from the engine, like spark knock, only louder. I don't hear it at idle or when decelerating, only on acceleration or cruise speed. I use 93 octane gas. Any ideas on the problem?
  • kschofieldkschofield Member Posts: 1
    I'm looking at purcahsing a 1992 diamante, however the suspension adjustment control is not working.
    any idea on how much this is to repair? Also I will need to do a brake job on it in abiut 10,000 miles...whats the cost average? this vehicle has 109000 miles on it...whats the life average??
  • dmcgradmcgra Member Posts: 1
    The valve adjustment on a tracker are they set screw adjusted ar are they shims?
  • jjru2byjjru2by Member Posts: 1
    How do you check the battery, starter, alternator to find out ,which one is not working.1992 dodge gr.caravan 3.3.engine.
  • dandekarvdandekarv Member Posts: 3
    I had a problem with Ford Aerostar van transmission and local xmission mechanic fixed it. He charged me $1500.00 and repaired it. It did not work right and in two weeks it failed. I went to aamco to get it fixed. they completely rebuilt my transmission. Charged me $2200.00. Did not help me in any way to sue the first mechanic. I won the case but court did not award me all the money I spent to aamco. The court said aamco did an unnecessary repair and changed a lot of unnecessary parts. Within one year my xmission went bad again. just one month after the warenty.
    Of course they did not fix it under warenty and completely rebuilt the xmission again cost me $2400.00. Can any body tell me if it is usual or aamco chitted me? I tried to resolve this with their consumer relation department but did not work.
    My MBZ 190E2.3 is getting hot. How do you check what is wrong in the coolant system? I changed thermostat, fan switch, fan clutch (magnet) did not help. Any suggestion?
  • joelejoele Member Posts: 6
    I have a 85 Accord with 113, 000 miles and everytime when I change the oil and oil filter,I notice that in order for the dipstick to reach the appropriate level (between H and L), I would need to add 5 and a half quarts of oil. Is this normal? I don't want to overflow my engine since my understanding is that for these smaller cars with 4 cylinders, 4 quarts would be sufficient. Any comments or suggestions would be greatly appreciated! Thanks!
    we have a 88 accord and we use only 4 qts of oil.
    have u rebuilt the engine lately.
  • majordan1majordan1 Member Posts: 1
    There is about 2-3 inches of play in the steering wheel of my KIA SPORTAGE. Can you tell me how I can fix this problem myself?
  • beaterbeater Member Posts: 16
    I just bought a '99 Mercury Marquis and purchased an extended service plan from Ford for 6 years/100,000 miles for $1200. I can cancel anytime during the next 55 days and get all but $50 refunded. I just got the paperwork on the extended service plan in the mail. It has a few clauses which make me nervous. One is that I am required to perform all the recommended maintenance in the service guide. That's a lot of trips to the dealer or other service source and a lot of money. Also, they don't pay for the failure of a covered part caused by the failure of a non-covered part. That's one of those clauses that's open to interpretation. They also don't pay for failures caused by loss of fluids. That's another clause that worries me. Am I being overly paranoid? Has anybody had personal experience with Ford's extended service that can put my mind to rest? I originally bought the plan because previous vehicles always managed to rack up one or two big repair bills about year 4 or 5 and I always said "I wish I had bought extended service- it would have paid for itself". Now, I'm not so sure I won't end up paying a lot for the plan and still get nicked by the repair shop. I've got about 55 days to decide. I'd appreciate any input.
  • cbloomcbloom Member Posts: 1
    I am looking at invoice prices for a dodge car.
    I am curious if the sticker price says manufacture discount on package involved then there is no cost to the consumer for that item.
    When negotiating does the dealer start the sticker price at the original price or the discount price for negotiation.
    Also if the invoice pricing from edmunds also shows the discount from manufacture at zero do you figure your invocing pricing without that packages costs being figured in.
    Does the dealers invoice reflect the discount on packages or is that added in.
    If anyone can help explain this to me I would appreciate any help before I get ready to buy a new car.
    Cbloom
  • mznmzn Member Posts: 727
    Cbloom, you may want to visit our Smart Shopper conference for additional information. Our car purchase conversation is concentrated in that conference.
