Visitor Agreement.
I have a friend who tried Back to Black to restore an older, grayed/whitened rubber bumper. The report was that it looked great. For one or two days.
It might work to remove wax from unwanted places, though.
Pat
Your host, Bruce
I have used a Wen orbital polisher for many years, the orbital design prevents most of the "swirl" marks associated with polishing, and it is almost impossible to "burn" the paint by pressing too hard in one spot. Be sure to get an orbital polisher and use foam polishing pads for best results.
However, paint is delicate, it is the one area where a light touch works better. I am not familiar with the B&D unit, but the Wen has a semicircular handle so you can use both hands. Actually, I usually used only one hand, the weight of the polisher was enough to do a great job, you should not need to press at all. Just let the polish do it's work. However, I don't use the buffer any longer, I'm into the polymers that just wipe on, wipe off and look and last fantastic!
joe
Have any of you tried one of these services? How well do they work?
Does the repair really restore the surface to the original appearance?
Any information would be appreciated.
Good how-to articles are at carcareonline.com. Washing and polishing cars can range from a dirty rotten chore to a love of life. Do what works best for you. Weekly washing with a good cotton chenille (or wooly) mit and wax when the water stops beading is probably middle of the road. Instead of the wand you'd be better off with a boar's hair brush on a 4' pole.
Many thanks,
Bob
http://www.autosupermart.net/forums/Car_Care/
they have lots of people talking about this stuff.
also see above for another site.
jackson
talking care of rust problems.
I have a few small areas of rust that I can't see paying someone big bucks for if I could do it myself.
The car is also 11 years old and where the rust is it isn't a problem if the paint doesn't match exactly.
I bought some GS27, but it didn't work very well on most of the scratches. In addition, I got some touch-up paint from the dealer (using the correct color code from the vehicle sticker). I applied some paint to some of the scratches, but the new paint appears several shades lighter than the paint on the car. It really looks bad - worse than the scratches! I have been told that because the car is 6 years old, the finish has oxidized and will appear darker than the when the car was new. Too little too late!
Two questions...Is there any way I can get that touch up paint off? And is there a better way to get rid of my scratches?
Thanks much for any help...
Thanks in advance
Any advice ???
I have a red 99 Grand Prix, and keep my car very clean, and while drying the car, over time, have noticed the appearance of the fine swirl marks that look like spider webs in direct sunlight.
I've taken care from then on to use different sponge/chamois on the top and bottom portions of the car and have not noticed the markes getting worse.
I've used 3M's hand glaze, which hides the marks well, but only for 3-4 weeks. Have any of you been able to find a longer lasting solution for these swirl marks?
Switching to such towels, yes, even to wash the vehicle, (I use a hand towel wrapped around a sponge) is somewhat more expensive than what you're probably using now, but it will stop adding to the swirls and scratches that you currently have.
If you use Zaino Z1 and Z5, available through zainobros.com, or a local Zaino distributor, you should be able to take care of the existing swirls and scratches. Given the color of you car, it may take five applications of the Z5 to achieve the desired result, which might take using Z6 on your polish applicator to help insure the most economical spreading of one bottle of Z5 on your size vehicle, but two bottles might be necessary. Call Sal Zaino at the telephone number on the web site, or write him at sal@zainobros.com to discuss your problem.
Also: indieboy: Zaino's Z18 Tire Glaze should help protect your rubber rails. Check it out at www.zainobros.com.
Just wondering.
Pat
http://autosupermart.com/
one grand is the company name.
and about 2-3 months ago the paint suddenly started flaking off in big "chunks". I now have
locations (roof, hood, door pillars) with 2-7" spots that are continuing to grow at a rapid rate.
I spoke with Chrysler and they directed me to my
local dealer. The dealer said they would pay for
1/2 of the AFFECTED areas (which are still continuing to grow!!) This to me is not acceptable...... Anybody have any similar problems? I have found no recalls on such a problem.....
If you are having these problems already it may get considerably worse, as my truck was "perfect" for over 4 years.
I have been trying to find any recall notices on paint. Have you had any luck with Chrysler?
My wife bumped our car (2000 Hyundai Elantra, black) last weekend and left a dent on the front
bumper. It's at the front-right corner and about
the size of a tennis ball. There're also some scratches around it. It's not that obvious but just painful to look at. (Damn it!)
A local dealership estimated it for about $450 to
change the whole bumper. A bodyshop would "fix" it
for about $200.
So what do you think I should do?
I'd like to have it changed, but with $500 deductable of my insurance, I'm going to pay the
whole thing myself. Plus, I'll have to leave the
car there for about 10 days.
To have it "fixed" in local bodyshop would cost a
lot less money and time. But can they do a decent
job? Of course, they said they'd fix it like new,
but can you believe them? Any experience? Any good body shops you know of?
Your opinion and advice, please?!
What is your opinion regarding using a cover considering these factors (e.g., convertible top, MI's snow/sleet/etc.)?
I have seen reference to different materials/brands: NOAH, Dustop, Evolution 4 and Sentrex. What do you think is best? Where do you recommend getting one?
Thanks for your help and thoughts!
PS - If you think this is better suited for another forum (e.g., Accessories), I apologize; please let me know, and I will ask there...
