Visitor Agreement.
1) I'don't always have time to go through all the proper steps for fine detailing.
2) I used this on my 93' Celica (black) convertible & had great results.
3) I didn't have the heart to throw away 1/2 a bottle! LOL
Dave
P.S. Yes, the Escape is a great car/truck!
Dave
ie.1 piece vs.3 pieces etc..
Dave
2. Check out the local wrecking yards. You'll prolly find exactly what you want and it won't cost too much.
www.jcwhitney.com
I do not work for them, but ocassionally purchase from them and receive their catalogues. They always have dash covers listed.
It all depends on how picky you are, but generally, I firmly believe that a full paint job is a last resort and will not leave you smiling. Your choice, that is just my opinion. Any cheap paint job you get will not likely take well to shining and waxing and if you change the color it certainly will show scratches and scuffs as the other color will show through. Don't do it! If you have to, keep the original color.
~Spyderturbo
Don't use the chemical scrub if your paint is cracked.
Abrasives and chemical scrubs can be too harsh after this treatment, so now I only use the glaze/sealant and a pure wax (no abrasives) like california gold, or Meguiar's Hard Yellow #26.
What could I use to fill/blend in those scratches. They are pretty irritating to look at. I don't want to mess up the finish in that area.
Thanks for any suggestions!
RR
With clearcoat paint even the finest scratches will show up since the clearcoat is, uh, "clear".
If you can run your fingernail across the scratches and clearly feel each one then they are prolly pretty deep. If you can barely feel them then maybe its just the clearcoat that is damaged.
I think the two choices you have are to experiment by using a variety of products to remove the scratches. This will take time and money but if you like a challenge..........
The other choice is to take your car to a pro detailer or a reputable body shop. A good detailer can tell how much damage there is and may be able to buff out the scratches. A body shop can do essentially the same thing.
I second the advice that the first step is to try and buff it out. Actually, old cars like this are good ways to experiment with buffing and polishing techniques. I mean, how much more damage can you do?
I prolly wouldn't bother with a new paint job on a K-Car. Spend the $$ on a bumpin' stereo or something worthwhile.
Just my two worthless pennies that I picked up off the street.
I have heard that Chevy decided a while back that their vehicles don't need primer. I'll put it this way... I can see the scratches. In the scratch groove it is a light color, so it went through the clearcoat. Doesn't look like bare metal or I'd have gotten it taken care of sooner, but I may just bite the bullet and go to a body shop.
The eraser trick sounds feasible, but with my luck I'd trash the whole door and have to pay buku $$ to get it fixed.
When I first got the car, I Zaino'd it. Only one coat as I didn't have 6 hours to spare for the second one to dry.
Off to the body shop I go!
RR
1. Well, it won't help resale. A sharp used car manager can always tell if a car's been repainted. But if you sell privately it'll be OK. Just know that no one will care.
2. Side moldings usually get damaged when removed so its best to replace them. You're right about the double sided tape.
3. I'd have to see the flares but my guess based on your description is "yes, they can be painted".
Chris
http://carcareonline.com/
The paint sealant thing wouldn't have stopped you from crashing into the post either.
The scratch is about an inch in length, I wiped clean the area, and there are several scratches going across the door panel, I tried a bit Z5 with no avail. The scratch looks like it's above the paint to me, or very light, but I am not an expert by any means. I am wondering if there is any special agents out there that I can use to "wipe off" the scratches? or to cover it??
any suggestions would be greatly appreciated.
I did this once to an expedition parked with its bumper in contact with mine when I came out of the hospital. I had marks as a result... he had no damage because it was actually his license plate frame that came in contact with my bumper. There was no way the driver wouldnt have noticed since they had to walk around both vehicles to come to the entrance. The most irritating thing was that in an almost completely empty parking lot with dozens of free spaces this person had to come and kiss my bumper.
By the way... I've gotten rid of lots of minor surface scratches with polishing. Otherwise, rubbign compouds may work.
Try some polishing compound to remove the scratches. This problem happened to me a month ago and a little bit of Meguiar's Fine Cut Cleaner followed by some 3M Imperial Hand Glaze made my mirror look like new.
If you want to get rid of the rust, you can disassemble the parts and use a rust remover (chemical) or sandpaper. Clean each part perfectly. Then protect the item with some kind of rust inhibitor, clear coat, or paint.
Good Luck.
Since it is not an area anyone can see, and it is not finished, I was thinking of lightly sanding down the loose rust and then painting it with one of the various rust removers available. These products are supposed to convert the rust into a primer type surface that can be painted if necessary. I was just going to leave it the primer color. I will probably only need about $5 worth of the stuff.
Does this stuff actually work, and will this keep the rust from returning?
Also, if a car has about a dozen scratches or chips, what should I budget for repair? I would prefer not to paint the entire car, as I believe the paint is original. I would like to make the car look better, but mainly to preserve it another 34 years.
Brenda
Inssurance paid for it to get color buffed,160.00
Shop said it was caused by chemical. After many calls to rude insurance people I sent an email and they said they will pay 3000 to have my car painted.
Isn't 3000 too much ? Insurrance said they already sent the check. Are they likly to raise my rates ? I still don't trust them. I am getting it painted at the end of the month.
