Visitor Agreement.
It is 67,000 miles. In winter, whenever I started
the car, it can not forward or reverse. After the
engine run for about 5~10min, the car can move.
In the hot summer, this problem never happen.
i don't know if there is some problem for the
transmission. Thanks for your help!
i have a '95 m3. i just got it about 3 weeks ago. anyway, the tranny seems sticky between gears. sometimes it will misgear going from 2 to 3 and if your not carful you will dump it back into 1 by accident. is this a problem trying to show itself. what can i do?
2.E36 M3s are somewhat notorious for bending valves when a driver hits 1st instead of 3rd or 2nd instead of fourth. A stiffer transmission mount will help. Check out: www.uucmotorwerks.com for some helpful info. Click on "Products" then click on "TME".
It probably wouldn't hurt to check the motor mounts as well.
I still am not having any noticable shifting problems, but....
best of luck
Thanks for anyone who will answer!
Read through some of those topics and join in on any of the discussions. You'll find owners and shoppers in them discussing the relative merits of each.
Good luck and welcome to Town Hall!
Pat
Honda reccommends replacing the timing belt every 105,000 miles!
Is that such a big deal?
Blazer. Can I get one from GM? I called them
today with no luck. I must have the wrong number. If anybody has a number for GM, I would appreciate it. This transmission must be a good one because it will be sent out of the US and they do not rebuild in this country.
Thanks for any help.
fix the problem of your Dodge. If so, what did
you do with the transmission? Did you just replace
the seals? How much did you fix this problem?
Thanks a lot. Your helps are highly appreciated!
Sorry, I don't have answers just another question:
My 2000 corolla has a 4-sp automatic transmission. I can feel it shifting when accelerating steadily uphill around 30-40 mph. This is accompanied by a spike of 300-400 rpms and a spurt of acceleration. Is this normal or not?
Thanks in advance.
1. What causes the spike in the RPMs? The downshift? or the shift from 3rd-4th? I am ignorant on this subject b/c I do not drive stick.
2. The other day a state trooper got me speeding on the freeway. In my haste to pull over and stop my car, I shifted into P before my car came to a complete stop. There was a *THUMP* sound. I guess my car was going about 4 or 5 mph when I shifted to P. How much damage do you think occurred? Which parts of the transmission would suffer damage in this case?
Thanks in advance. I would appreciate any input.
It's difficult to say exactly what, if anything, was damaged when you slammed it into Park, without looking inside the transmission - unless it damaged the shift linkage itself, which you'd presumably have noticed by now. (Part of the problem is that you can't tell what gear it was in at the time, unless you know this drivetrain so well you can rebuild it in your sleep, so you can't tell which pieces that were turning weren't turning anymore.) I come from the "keep driving until you notice symptoms" school of thought, so if it's behaving more or less normally, you may have dodged - or at least slowed down - a bullet.
It used to shift so smooth that the only way you knew you were in a different gear was by the Tach.
It is now not quite as smooth as it used to be.
It has been servised properly its whole live.
Should I switch to Synthetic??
Will this help??
Are there any Negatives to switching to Synth this late in the game???
Thanks Smily
Synthetic motor oils (Topic #543)
Engine Oil - A Slippery Subject (Topic #851)
Pat
150,000 mi. is great!
Don't change anything.
Car shudders when the TCC locks up. Runs great when the TCC is not locked. From about 50mph and up the shuddering is not noticeable.
Definetly seems to relate to the TCC locking. Engine does not seem to be missing under load.
Any ideas??
If anyone in the National Consumer Protection Group reads this I hope you can get the word out.
Anybody know if the reverse in this puppy can be fixed without having to rebuild the whole tranny. Or is the best route to get a used tranny and simply replace the tranny.
At 212,000 miles it's probably shot though.
I took it to the dealership before the warranty expired and they said it is functioning as intended?
Has the tranny had regular service..? If not you might consider replacing the trans filter, but drain the old oil into a clean container, strain it through cheese cloth, and reuse it. I say this only because of the miles on it, and if it hasn't been serviced on a regular basis, I have heard the new oil can cause other problems.
This worked for me a number of years ago on an older Chrysler product, I experienced a similar problem, changed the filter (the old one was apparently restricted from lack of oil changes), and the vehicle ran for many more miles w/no problem.
Good luck, John
stick would pop out of gear in 1st. I thought it
may be the synchronizer. The replaced the
transmission. The mechanic said they found medal
shavings in the transmission. They problem seemed
to be resolved until 6K. Brought it back in. They
can't replicate the problem. It pops out of gear
(on the average of once every other day) Brought
it
back twice more without resolution. Has anyone
else experienced the same or similar problems?