    Just use the Conferences Drop Down Menu on the left, select Smart Shopper and go!
    carlady/roving host
  • b727jkb727jk Member Posts: 1
    On my 1987 Nissan Pulsar I have 172,000 miles with realive new Cat converter, PVC valve, Oxygen Sensor, EGR Valve, and the car still blows white smoke! It could not be the muffler even though it is three years old. There are no holes. Mufflers only muffle the sound right? Or is there some greater quality to Emissions. I found a Sensor valve that will not open on an idle suction line but it costs $86. Could I run a tee through this to leave these lines always open! The lines go to the emission fuel canister, the EGR and The AirFiller. Any insight is definitely appreciated.
  • bobs5bobs5 Member Posts: 557
    White smoke usually means there is coolant getting into the combustion chamber. I would suspect that a bad head gasket is the problem
  • dschroffdschroff Member Posts: 1
    I have a 93 explorer and it will not engage the 4x4 feature when i touch the appropriate button. Any suggestions or experience to engage the 4x4?
    Look for the fuse for the 4x4 system. It should be under the hood somewhere. My friend has a 91 explorer and it popped the fuse once.
  • hall2hall2 Member Posts: 40
    What is a propeller shaft? My owner manual says to inspect and lube the propeller shaft (4X4 truck). Where is it located?
  • oldjunkloveroldjunklover Member Posts: 7
    I don't keep up with these conferences religiously, but I was browsing here, and I notice a conspicuous lack of posts from Mr_Shiftright. Is he gone!!!
    Where oh where has Mr_Shiftright gone?
    Oh where oh where could he be?
    With his posts cut short and the time way to long,
  • hywyhywy Member Posts: 4
    Hi all! If you have (or had) any of these vehicles or engine - please, please PLEASE! let me know your maintenance experience...
    MazdaB2600 p/up - years 86 to 89, Dodge Raider Jeep - years 85 to 89, Dodge D50 p/up's - years 86 to 89, Mitsubishi p/up's - years 86 to 89.
    stick shift, 4x4 and or automatic.
    The engine in these vehicles is a G54B from Japan, 2.6 liter,with hydraulic lifters, 13 1/4 " bell housing and no jet valves. I need to know your overheating specs. Did the engine go after ?? miles? How many times did it go to the shop? Did your head keep overheating. Any of the above or anything else. thank you all so much
    hywy
    Mr. S hosts the Classic Car Conference and posts here occasionally. He is a busy dude away from Edmunds, too!
  • fjeganfjegan Member Posts: 2
    I just purchased a new HONDA ACCORD V-6 and have noticed that when I reach around 50 mph, there seems to be a slight engine miss, which I don't notice at lower speeds. The dealer indicates that I just need to give it some time-a break-in period and he'll check again at the first 3,000.
    Anyone else experience a miss at speeds above 50?
    thanks-jack
  • pegronpegron Member Posts: 1
    I have a vibration in the front that feels like a tire out of balance. We have replaced the tires 3 times, checked wheels and still have vibration. Buick Engineering hasn't come up with solution yet.
    Buick engineering reports that some of the 1995-1997 Park Avenues have this problem. Anyone else experiencing similar problems ??
  • nattanatta Member Posts: 9
    I have a 94 thunderbird lx with the 4.8 liter
    engine and today I was going to go to work and it
    seems to be hesitating when accelerating ,almost like a timing problem, now I recently put a full tank of crown corp gas in it and I heard some bad things about the gas . Can this gas be the problem ,I never had any problems until I got this gas.
    4.6 liter engine not 4.8
  • 420park420park Member Posts: 5
    I have a 90 Accord LX Auto with 131K miles.
    If I take a short trip while the car is still cold (outside temp 30 F or colder) the transmission indicator on the dash will not show the car is in park after I have shifted it back into park. The dash indicator doesn't show any position being selected, for that matter.
    It appears that the transmission is actually in park since the car will not move. In this "limbo" state I am also unable to shift the car out of "park". After I wait a few minutes, the Park indicator lights up. I can then shift.
    This does not happen after the car has warmed up.
    I first noticed this last winter, and then again yesterday when we had our first cold day. The transmission does not exhibit any other problems.
    Any suggestions?
  • ardateardate Member Posts: 1
    Hi there:
    We just bought a 1991 Festiva with 129,000 km (80,000 miles). Very well maintained vehicle. Yesterday though, when the car was put in reverse and backed out of the garage, there was a clicking - ratcheting noise. The noise is produced only when the car is in reverse and whether or not the engine is running, that is coasting down the driveway. Any advice ?
