I Don't Understand What My Mechanic is Saying
They may have had to damm near pull that engine to get to the hose.
A buddy of mine had to replace the clutch on his V-12 XKE once.
The price was STAGGERING but it was something like a 18 hour job at 85.00 per hour or whatever the rate was at the time.
Of course, he had to pay top dollar for the parts as well.
When he complained, the Service Manager told him " You should have thought about that when you decided you had to have a 12 cyl Jaguar"
Harsh words, and a poor bedside manner perhaps.
But oh so true!
You have to get some numbers down on paper with repair shops before the work begins...everyone has to be on the same page.
And I think some of the expense came from the " While we are in there..it's a good idea to change the ...."
And...yes, he SHOULD have thought about the cost of repairs when he bought the Jag. A fact he is well aware of now.
Today, he drives a Toyota truck!
Basically, exotic cars generally require exotic care -- isn't that part of their allure?
But, always get an estimate -- most places have to come in within 20% -- and don't hesitate to use that estimate to shop around.
Get on a telephone and shop around or tell the service manager that you think the price is too high and make them show you its basis before you authorize the work.
One place you can sometimes save money is by telling a dealer that you see no reason why you should pay retail for parts. Tell them, in no uncertain terms, that how they deal with you is a factor of your ever buying another one of their cars.
Finally, analyze the price in a cost benefit way and see if maybe the value isn't more than you assume. A $600 repair that will last 10 years isn't such a bad deal.
book on the net for automotive purposes. None to be found! You will have to buy one if you are
interested in finding out the aprox. labor times.
You are correct in assuming that a good mechanic
can beat the flat rate times. I just had a crank
seal & timing cover seal plus a water pump replaced in a 1992 Stanza XE flat rate was 10.5 hours for the seals & 2 hours on the pump. They had it all done that day. Supposedly the engine is to be removed, you know that didn't happen.
First, this guy is faster and smarter than most. He may have years of experience.
He has spent a TREMENDOUS amount in tools. He has bought the 100.00 tool that makes the job easier to do.
Now, on the other hand, if he runs into trouble, and the two hour job takes three, he still gets paid for two!
He can run into stripped bolts (by the do-it yourselfer who fixed it last time) or stubborn, rusted fasteners etc.
The flat rate books assume average times.
I just bought a used (92) camaro. It was overheating (I got a discount off the price because of it) and I took it to my mechanic as soon as I got it. Now, he replaced a few things (fan motor was dead, one or two sensors weren't working) and says he has it stable at 220-240 degrees. I have heard elsewhere that about 200 is the correct temperature for a camaro to run, but the mechanic said that 220-240 is not too much higher than normal. Does this sound right?
220-240 is MUCH lower than when it was overheating before BTW... The needle was pegged at over 300.
If you're not overflowing too much into the overflow tank, and the car isn't pinging or running badly, I'd say it's okay at 220+...you might take the precaution of having the radiator flow tested, and of changing the thermostat just as a maintenance item (do NOT remove it!).
Best test would be to climb a long steep hill on a hot day with the a/c on and see what the extreme is on your gauge...that way you'll know the worst possible case.
Kuching-
Now you know why this car has a worst depreciation in it's class. Both parts and labor are expensive on the air suspension, and nobody can guaranty that it will be done right. If you going to keep it, you have no choice but replace "bags". Just get as long parts and labor warranty for them as possible. As for me, I wouldn’t keep this car, no matter monetary losses I sustain. If you wife likes cushion ride, lease a new Continental for her and leave problems to somebody else.
Rotating the tires might not prove anything because all the tires are suspect.
Switching brands (and hence tread patterns)may be okay as long as the same pair of tires goes on each axle.
The axle ratio refers to the number of times the driveshaft or input shaft turns to get one revolution of the driven wheel.
For instance the 3.08 ratio you have means that (let's assume a rear wheel drive car here) the driveshaft has to turn 3.08 times for the rear wheel to turn once.
Which is better depends on what you want to do with the car. A higher numeric ratio is better for drag racing, but a lower numeric ratio is better for fuel economy.
Hope this helps.
Dave
Well, here's the story on that--of course, it CAN be rebuilt, but the success rate is not very high with rebuilds on these units, since the internal passages are very very tiny and the chances of cleaning them properly are not so good.
So waht your mechanic is saying is "Look, I don't want to take a chance on this not working and me wasting my time, so I'd rather you bought a new one and saved me the risk of working for nothing".
