Paint and Body Care
Lexol: Very good! I find the cleaner to be subpar with other brands, though. I enjoy the conditioner the most. It leaves it supple and soft.
Blech-Wite: Very strong! But I find it hard to use, since it's so messy. The easiest results are by using a sponge.
I'd like to keep the black, glossy plastic both black and glossy with minimal fussiness -- any suggestions of what will work well over the loooong term?
BTW, I've used blechewhite in a spray bottle on my tires for years. It does a consistently fine job. One car has BBS wheels, the other has lacquered alloys ... I've never had a problem or taken any special care. I just do the tires before I wash the car so that any overspray is washed off.
Take care.
Joe W>
Do 1/2 a mat and you will see!
Glad you like the Lexol - it really works well. Be sure to put it on with your hands, rubbing it in well, then buff off after it sits a while.
Vern
agree with automophile...always try to use the least invasive method first...so a glaze seems like a good start...good luck.
Vern
I need some help fast!
Let us know how it works out.
Silvercoupes rec of "mineral spirits" was more in line with what I have had very good success with...Turtle Wax brand of Bug & Tar remover...it comes in a can...and smells like it is full of petrol distillates...works well.
With any of these treatments, you should wax afterwards with your favorite auto wax.
Vern
new cars. Generally, if it is less than $X, the
dealer does not have to disclose the repairs to the buyer. You should check out what your state
says.
New cars get damaged quite often during transport
and delivery and this is the normal process.
I am not trying to defend the dealer's actions. I
always plan on a couple of hours to go over a new
car when picking it up. Better to discover it up
at delivery than a week later.
Also, I live in MA and found the following product, which I saw posted to a board, interesting. Does anyone have any experience with it or similar products?
http://www.stratmosphere.com/ultimate_snowbrush.htm
However, now those polished areas have very light swirl/scratch marks which are only visible under certain light conditions and looks a little "hazy" under certain other light conditions. Any recommendations?
As for remedying the scratches that seem to have resulted from your polishing, I have had success in filling in scratches using Zaino Brother's Z-5, @ $16.95, the formulation for filling in scratches and swirl marks. Z-5 is one of three polish products designed to be used after Z1, PolishLok, the base Zaino product, @$8.95. You can read about Zaino at zainobros.com and email Sal Zaino at sal@zainobros.com to find out if there is a distributor near you so that you might save the $6.95 Zaino shipping and handling charge. Because there are some hyper-sensitive folks in these forums, I feel I need to disclose to you that I am a Zaino Distributor as a side line. I've been accused of touting Zaino AND denigrating other products to my personal benefit. I only recall advising folks how to use Zaino, or answering what Zaino products might fill a Town Hall poster's expressed desire, such as your's, and only recall repeating others' problems with other products. When a satisfied customer of mine cited that I was a distributor in our area, I removed my email address and geographical information from my profile so that I would not be improperly using edmunds.com's forum. I am not saying that the Z1/Z5 combination of products is the only way to remove the scratches; it's one I found to be very satisfactory. The funny thing about my being "exposed," as some seem to like to characterize it, is that I had two contacts immediately following that incident, but have had no sales related to those contacts. So the sales I churned up before and after "exposure" total ZERO; for you language parsing detectives I have had no benefit direct or otherwise innur to me through the various edmunds.com forums.
So was the $1,402.50 worth it? Well, the $1402.50 wax was smoother and glossier than Zaino right after polishing. Interestingly though, the great shine didn't last long. So overall, the results are disapointing! The extraordinary gloss didn't last as long as I expected...
TP
But if you want more of a "show-car" quality shine, or become one of the car-obsessed (we will probably have a 12-step program for us soon), look into the better, higher end products. I used Meguier's before switching to Zaino. Both are good and have a wide range of products. Meguires has a professional series of products in addition to their home use stuff, and a very trusted restoration shop near me swears by their stuff.
Now that I've tried Zaino though, I'm thinking I'll be a loyal customer for some time. I'm really impressed with the quality and depth of the shine and the hide properties for the swirl marks. It really looks like I poured glass on the car the shine is so deep.
For more info, go to:
http://www.zainobros.com/
http://www.meguiars.com/
There are lots of tips on car care and how to avoid the swirl marks in the first place, how to hide them once they have occured, etc.
Wash the area with Dawn dish soap. The high alkaline soap really cleans things off very well, but will not harm the paint. It actually strips the wax off the washed area though, so be sure to reapply wax afterwards.
Use a surface cleaning agent like Meguier's Clear Coat Cleaner.
Use a clay cleaner like Zaino or Clay magic.
If all else fails, use toothpaste. But not a high-abrasive whitening brand. Just Crest or Colgate. These have very mild aprasives in them which are too fine to leave visible sratches. NEVER use the over the counter polishing compounds. They are way too abrasive.
Work with a high quality 100% cotton cloth or buffer bonnet. Polyester in the cloths can cause fine scratches and swirls over time.
And keep a good coat of wax on your car. Everything will come off easier and the paint will not oxidize.
2) After treating the scratch, I will detail the car before winter. What is the quickest way to remove the older wax?
3) I have a bar of McGuire's clay and want to know how much of it I should be using if I were to treat the whole surface (except the bed)? (or in a sense how much should be left when I am finished)
4) As for the bed, I have a removable bedliner that was only put on a few months ago. I was told to put on a coat of wax without removing it before putting in the liner. Is this a good idea?
Thanks, Joe
It really is hard to hide a deep scratch without using a good body shop. If you are going to try to fill the scratch, first wash the area with dishwashing soap. The brand "Dawn" has a high alkaline content that will strip off all of the old wax very quickly. Once it is dry, shake the touch up paint until your arms are about to fall off to get it well mixed, then use a toothpick to dap it into the scratch. Let it dry and repeat. It will take a day or more before the paint is completely dry and "flat" to the surface. You can dap up any excess with a rag wetted with mineral spirits or paint thinner, but be careful and quick. Unfortunately, the area will never be quite the same.
If the scratch did not go through all of the paint on the car, but just marred the top layer, you might try buffing the area with a high quality "glaze". Meguier's makes several different grits. Always try to go with the least abrasive that will work for you, and finish with the finest grit they offer. NEVER use the rubbing compound made for the do-it-yourselfers. They are too abrasive.
Claying the car calls for a lot of work. It's not complicated though. I've done it to several cars. Just keep the surface lubricated with a small amount of soapy water in a spray bottle while you are rubbing. You might check out Meguier's web page or e-mail them for directions, since you already have their product. http://www.meguiars.com/
You really do not consume the clay bar. But you do keep folding it around to keep te top surface fresh. Once the clay cannot be "freshened" by folding, or you get some dirt particles that can scratch your paint imbedded, it is time to get a new bar. So you can see why a really good wash is important before the claying.
Never heard about leaving unbuffed wax under a bedliner. Why would you?
Removing keymarks are pretty simple. If it is not very deep, I reccomend Zaino Bro's clay. If it shows the car body, I reccomend a scratch remover.
