Cracked block on a EcoTech I4 engine
My 2009 Vue developed a coolant leak into the oil at 130k km. I had to have replaced. GM has a technical note about this exact problem with the recommended fix: Engine Replacement. The coolant was leaking into the oil at the water pump.
The Statement from the dealership states that there was a crack in the block near the water pump. The dealership was good and gave me a little help with the bill, but a block should not break like this. Is this a design defect with the block, and if so is their a class action already started?
