the car was jerking so hard I wasn't sure I'd make it back up to the dealership.( It drove fine for the first 5 days.) The service dept. said nothing wrong registered on the computer, so they have to pull out the transmission and fix it.This may take up to a month because the beetle technicians are on vacation the next 1-2 weeks! My first car payment is due in 2 weeks and I feel very bad. Is this a common occurence with the new beetle ? What can I expect from here on out with this diagnosis?
To change the shift point, you want to make a small change in the effective length of the transmission cable. You will find a threaded portion on one end of the cable sheath which facilitates this adjustment. Loosen the locknut and turn the adjustment nut about two turns, increasing the tension on the cable, and retighten the locknut. Carefully note the amount and direction of the adjustment so you can return to the original setting if necessary. Make further adjustments based on the driving performance. This will affect the 1-2 shift as well as the 2-3 shift but should provide better overall performance if the shifts were previously too early. Note that there may be a trade-off; sometimes raising the shiftpoint will be accompanied by harsher shifts ...necessitating an adjustment back near the original setting.
I feel it is not as smooth a transition as it should be from starting and stopping. The gears are great all the way through them, but this intermittent annoyance..? could it be a brake adjustment I am feeling?
Thank you shawn
Could it be that one of your sensors, such as a hydraulic pressure sensor or a speed sensor, is defective and therefore the cause of incorrect shift points? Sorry I can't provide any specifics.
1)follows the rotation of the torque converter internal shaft (continues for 2 seconds after flex plate stops turning).
2) usually starts when I put the vehicle in reverse, sometimes takes a minute or two, then continues to squeak in all gears, P, N, D, R.
3) stops squeaking when I put a load on the engine, resumes when load reduced. If I shut it off, then restart it, the squeaking stops for a minute or so.
4) Noise appears to come from just behind torque converter. About as loud as a car alarm.
5) No metal particles in pan, slight amount of fibrous material (half a pinch), fluid changed 4,000 miles ago.
I put in a new flex plate and torque converter, but the problem persists.
I have not heard a transmission make that noise before, nor have found anyone else who has. Any ideas? It shifts fine, runs normal. I havn't been driving it for fear of having the squeak turn into a grinding noise.
Bruce
and fluid in EOD tranny. Shifts into/out of reverse and drive real well. Will not upshift out of second gear. Anyone have any ideas on what's wrong and how to fix it? Thanks in advance. Hugh
problem. Dealer asked me to replace a re-build
transmission w/ the cost of $3300. I checked other
shop only cost me around $1800 to $2800. My question is what is the right range of doing this replacement. This is the 1st time I have this kind issue. I did the regular transmission maintenance at 30K miles and 60K miles. This van supposedly is reliable. It really bug me a lot. Their reputation get downgraded in my impression.
How many miles does the van currently have? You can always call Nissan customer service, explain that you had regular maintenance done, and simply ask them if the life you got from your transmission is acceptable to them.
Gus
Conference Host
At 32,000, the transmission was just starting to act up, so we dumped the car.
Workmanship was terrible, I could go on and on.
Resale on these is terrible!! Nobody wants them even at 2000.00 below book!
Still, people are still buying...Just like I did when I was assured that the 95's were all new and "improved".. Yeah, right!
I took the thing to Dave's Aurora Transmission in Lynnwood, WA. They quoted me a great deal on rebuilding the tranny. But when I brought it in, they kept saying the tranny was fine. Wouldn't take my money for a rebuild. So they kept it overnight for the owner to look at it. Called me back the next day saying "you're not going to believe this". Turns out the noise (that six people swore was a bad trans pump or bushing) was a vacuum buildup caused by an extra PCV valve (pcv valves on both rocker covers)in what was supposed to be a breather back to the air cleaner. It was causing a resonating "squeak" that was vibrating the whole motor/trans. Took off the PCV valve, stuffed the hose in the breather hole and everything is fine now. Nobody had ever heard an engine/tranny make that noise before (except a squeaky belt).
Oh, Daves Transmission spent an hour and a half on my truck to figure this one out, and charged me $0. The last honest transmission shop I figure.
Just think if you had taken it to one of the chains?
well it started to make a sound so i brought it in.turns out according to the service guy my car missed quality control and it was released with no transmission fluid in the car.. .so i killed the transmission by driving hte car. they need to replace the entire transmission. could this effect the engine? will this be a recurring problem now since it had to be worked on? should i request an entirely new car since it's only 2 months old?
any advice help or similar experiences greatly appreciated.
What make / model is your car ..?
how would it even make it till 2 months if there was no transmission fluid when you bought the car ..?
how did the dealer miss it and he is supposed to inspect the car before he delivers it to you ..?
My feeling ... If you can get the dealer to acknowledge that he sold you a car that had no tranx fluid then you should press him to own up for it and give you another one.
i don't know.. but i put 4000 miles on it and it began to whir and whine.. that's when i brought it in.. he said there was some in it but not enough and that messed up the transmission. i have gotten on the phone to VW and i am seeing what i can do to make myself trust my car and VW again. this is all a big fiasco. thank you for your response.
and yes they are supposed to inspect it.
Dave's Aurora Transmission shop is to be commended.
Marc3, have you checked the tranny fluid? Is the level right, and what color is it?
guitarzan
Community Leader/Vans Conference
About 20,000 miles ago, a noise began coming from what seems like the transmission that sounds like a whirring noise or BBs in a tin can being spun around rapidly. The noise is present in all forward gears (neutral and park as well, not sure about reverse), but most noticable in first or second. I changed the transmission fluid and filter about 10,000 miles ago. The fluid was in perfect condition; there were no metal pieces on the magnet. The transmission seems to be ok other than this sound. I just don't know if I should be worried about it. I searched for TSBs on www.alldata.com and found that there is a TSB for "Transaxle Bearing Whine", number 932727A, issued in JUL 93. I have not been able to read this entire TSB, but I think it might hold the answer for me.
I have seen at least one other car with the 4T60E transmission exhibiting the same symptoms while driving down the street. Does anyone else have a GM car with the 4T60E that has this problem?
Does anyone else have a copy of this TSB or know where I can get a copy of the entire thing instead of just the summary (without paying $20 like alldata charges)??
Jay
the noise was coming from the front wheel bearings. they replaced both bearings ($900!!!)
and the noise went away.
They did notice that the trans was slipping a little and told us that we'd need a new torque converter and some minor transmission work "soon".
so you might have your shop look at the wheel bearings.
Thanks for the tip. I don't think it's the wheel bearings since the noise is present even when the car is stopped (the car makes the noise even in neutral and park). I'm still trying to get ahold of that TSB.... no one seems to know where to get them other than paying alldata.com $20.
I have a 1996 Buick Regal, 3800 with just about 56000 kilometers. It has automatic, overdrive transmission. The 3 year warranty was over just about a month ago. Last week, after backing out of my driveway and then putting the car in drive broke something inside. The car stopped moving. I found a broken gear and some metal parts, looked like part of the casing on the pavement. There was a reddish brown sort of fluid that leaked all over the place. I checked the transmission fluid. It was still there. I am told that it is the gear in the differential. I took the car to the dealer. They say, warranty is over. Mileage is still under 60000 km.
I checked with another mechanic I know informs me that GM has had differential problems in their cars. The differential is not as sturdy as it should be. He could not find any info. on 96 Buick Regals though. I just want to know if anyone has heard of similar problems with GM cars ? especially at such low mileage. I am asking GM to fix the problem at their cost because the dealership wants to replace the transmission at a cost of $ 3800.00. Any suggestions, anyone ?
