If an automatic is shifting hard, it could be lots of things depending on how the trans is regulated by the car's systems, but everyone should keep in mind that a trans service is always worth the money. An auto trans' worst enemy is heat, and degraded fluids cannot handle heat as well as fresh oil.
Obviously, those Crown Vic police cars are doing well, or the cops wouldn't keep buying them.
Neither one of my Fords have problems with the transmission, and that includes a Crown Vic...
Anyways, I think all makes have a bad design every once in a while, like GM's 5.7 liter diesel...
Yours in grumbliness,
Rick D.
1. follow the severe service guidelines in your owner's manual.
2. only use mopar tranny fluid. even tho some dipsticks say dexron...don't use it. if a mechanic puts dexron in to top off the fluid...immediately change the fluid and filter and use only mopar 7176 fluid. therefore be especially wary of quick lube joints who might not use the correct fluid.
just following these two rules should greatly enhance your transmission's life. he also mentioned that this transmission is very sensitive to the quality of the transmission fluid and that many people have eliminated problems with their units just by replacing the fluid and filter.
miles the transmission went.I am wondering now if
there was a correlation.
i just checked the owner's manual for my 98 intrepid and it states that i'm only to use mopar atf+2 type 7176 transmission fluid. it went on to say that use of any other fluid could shorten the life of my transmission and also affect shift and torque converter lockup smoothness. that seems a pretty strong argument to stick with the 7176 fluid if you ask me. now that i think about it, use of improper tranny fluid may have contributed to quite a few of those tranny failures that chrysler is so famous for.
Should I change it anyway at 40,000 miles?
INKY
I would disagree that the only course of action is to check the fluid level daily, however. Replacing the hose (and probably metal line) and transmission pan seal is a reasonable course to take, too. Interestingly, I did not feel any transmission slippage until I went to accelerate from a dead stop - all highway driving that day, until then. I have now adopted the habit of checking all fluid levels the morning of any highway trip. I'm also driving a GM now with a "bulletproof" 3.1L V6 and 3spd auto, and pampering it.
My research and reading confirms that Honda and Acura automatic transmissions do tend to be clunky in shifting, but they are durable. The Honda/Acura manual transmissions, however, are both snick-snick wonderful and durable.
Did the wholesale buyer you spoke to specifically say the problem was transmission failure? One reason some buyers may avoid high mileage Acuras/Hondas is due to the need to replace the timing belt at regular 60k intervals. The Honda/Acura engines are OHC engines with very little clearance between the valves and the piston. If the belt breaks, some of the valves will stop in the open (down) position and the pistons will smash into them, resulting in an engine rebuild or a new engine. This arrangement is much more power and fuel efficient, but does pose this problem in the event the timing belt breaks. Many engines, mostly used by the domestic manufacturers GM, Ford, and Chrysler, have greater clearance and if the timing belt or chain breaks the engine stops but there is no contact between pistons and valves so no permanent damage was done. Honda/Acura recommends that the timing belts be changed at 60k, 120k, etc. These timing belts can go well beyond 60k but it is felt that 60k is a safe recommendation to avoid breakage and the resultant damage. However, it is an expensive job ($500 - $700) so many people don't do it. I believe it is extremely rare for a belt to break short of 90k and many go well beyond 100k. The risk with high mileage Acuras and Hondas is that the timing belt has never been replaced and who knows when it will go.
If you are interested in the Odyssey, don't let this deter you. The auto transmissions are not the smoothest, but they are durable. Regarding the timing belt, it is a far more powerful and efficient engine because of this design. Just look at it from the perspective that at 60k this van will still be worth putting the money into it, while its competition (Caravan, Venture, Windstar) will be ready for the junkyard by 60k or at least worth virtually nothing in resale value.
On the transmission problem I had, the fluid level was kept up and was good when the transmission failed at 58000 miles. I had the fluid changed three times in the 40000 miles that I have owned it-before it failed.
Anyone else with that problem?
Your EXplorer will run better with the EGR valve and sensor in good working order.
Just bought a Honda Odyssey and the transmission is less than stellar - my wife and I feel that our other minivan (93 Mercury Villager)shifts smoother after 85K miles than a new Odyssey.
The transmission fluid has been changed at 30k and at 60k. The fluid is black, not dark red or brown, but black. The dealer says that this is normal for Camrys with over 30k miles but everyone else is as surprised as I am. Have any of you heard of black transmission being "normal" ?
The car has had all of the recommended servicing and seems to shift normally but I think the dealer may be too shifty.
I feel there's too much at stake here to let it go with the old "oh, they all do that..." routine.
You might check this site for latest recall information;
http://www.alldata.com/consumer/index.html
Smart Shopper
I have a '92 Maxima SE w/5spd and 96K miles on it.
Recently (last couple months) I've noticed a slight "vibration" during acceleration at certain RPMS - ~3600, ~4100, etc. etc. It's detectable in all gears, but at the same RPMs then goes away quickly just to come back again at another certain RPM (my wife can't even tell it's there when she drives it - it bugs me a lot). With the car in neutral, I can rev the engine and there is no vibration through the gas pedal. If I coast in neutral, I of course don't feel the vibration either. When the car is first cold in the morning it doesn't seem to exhibit the vibration till it's fully warmed up.
Could this be a sign of a clutch problem? It's still got the original clutch. Any ideas? At the 90K service the dealer didn't find anything wrong other than fixing the CV joint and finding the exhaust manifold cracked.
Michael
Also, although you said the car had been checked thoroughly, make sure that the motor mounts have been checked--make sure that the rubber is intact, and that any bolts/nuts securing the mounts to the frame or motor are tight.
Next day, started to hear funny sound took back to dealer. Were told the transmission is gone. Needs new transmission. Reason "because you hit ice went in ditch and were spinning tires back in January. This caused the transmission to fail. Talked to State Farm Insurance re: accident, transmission. State Farm will not cover transmission and Chrysler will not fix. What do you think. Can a transmission completely fail from this after it has been driven over a period of time after this happened.
Neon Transmission---the biggest enemy of automatic
transmissions is HEAT--someone certainly could have fried the internals of that transmission pretty badly while spinning the wheels in a ditch...not meaning to blame anyone in a distressing situation, but sometimes people don't give up and call a tow truck like they should.
By the way, the pan on the transmission could be dropped and evidence of burning should be quite apparent. If there isn't any evidence of abuse, perhaps Chrysler should jump in, at least partially, on such a low mileage failure. You might have the pan inspected at an independent shop and have them write down the results, should they show no burning of clutch plate material.
a lot smoother when the temperature is 30 degrees or below. Does anyone know why?
What I'm try to determine is whether or not to hang on to this car or get rid of it. I still owe about $8400 on the thing, so with the approx. $2600 in repairs (tax, towing, etc.), I'd need to get almost $11k for it just to break-even (Edmunds is telling me trade in value is about $12,500, so it might be possible).
I'd be looking at trading it in for a new car, and would be definitely "trading-down" from the Millenia to a more affordable vehicle. Even so, knowing I'll have payments either way and piece of mind of the new car warrantee make it very tempting.
Any ideas?
Sounds like this whole problem was due to a leak of some sort. It would be interesting if someone didn't tighten something properly, but alas, it may be too late to find out...the coincidence is interesting, though.
Millenia's are very good cars and I really think the trans problem was unusual. Get pricing from a good local tansmission shop also. I would stay away from the chains.
A good used one would be smart also,