  • edsissonedsisson Member Posts: 1
    I just bought a 99 Buick regal with the supercharged engine. The owners manual says the engine require premium unleaded fuel. Maintenance people at the local dealer say it's OK to use regular unleaded. in fact, they say "Under no circumstances should you use premium unleaded in cold weather (Ilive in Alaska)because it causes major jelling problems inside the engine.
    The warranty statement indicates the warranty can be voided for using non-recommended (regular) fuel. The Buick customer relations department is no help. They say consult the dealer.
    Does anyone have any information on this subject?
    I would go by what the manual states.
    "Premium unleaded fuel"
    Don't risk voiding the warranty.
    Never heard of jelling with gasoline, I have heard diesel fuel will jell.
  • rs_pettyrs_petty Member Posts: 423
    Has anyone designed a good spreadsheet that can be printed out that puts required maintenance schedules on 1 page. I keep track of all kinds of things down to when wiper blades get changed/tire rotations, etc... I built one for 3000 mile oil changes, but now I'm doing 7500 mile changes and before I redesign thought I'd see if somebody else had a good idea. Thanks.
    To me it doesn't pass the common sense test that hi-test would jell when regular wouldn't. If you use a major brand e-mail them and ask, heck ask them whether you use it or not. I doubt your car will run correctly on regular. The SC needs the extra octane.
  • waschwegwaschweg Member Posts: 2
    I have a 1994 Plymouth Sundance with 82,000 miles on the 2.2L 4-cylinder engine and a 5 speed stick shift. It has been very reliable until now.
    5th gear is bad and needs to be replaced. The car has been at the dealer since the middle of October. Chrysler does not have the part available anywhere in the US. I have been told that it would be manufactured and shipped on four different dates. The latest expected ship date is in the middle of December. After many phone calls to Chrysler's consumer line, Chrysler covered a rental car for a week and a half but then stopped because the part was taking too long. Both Chrysler and the dealer said that I should not expect them to keep parts for such an old (6 years) car. The dealer said it would install an after-market or a used part if I find one and take it to the shop. It would not help me find one. If I did this, there would be absolutely no guarantee on any of the work done. I have been unable to locate any replacement part. Several friends have told me that auto makers are required by federal law to have on hand parts for cars 10 years after the manufacture date, but I have not been able to verify this. Do such a law exist? If so, how can I find out more about it? Do I have any recourse? Does anybody have any information to help me get the car fixed?
  • ganggang Member Posts: 16
    I have a 94 Nissan Sentra LE with 86K miles. During the past 7000 miles after I bought the car from the previous owner, I have kept topping off
    the power steering fluid every 300 miles. I thought there might be some minor leaking somewhere. And I never feel the steering is heavy!
    Yesterday I brought the car to a mechanic for a checkup. He told me a clamp was deformed, and he had fixed it. Today I crawled underneath the
    car, and found out that on the right side of the power steering gear assembly, the clamp close to the center end is missing, and the boot is
    wide open at the end. No wonder there has been fluid leaking, and the situation must have been so for quite a while. So the mechanic was
    lying to me (or even worse) although he didn't charge me on this.
    A while ago today I just called Midas. A mechanic on the phone said that, based on what I described to him, there might be some damage to the assembly. So he will probably have to replace the whole assembly with a labor of 4-7 hours at an hourly rate of $65 plus parts! It sounds
    so horrifying that I am thinking to abandon the car since it has given me so many troubles (A/C, CV boot, starter, oil leaking from the oil pan
    gasket, etc.) during the past year. Do you think what the Midas mechanic diagnosed is reasonable? Since I have not felt heavy of the steering
    yet, can I still drive the car by keeping adding fluid? Do I really need to replace the whole assembly instead of just fixing the torn-open
    boot? Does it really need that long time of labor to replace the assembly? Thank you very much for your advice.
    Gang
    The power steering rack on a car should not be leaking fluid. If yours is, then yes, you need to replace it because it is bad.
    I once had to replace a rack on a Nissan Pulsar, and it was a 5 hour job. The power steering racks on some front wheel drive cars are jammed into the front of the car, almost as though the car had been built around the rack!!
    Get a second, even a third opinion. Think about going to somebody besides Midas. They're cheap(er), yes, and they have a warranty, but I believe the warranty is only on parts. If the rack goes bad again, under warranty, you may end up paying again for labor! You may also want to think about getting rid of the car.
