Visitor Agreement.
might go for cheapest restoration you can get.
Because it is a low mileage car so called 'hard
parts' may be still good and soft parts not that
expensive. Here what I would do : bring car to your mechanic and ask to remove transmission.
get the transmission to the transmission repair
shop and get their estimate. If tranny is ruined
and too expensive to fix, get another one from
junkyard. This way you will avoid pressure to go
one particular way of resolving the problem and will save a few bucks. Make sure to clean the engine compartment after repairs are done, and wash undercarriage from transmission fluid. Drive car around for 3 - 5 K miles. This way you will avoid "what that stinks?" question during trade in, or even omit transmission problem altogether during the trade in process
We thought of going for salvage, but since the car is so new and that it wasn't a real popular car, the chances of finding a wreck turned out to be slim to none.
I live near a pretty steep mountain and we go up/down several times a day. to save on brake wear we use engine braking (shifting into 2nd gear).
recently we've had two torque converters die suddenly. one in a 94 jeep wrangler with 45k miles the 2nd in a 93 cadillac 60 special with 87k. the repair costs were several thousand dollars.
is this caused by using engine braking? or did we just have bad luck with both cars?
Your converter may have had some defect that led to it's early failure. Too, if a large part of your driving is up and down steep slopes in hot weather, these factors may have contributed to the failure.
My guess is that you your failures were flukes. I would continue to use engine braking on the downgrades. (As you apparently well know, to do otherwise invites brake overheating and possible catastrophic consequences.) If you have significant hot mountainous driving, suggest that transmission fluid be changed somewhat more often that the owner's manual calls for and be sure the transmission fluid cooler is working properly. An auxiliary cooler may be advisable. (These coolers are not too often installed on passenger cars but vehicles that tow travel trailers usually have them.)
I have a question? I have a friend she always
shifts transmission to Neutral when she stops
then shift back to drive when she goes.
Is that good for transmisson or bad for transmission? People says if you are doing
that to CR-V, it will hurts transmission.
David
A long wait in stalled traffic or at a train crossing would be an exception; particularly in hot weather. With a long wait, selecting neutral will reduce the engine load slightly and facilitate better engine and transmission cooling. Some fuel savings would also result but the savings amount would be extremely small; I would guess 5 to 25 cents per year for most driving conditions.
They said the transmission is toast.
Dealer said it would cost $2300.
Don't you all think that is a little high?
What would you do?
I have 97 Mazda 626 LX AT. Trans. was replaced at 30K. Now It has 37K.
When I check the oil, I realized that at the end of dipstick there are very tiny metal pieces, may be 3 or 4 times smaller than pinhead.
These pieces are attached to the dipstick, oil seems like clean. After 2 or 3 dunkins stick comes up clean.
Also when you try to get any gear, trans. is banging. Original one was not doing it. Mechanic said this is very normal.
Thank you for any response.
Since the car is under warranty I will take it to dealer but I am tired of that BS
A "banging" condition is not normal; something is wrong. Suggest that you talk with the service manager and request that he drive or ride in the car to understand the problem. I would be quite firm in insisting that corrections be made but allow him a few days to schedule the repair. Hopefully, by not being too pushy on the date of the repair, you can keep communications reasonably friendly. Keep a record of what was done and "who said what" in case it does become necessary to call the Mazda zone office with your complaint later. Good luck.
I forgot to mention that banging is only happening when the car is not moving.
From park to r or d. Once the car moves it shifts smoothly. Any idea?
I seriously doubt you could overhaul the trans yourself, since besides getting all the pieces back together right, you'd need special tools and extreme cleanlines and probably a special type of washing machine for the converter....it's not rocket science, but it isn't all that easy either...and getting the damn thing out is a job, too...a C-6 is heavy, and not the kind of thing you'd do on your back.
Try an oil and filter change first...you might get lucky, you never know.
V8/4.6L, moonroof,leather,power everything.
Love the lines,love the power,handling, was very happy with my new kitty. 40,000 miles later, transmission shudder and shifting problems.
Had the transmission rebuilt. Not under warranty.
Two years and 40000 miles later, yep transmission again! I guess $2000 in trans. repair is still cheaper than buying a new car, although, I can`t help but think I better save up another $1000 for the upcoming two year mile marker! No more cats for me. No longer trust Ford/Mercury transmissions. Will not buy another one!
