Visitor Agreement.
I don't know much about the Ford products, could this possibly be a governor pressure switch...?
Thanks, John
Boo Hiss on aftermarket spark plug wires. Replaced with GM wires and the car runs great!! Always avoided GM wires due to cost... well now I own a cheap set that looks great in the trash can. (Actually, the GM wires were only $15 more)
Caravan Sport. At 30K the transmission was acting
funny, each time it was taken to the Dodge dealer
they said it's alright. At 43K (now out of
warranty) it would only go into 2nd or reverse.
Chrysler said, 'to bad', and only paid half the
$1,500 it cost to fix. And the Dodge dealer would
only give $10,000 for it as a trade in. So, Two
things if you buy a Chrysler product minivan: 1)
buy an expensive extended warranty, 2) resale will
be very low.
Now after surfing the internet, I see I am not
along. Verdict: Chrsyler minivans look nice, but
have no quality or resale.
Has anyone been successful at suing Chrysler?
For 2001, also know that Chrysler has repeatedly
said over the past 10 years that they have fixed
their transmisson problem.
http://www.consumerreports.org/Special/ConsumerInterest/Reports/9910war0.htm
Have you done any service to the transmission? I always recommend that you follow the "severe" schedule no matter what style of driving you do.
Make sure that you only have dealership work on transmission so that you get the proper fluid (ATF+3/Type 7176 - NOT Mercon/Dexron III). You can see my dealings with DC and transmissions on the Vans board - Topic #970.
best of luck
The problem first occurred around 18,000 miles. The dealer suggested to keep driving till the problem was happening and bring it in at that time. Since I live in the county and have a lot of highway miles driving I am having a hard time getting the dealer mechanic to experience this problem. The dealer change the valve body but there was no improvement. The van now has 28,000 miles now.
The problem has never occurred when the van is first started from home. The problem can stop when the engine is shut off or sometimes the problem will stop on its on while driving. The service engine light has never come on. Any suggestions?
This past Sunday (with the car now having 12,270 miles on it), while I was in park, the car jumped into reverse. Then it got stuck in S2, which is like 2 or 3 on most automatic cars. Again the car was immobilized because of a transmission problem. (
Needless to say, I would never ever buy a BMW again.
Has anyone else heard of these kinds of problems with the 323?
Thanks in advance.
Doug
Need ATF + 3 for Jeep/Chry products.
I'd call a new car dealer if you want to confirm.
John
Bye.
If anyone tells you to use Mercon/Dexron III with some additive RUN:
www.allpar.com
best of luck
BTW, the lack of a dipstick is in line with your U.S. law which requires a vehicle to be "untouchable" for 100,000 miles other than routine service such as checking belts, changing air filters, etc. Hence Dexcool 100K coolant, platinum plugs, and other extended service items.
Would you recommend synthetic AT fluid? It appears as if Amsoil makes one which they claim exceeds all manufacturers specifications.
Gotta love that "not user-serviceable". What about the thousands of drivers who don't plan on doing driveway trans rebuilds but would like the assurance that there's something in there? First rad caps, now trans dipsticks. It's a conspiracy, I tell ya!
Regarding the synthetic fluid, as long as the label says "Meets or Exceeds Requirements of Dexron III (GM 6297-M)" it won't invalidate your warranty. Go for it. Superior stuff in every way.
myself. I have a 1993 Mitsubishi Eclipse GS.. I've
owned it for a year and its been into the same
tranny shop 6 different times over this time span
and during that time the following has happend.
Transmission has gone out 3x
Bad shifting 3x
They've replaced multiple broke shafts and other
various pieces as well as rebuilt the tranny but
three months later I was back in the shop with a
new transmission problem! Fortunetly I only paid
the first $1500 cost of the intial repair and the
5
different times its been in after that have been
at their cost.
What should I do?!?!? I'm already preparing a
letter to Mitsubishi with repair records demanding
action. I can't return it to the lot since it was
a
30 day return warranty which of course it ran fine
for those 30 days. I'm stuck with a pile of scrap
metal that I'm even having a hard time selling
despite it being in excellent physical condition!
Does anybody know what kind of trans. fluid is
recommened and the fluid capacity of the trans.
Thankyou
But this problem only happens after driving on the freeway for at least 30 miles(warmed up).
When Im doing city driving (stop and go) you can start to feel harsher up shifts, but nothing close to freeway driving.
What puzzles me the most is, when I shut down the engine and let it sit for a couple minutes, and then continue driving, everything is fine for a little while.
The oil looks fine, and there is no burnt smell. I even changed the filter and oil... and still have the same problem.....has anyone else had this prob. or maybe has an answer
Oil Pressure
1-2 Accumulator Piston, Cover, or Springs- damaged
Control Valve Body- stuck 1-2 accumulator valve or mislocated 1-2 accumulator bushing retainer
Driven Sprocket Support- rolled or twisted seal or worn sleeve in 2nd clutch housing
1-2 Accumulator Seal- cut seal
1-2 Accumulator valve- stuck valve
Source: 1997 4T60-E Automatic Transaxle Diagnosis and Overhaul Manual
If other shifts have the appropriate "feel", you can eliminate oil pressure. The most likely problem is a 1-2 accumulator malfunction (leak or bind). Could also be the accumulator valve binding in it's bore in the valve body as the unit heats up, or a leaking valve body or accumulator gasket.
BTW, this transmission does not have a dedicated control module. Shift points, line pressure boost, and converter clutch apply are controlled by the Powertrain Control Module which also looks after engine fuel delivery, spark management, etc.
Any thoughts...?
Thanks, John
According to this book I have just found, "GMC Authentic Technical Service Information on Transmission Diagnosis and Electrical Diagnosis".
Just let me say this, any book that has the "Authentic Technical" stamp on it, you know you have the answer to all your problems. (Ya, right)
To start off, I have to rephrase my first question to when I said HARD and Harsh, to DELAY SHIFT: meaning a condition in which a shift is expected but does not occur for a period of time. Delayed is also defined as late or Extended.
HARSH (ROUGH): meaning a more noticeable engagement of a clutch or a band as compared with "Firm". This condition is considered undesirable at any throttle position.
Delayed is more like my problem. When you first start to take off, your waiting for it to shift as your RPM goes up but nothing, then all of a sudden BAM it shifts. When I had my 84 Chevy Blazer w/ the 700R and if you had that problem, most likely all you had to do was adjust your kick down cable.
But according to this book I have been reading, basicly everything is controlled by the computer (OBD) and I mean "everything". You would think it would at least set a Trouble Code to what is happening. I guess I'll read on, I was hoping maybe there was a quick fix.
One more thing, Burdwag when you said it was'nt under warranty, did you mean the warranty expired or the warranty would not cover that particular part? Because I have the extended warranty with Warranty Gold. But thats a whole other topic.
SHUDEDER: meaning a continuous jerking condition similar to "Chuggle" but more sever rapid. This condition is most noticeable during certain car speed ranges. This is according to my "Authentic Technical Service" book.
I remember it did exactly as you described. I was moving some stuff up to UC Santa Barbara for my daughter. It was fine for about a half hour then started to act up. Once in overdrive on the highway it was fine of course. After stopping for a while it would be OK and then shortly it would act up again. Shifting manually had no effect. My brother in law said it had been acting up this way intermittently for some time. Actually he said the next day it was fine but then started acting up again later in the week.