  • bettajettabettajetta Member Posts: 2
    I have a 929 S that I put 120,000 miles on. The center console gear shift is extremely loose and when I took it to a transmission repair they told me to live with the problem because it would be too expensive to take apart and repair. Is this a serious problem...what should I do...the car also needs struts and rotors...is it time to give up on this faltering luxury car....HELP!!!!
  • lucky20lucky20 Member Posts: 35
    Get 2 or 3 other opinions about that trans. problem. Don't mention other opinions given you to any other shops. You might get a surprise.
    Struts & brakes can be considered normal maintenance at 120K
  • dobie110dobie110 Member Posts: 19
    I need some opinions on a car I'm looking at. I have an '86 celebrity wagon that I'd like to update and ran across what looks like a good buy. first I don't really need a car, the celeb. is a second car for back and forth to work, and just a winter car at that. anyway, I found a '94 olds cierra wagon that appears to be in great shape, the body is beautiful (not even door dings), no scratches, and the interior the same. and the asking price on the window at this used car dealer, only $2995. (the car books for around $7000.). o.k., now here's the glitch, it has 143000 miles on it. to look at it, you'd never know. I want to go test drive this car, and want to know if there is anything specifc anyone knows out there that I should look for. I'm not afraid of miles if the car was maintained properly, but am still skiddish. I know the basics as far as how a good engine should sound, and transmiission should feel, and know to check for bad racks on these cars, but anyone with ideas about trouble spots with this mileage, or anything else to be aware of, let me know please. P.S. It appears the car in my opinion was taken care of well, not only by the condition, but, it has mud guards on it, those stainless steel window drip guards on the top of the windows, and a custom ordered carpeted dash cover over the dash, and I don't believe it is covering anything, but I'll check. o.k., tell me your views and opinions.
    anyone have any ideas on the replacement costs of struts and rotors for the '91 929 mazda??
  • rjl621rjl621 Member Posts: 1
    I have a 91 Bonneville w/117,000 miles that was running great. I noticed the oil pressure gauge reading very low pressure. A new mechanic I was using said the timing chain (original) was going and messing up the oil pump.He changed the timing chain and oil pump for $700.00. The next day I drove at highway speeds for 50 miles and started hearing tapping when I stopped. The car was towed back to him and he said the car had a bearing problem - big repair- and recommended a new engine for $2,100. Since I never heard the bearing before, could he have done anything to cause the problem? He claims that before he did the work he took a manual oil pressure reading and found very low pressure.Another mechanic I trust said he works on these 3800 engines and doesn't remember EVER changing a timing chain. The car is in mint condition - book value $4,100 - but it's worth very little as is. I'm considering doing the engine replacement. Any advice woiuld be appreciated.
  • devserdevser Member Posts: 1
    Does anyone have any advice on replacing an engine on a 1989 Honda Civic Si. My old one is shot with 140,000 miles due to some bad problem detection advice from a dealership. On the internet, I have seen several companies that inport engines from Japan - Is this a reasonable option to pursuit? The car is in excellent shape otherwise. Any feedback is appreciated.
  • waddleswaddles Member Posts: 3
    Hi, I bought by car in July and I wanted to know if I needed to do anything special to it for the winter time. I live in Illinois so it gets pretty cold here. My last qestion is that I suppose to receive $350.00 for gas from the ford company and I never received it. What should I do? I've called the car dealer that I bought the car from and they keep telling me that the ford company is back up and busy and I'll get my check next month. This have been going on for two months now. What can I do?? Thank, and help please
  • jjackson43jjackson43 Member Posts: 27
    #201
    When your mechanic says "new" engine, does he mean a new one from General Motors and does the $2,100 price include installation..? Or is he getting a rebuild for some local shop..? Check on the warranty. I just purchased a new 350 (5.7)"crate" motor from a local Chev. dealer w/a 3 year 50K mile warranty for $1,800. I would seriously consider buying the motor yourself and having it delivered to a mechanic. Get the installation price w/you providing all needed parts, just rely on them for labor. Some shops won't do that, but you might try talking w/your mechanic about it, especially since he has just made a bundle on you with the labor of the new timing chain and oil pump.
    John
  • betsyo1betsyo1 Member Posts: 2
    I am looking for repair shop in Arlington/Ft. Worth, Texas.Do independent shops get all the info
    from the factory for repairs?
