I have a 97 Legacy 2.5 gt with an automatic transmission going into limp mode.
I have been having trouble with the shift solenoid and the trans going into limp mode. I recently replaced the shift solenoid and I now have the same problem but just when the temp outside is above 90 F or when I sit in traffic or idle for more than 3 or 4 minutes. The same code p0758 comes back up. Does anyone have any ideas? I was thinking maybe the temp sensor?
Best Answer
samfiveo
Member Posts: 2
My problem is the trans will shift 2nd 3rd but not 4th after the initial start up or restart. The trans then will not down shift from 3rd after this point. I changed the shift solenoid and the fluid and filter with no real change. I didn't notice the issue of heat before the change. I am starting to also suspect the tcm. Thank you for your help!5
Answers
