Visitor Agreement.
should I just put some clear coat paint on this or what? the touch-up paint from the dealer comes with a separate clear coat as well. they are in the nail polish format.
any idea???
again, any chance of using the clear coat touch up from the dealer, then wet sanding, etc. to smooth the surface and blend with the original?
we already know how Joe feels about this.
I did this about two years ago with an '89 with a damaged trunk and the results were excellent: painting cost, about $250 at this particular shop.
Take care.
Joe W>
Last time I had this problem it was on a 1988 Volvo 240D (bought in 1990) the clear coat around the air vents by the hood and around the windshield were peeling off.
I have also used Zaino window cleaner which seems to be a mild abrasive in a polishing suspension and works well too, but you have to order it by mail and with the freight it is not worth it unless you are going to order a bunch of stuff.
Look for this, I bet this or something just like it is available. Just make sure you follow the directions as I am sure you could really start polishing an eyeglass prescription if you were not careful and that would mean you are stuck for a new windshield or you can't drive at night with the craze lines that could be formed. I have used both of these products a few times with no problems and they really do clean up not only the water spots, but the wiper lines and marks.
One other thought... Have you ever tried using straight white vinegar on your windshield. It should cut through water spots pretty easily. You could then follow up with a basic window cleaner like Windex, 3M, etc. By doing this you will save money over abrasives (though Zaino is great) and won't run the risk of damaging your windshield.
My two cents..
Does anyone have experience with or thoughts on this tool? Any advice is greatly appreciated.
I have one myself. It is useful to a point, and the blade itself won't scratch your car, but there is the risk of getting something trapped between it and the car surface which can cause a scratch. And you still have to go behind it with a towel.
Others may chime in here, but meanwhile you can check out that other topic for some other viewpoints.
Pat
If they want to "color-sand" your car, it may be OK. The paint will be ultra-shiny, this is done for show car finishes. Howeverm the clear coat will be thinner.
Try the clay, Good Luck!
What is a claybar anyway? The salesman at the store described it as a liquid in a bottle and I pictured it as a bar of clay that I would lubricate with Z7. Can any of you old-timers enlighten a beginner on this? I'd really like to hear from someone before I get started in the a.m. so thanks in advance!
dave
I am a car fanatic for nearly 40 years and have been detailing cars on the side since I was a kid. I try EVERYTHING, and I am EXTREMELY skeptical of new "magic" finsihes and waxes. After a year of watching the comments in the forums, and seeing the results, I ordered a full set of Zaino and used it properly, over 2 weekends on our 3-year old Accord.
The results were, and still are like nothing I have ever seen. The shine is "hard" - I have never seen wax reflect so clearly, with such detail. It has now been 3 months, and the water beads like it was just applied. Bugs don't stick and come off with plain water. Please check out the photos at:
http://www.geocities.com/newwestd/CarPage2.html
AND
http://www.geocities.com/MotorCity/Flats/7501/Feb.html
to see what Zaino can do. AND - Here's the best part - it lasts! While my very best all-day glaze and wax job would look great for a while, it definitely fades after 2 months, maximum. The Zaino shine just keeps going and going! You may be shooting yourself in the foot with this.
I am not associated with Zaino in any way - just a converted skeptic.
Spray it on, rub, buff. (Check instructions, though)
Also - better to have too much than too little!!!
meguiars does sell just the clay bar but i've had a hard time finding it in my area. my local c.a.p. store carry's it but only 2-3 bars at a time.
dave
How many coats of Zaino? It is the only polish I've seen that gets shinier after multiple layers. Wax never did this for me. With the first layer, Zaino was no better than good wax, but after 2 or 3 easy layers, the gloss really came out. There was a huge difference between one and 2 layers.
How about over time - say 3 months later - is the wax side still shinier?
2) Surface loc layer
3) 2 layers each of swirl mark remover & polish
4) That spray polish ( z6? )
altogether 7 steps.
And, yes, 4 montls later now they look pretty much the same. Note that i'm not saying the wax was better, just no one could tell the difference. I note the zaino side beads water a bit better now. If you are really impressed with zaino I would suggest trying the 3m stuff. It seems awfully similar.
dave
What 3M stuff did you use? I am open to trying it.
dave
DON'T push down. The fibers do collect dirt that can possibly scratch. Try to hold the Duster so that just the yarn is brushing your car, not the weight of the duster.
DON'T use it when the car is hot. Some of the soft wax may melt out of the yarn and streak the car - not bad, but annoying.
DON'T use it after it is filthy - get a new one! The makers say you can use it forever, but they probably don't like a Zaino quality finish on their cars!!!
DO use it at the end of the day, before your car gets dew on it (if kept outside). That way the dirt will not get stck on to the car.
DO use it lightly -if the dust doesn't come off easily, it is time for a wash.
Have fun - JON
Follow the directions: before using for the first time, let the duster sit open on a newspaper. This lets excess wax drain away.
Obviously, they will repair it, but I'm concerned over the quality of the repair. Even if I can't tell that it's been repaired now, will it be visible in a year or 2? He has told me they'll replace the bumper cover if I'm not happy with the repaint. But, they still have to paint a new bumper cover, so what's the difference? I haven't accepted delivery yet, so I can still walk away. However, I got a good price and like the car otherwise. (Provided they fix the rattle in the rear deck) My concern is can a dealer do as good a job on paint as the manufacturer? Especially long-term durability?
His allocation sheet doesn't show anymore of the same model & color coming in anytime soon, and I can't wait for a long time for a new one. The color is Signet Silver, by the way.
All opinions are wanted, what would you do?
If I do have to let them paint it, will I have to worry about long-term durability? Is the paint going to chip/flake/peel/crack on the bumper that they repainted while the rest of the car looks good?
My gorgeous Pearl White Millenia S was damaged at 2 weeks old - I was devastated! My local body shop repaired and repainted the trunk lid and fender perfectly. Until I sold the car 3 years later, it was still undetectable, and I am very critical.
JUST - don't accept it unless it is perfect!
Thanks for any response!
andy
thanks again
andy
Any suggestions on how I remove the white residue caused by an inept wax job? Some weeks ago I washed and waxed my car. At the time I thought I had buffed off all the excess wax, but it is now very apparent that I failed miserably. There is quite a bit of white wax residue all over various spots, and it's quite tough to remove.
Any suggestions on how I can remove it, other than a wet cloth and an enormous amount of elbow grease??
Thanks in advance,
Mike
andy
