Pontiac Torrent Sunroof
I have a 2006 Torrent. I was looking at the sunroof the other day and have a question.
When it is closed should the glass be level with the top of the roof?
When mine is closed it sits about a quarter of an inch below at the front and only about one eigth below at the back.
I have looked at 3 other equinox's and torrents with one being the same as mine and the 2 others higher at the front and lower at the back.
I was just worried about water pooling in the front edge.
Hopefully this will be resolved quickly for you. Let us know if we can check into anything further for you (we can be reached at socialmedia@gm.com and ask that you include your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation).
Sarah, GM Customer Service
There is a wire connection on the drivers side near the hood release and behind the plastic kick plate( if you remove the doorstep strip) it can get wet and lose connection. If you disconnect it and clean the connections and make sure they are dry it will fix the problem. I went a step further and wrapped plastic over the connector to keep it dry.
I own a 2006 Pontiac torrent as well, and am experiencing some really weird things. When I saw your comments on the sunroof issues. I thought I may have come up on some solutions via your experiences. But mines is a a bit more farfetched, even though very close to yours blueandhalo3. When it rains the front floor areas are soaked on both the driver and passenger side. Mind you not the seats. Then I experience the exact same issues"both Check engine lights are on as we'll as the traction control light. I proceed to step on the gas to move my Pontiac and come to find out I have no engine power at all, pedal is all the way to the floor yet nothing. " ****** I mean really who ever heard of a partitioned rain in******
Let me be very clear when it rains, there is no evidence of the water coming in via open windows or the sunroof. Just a real phenomenon......
made quick vid on youtube,