EX-KY-CAT FAN
have trouble getting ahold of Geo/Chevy manual
transmission parts? I took my '97 Metro in for
some warranty work three weeks ago. The
dealership said they had to order a seal and
one other part. One of the parts arrived, but
the dealership says the other part is still on
back order. They said they even put out an
emergency request in an attempt to get the part
from somewhere else in the U.S., but apparently
were not able to get it. Is the Chevy supply
system really that bad, or is this an unusual
situation?
repaired (three times) by AAMCO who blamed Ford
because the trans was not getting enough power from the engine. Now at 156K the same unexpected, no clue given until the transmission melted down, again. I duly affirm that all I do is drive the vehicle to work and back (52miles RT) on flat terrain with a very occasional trip to the mountains. What is wrong here!! I read that in Nov 98 Ford may have recalled 92+ 4 wd Aerostars for transmission failure but I cannot obtain a hard copy of the recall. Any one else experiencing such problems??
One guess: They are using the wrong tranny fluid. Two: The tranny cooler has a problem. Three: They used an inferior part or missed a part all three times. Four: Part of the tranny has been changed physically by the severe heat (like the casing) and thus cannot be repaired. Five: A totally different problem that someone here who knows trannies might guess.
a) you got your money's worth from the first transmission and
b) AAMMMMMCCCCCOOOO messed up the repair on the rebuild. Not Ford's fault in this case, nor yours for that matter.
Are you referring to a transmission problem you have with your dodge ?
If so.. did you have a transmission fluid change not long before you started having your transmission problems ..?
I read somewhere that a majority of chrysler's transmission problems were caused due to using dexron instead of the mopar fluid...
just checking .....
#128 (and #130, for that matter):
Sounds like shopping around is your best bet. Try calling up different places, the dealer and independent shops, for a price on a factory rebuild. When you shop around get a total price that includes installation (parts & labor).
How long will an average tranny or transaxel
last before going south? Is the average
different for different auto manufacturers?
We've got a 1990 Ford T-Bird w/100K miles,
a 1993 Saturn SL2 w/153K miles, and a 1999
Chrysler Town & Country w/7K miles.
- Grego
A transmissions biggest enemy is heat, so a cooler is a great investment for long life.
This dealer would not go to bat for us with Dodge (or admit to a service screw up at the transmission service), so we ended up paying for a transmission repair. Needless to say, we no longer own this vehicle and warn every one we know off Chrysler products!
>but if you take the average japanese car, for
>instance, it should last the car's lifetime
The reason I ask is that the Ford (100K miles)
is getting close to needing tranny work. Also,
when I took the Saturn in for it's last service
(at ~150K miles), the mechanic was suprised that
I had had no tranny work done on it up to that
point...why did he have that expectation?
When a Chrysler product's tranny goes out at
~70K miles, that seems a might early...but
should we expect 100K to 150K miles for an
"American" (Ford, GM, Chrysler) car?
Just by happenstance, we own 1 vehicle from each
of the "big three"...I would *REALLY* like the
1999 Town & Country's transaxel to last at least
100K, if not more. Am I being overly hopefull?
- Grego
Aside from these persistent complaints, it's always been my position that the US makes the best automatic transmissions in the world, but alas, that reputation may be slipping (no pun intended).
I'd say 100K is a fair expectation for an automatic...I'd expect AT LEAST that from my car. Of course, if you're towing or you miss maintenance, then that expectation may have to change.
all of these transmissions were serviced at 25k intervals (fluid/filter change). None were used for towing. 75% of the miles are highway cruising miles.
a friend in the transmission repair/rebuild business told us that they usually go 75k to 100k miles before needing a rebuild. a small number will fail before 75k and a small number will last past 100k.
with the exception of the Jeep, our other cars seem to fit this pretty well.
The Transmission shop said bring it back in, no charge they are determined to figure it out.
They called me yesterday and said they want to put a shift kit on it. No charge. What good will that do? Anyway a friend of mine told me to tell the trans. shop to put a new speed sensor on it while they had it also. I am way out of my league on this subject, I know nothing, please throw me some wisdom, anybody. Lost in Transmission Traumas
By the way, no codes are showing on their fancy machines.
I called the trans. shop that has my car and told them to stick a speed sensor on it. I pick it up this afternoon. Guess I just have to drive it awhile and see if the new shift kit and sensor worked. They didn`t charge me anything for these items, so at least my wallet is still ok.
As for my car, the trans. man said bring her big if it acts up again and we will try something else. I was unaware so many things could cause a prob. with the transmission. I figured, hey you rebuild it and its a done deal! This was a learning experience for me. Thanks again and I will let you know how the kitty does in a few days.
My new Kia shifts smoothly, but seems to pause a moment in first (when given a good amount of gas) before really taking off. What's that all about?
cr
My question is this, what might this sensor be and could this be the whole problem. I would by a new sensor but I don't know what this one does or what it is called.
Any help would be appreaciated. Please e-mail me at e54@pacbell.net
Edwin
Heyward