His/her position is reasonable, and unless he/she were quite expert and just rebuilt Accord carburators 8 hours a day, I'd say his/her chances of success are about 1 in 5.
RE: Repairs on minivan
This sounds like a classic case of a failure to communicate on both sides. They didn't hear from you, you didn't hear from them, so both parties just went for it. Actually, the timing belt repair cost sounds reasonable, and I don't know what seals were replaced, so the cost could be quite justifiable or not, depending on what they actually did. In some states, if you don't give verbal or written authorization, you get the job for free. Check the rules with your local District Attorney's Consumer Info Bureau.
This is a 1985 SAAB 900Turbo with 143K miles and a 5spd transmission.
The emission failed for NO at 15mph and was borderline at 25mph. CO and HC were OK.
The last tune up was at the 120K service and the car has been very driven little in the last three years.
How do I diagnose this? Do I need a new catalytic converter or will a good tune-up get me going? Anyone out there know what I'm looking at? $$$?
Thanks for any help,
Dan Glenn
However, a blocked converter can be an initial cause of this. Being blocked, it slows down the airflow through the engine, thus the engine runs rich. So have it looked at.
guitarzan
Community Leader/Vans Conference
catalytic converter is good and hot. Tests performed on cold cats will show failures.
letmetalk, I'm curious about something. You mention tests at 15 mph and 25 mph. Are your tests being performed at speed, or do you mean 1500 rpm and 2500 rpm?
gus
Conference Host
Reduced NO is also a main reason for reduced compression and the contradiction gasoline engines face -- inefficent combustion to reduce NO.
Most EGR valves operate when the engine has reached its operating temperature and when it is above idle. EGR valves can fail; the control sensors can fail, and the passages can become clogged.
I don't even know if your car has an EGR valve, but I assume it has some way to maintain combustion temperatures below that needed to form NO.
Summit Racing, has a rebuild kit for standard GM alternators. It used to be $12, or $24 with a new coil. Years ago I bought one, pulled alternator, rebuilt it using the explicit instructions enclosed, and put it back in. It takes 2 people to put it in, but it is a pretty simple job overall. Sure beats a $60 remanufactured one. And I'm a scaredy cat when it comes to touching mechanical stuff.
Guitarzan
dealer to have the passenger door hatch replaced.
Since the door was shut at the time, they had to take the passanger seat out to get at the door hatch. After they replaced the hatch, the dealer noticed that the now the 2-wheel drive and 4-wheel drive lights were flashing and the windows nolonger worked. They told me that the "Gem" computer module went out and it would have to be replaced. Could they have shorted something out? This seems like too much of a coincidence to me? any thoughts out there?
Harry
on the SRS light the other day. The dealership mechanic indicated that there was an "open circuit in the clock spring assembly" - a short in the SRS wiring, as well as the battery needing to be replaced.
The car has 45k on it, out of warranty by 9k. Even so, this seems like a repair the dealership should honor, as it's obviously a defect and not wear-and-tear (in serious safety equipment, no less).
On top of all this, the dealership has suggested replacing brake pads (just pads for $300!?) and replacing the battery (for $103). The replacement of the "clock spring assembly" would cost $230. Their prices seem like a serious gouge.
Any suggestions on getting this fixed out of warranty or should we just grimace and pay it?
(the battery and brakes I'll do myself for a whopping $100 or less... they're crazy)
Thanks muchly - pixelation
It is the rubber part that wears out, particularly if the part is designed wrong and the rubber is under too heavy of a load. If you live in Arizona, then the heat also takes it's toll on rubber parts. Age is also a factor, as the rubber degrades over time.
It is not unusual for this part to require replacing after 80,000 miles and ten years. There is nothing wrong with your FORD, I had to replace the engine mounts on my Porsche at 100,000 miles, too.
Bruce
That just seems wrong to me. *sigh*
Thanks for the suggestions.
I replaced the wheels on my brand new Impala. I told the "boys" I was selling my wheels to a friend and to put them in the boxes the replacement wheels came in. They did this. But, as I watched through a window, they went around the car and collected each and every nut from the original wheels and threw them in a box. I had to purchase new nuts to go with the new wheels, but they fully intended NOT to give me the original nuts. Hello?? I just said I was selling the old wheels to someone else, might that person not have need of those nuts??? 'uh.. sure lady..." They gave me the nuts.. but when I got home I noticed I was one short.. Oh well.
For those who are REALLY paranoid....how would you know those really came from YOUR car?
If you think the shop is out to cheat you, you seriously need to find another shop or else do your own work!
