Paint and Body Care
Looks like small scratches that caused the rust. Is there a do it yourself method of fixing this which looks halfway decent?
Anyone have any opinions, good or bad?
Brenda
2) WD-40
Wash thoroughly and Re-wax after the tar removal. Good Luck!
You may want to look into mud flaps if this may happen again.
Vern
Anyway what they really do is protect OTHER cars-when you or your passenger open/s the door too quickly-you wish everyone, esp. people with kids, would use them so YOUR car doesn't get damaged. They will afford your car some protection against nicks, but only for that small area they cover.
Right now I am trying clear (like tape) strips that go on like window tint. They are almost invisible (if thats important) but again they protect other cars more than yours.
They are available for free from www.clearmask.com
You must be patient, if you are a "Give it to me now" person, you should do this yourself. It took me approximately 6 hours to install all of it.
Recommendations: I used the "Slip" solution on almost every piece. The slip solution lets you position the product exactly where you want it before you make it stick. Have a hair dryer ready, for the curved surfaces. Remember that this should last at least 4 years so don't be in a hurry.
Also there are some trim restoring compounds out there, such as "Black Jack" and 3M Scotchguard Protectant Gel for trim. These may restore some of the natural oils to the plastic and make it black again. It may take a bit of rubbing to get the treatmetn into the pores of the plastic.
Good Luck!
I've also put some Rain-X on my windshields. Of course it is a record-dry fall in my region, so I won't get to see it work for a while.
Brenda
Brenda
Brenda
My insurance might not cover the body repair costs because of my deductible.
Can the bump be fixed easily and at a reasonable costs? Does it have to be done at a body shop instead at a general car shop/dealership? Thanks.
I bought my bra from www.xpel.com but that was the only company that I found on the net. If you can get it cheaper from Bavarian Autosport, do so. Just insure that it's the 3M product. I visited the auto show that was just out here in Las Vegas and 3M was the only manufacturer that I saw that offered the clear bra.
If not, tell me this... could oven cleaner compromise the integrity of the paint? I ask because when I bought the car, having waited a couple of months for a standard transmission in a decent color to come in, the dealer decided to pinstripe it for me even though I never suggested that I wanted such a thing. So after some hassle they took it off, from what I was told, with oven cleaner. Could they have ruined the paint on my car? If so, what can I do about it?
A couple of other things... the paint that is gone is mostly in one spot about 2 inches wide by 1 inch. The other spots I've noticed are much smaller and not very many (7 or 8), but they are all along the area where the pinstriping was. When I had my car in for service a couple of weeks ago, I asked the service guy to look at the dissolving paint (the large area). He said it looked like someone threw an egg at my car and it dissolved the paint. Is he trying to throw me off or what?
I am no paint expert, and would not begin to guess what such a high alkaline product like oven cleaner would due to paint, but eggs do not disolve paint. They will make a mess, that can be very difficult to get off without damage to the paint, but the eggs themselves will not disolve the paint.
I wouldn't be worried if the dent was on a smooth part of the sheet metal, however this dent is on a steeply angled piece of metal. For those familiar with the latest Accord Coupe, it is on the angled piece of metal near the door handle.
The dent isn't severe enough to visibly damage the paint, however I am guessing the damage occurred during transport while the protective plastic sheet was on the car's exterior.
Any thoughts? Thanks!
Usually, dealer's will have you sign a sheet before you drive off that the car was inspected by you and you agree that it is "OK". Did you sign this sheet?
If you accepted the car "as-is" then you probably don't have much recourse. If they agreed to fix it, make them do it.
I signed the inspection paper after an inspection with all of the plastic still on the sheet metal. Yes, I know, very stupid! Upon the discovery of the damage, I had the sales manager sign a brief note that the dealership would fix the damage. The sales rep also indicated that he would provide a loaner free of charge.
The autobody shop owner recommended that he NOT put in a new panel, as this could compromise the factory welds and seams which could lead to rust problems later on. He was able to repair the dent to my satisfaction without cutting out and replacing the old panel, and without disturbing the factory welds. Don't know if the paint was disturbed, the area required refinishing anyway because of little nicks and cuts from glass, although the dent itself had no broken paint. In the end the appraiser let me keep the little money saved from not having to buy a replacement panel, although there was some additional labor.
So I would ask how the autobody shop is planning to fix it, although it would probably be whatever will cost the dealer less.
I am taking my vehicle to "Dent Wizard" which is the shop my dealer referred me to. I'll let everyone know how it turns out this afternoon.
But when a similar thing happened to me (and I didn't know about clay then, or these forums), I just used lots of water and my fingernail-yeah took a while but I found that doing one spot at a time with your finger was the only way you could tell if the grit was coming off, and floating away. If you use a brush or sponge/similar, you can't tell if you are rubbing the loosened grit right back into the finish. This happened to my corolla that was 6 years old. I think I would freak out if it happened to my new car.
The points out another reason to keep your car well protected with a good wax or polymer finish all the time!
Five months old? Yikes.
Pat
Community Leader/Maintenance & Repair Conferenc
