I just had my transmission rebuilt put it in and now it skips 1st gear and goes right into 2nd gear
colinshoellcolinshoell Member Posts: 3
edited July 2015 in Ford
Has anyone had this problem before?
Answers
  • colinshoellcolinshoell Member Posts: 3
    Its a 2004 ford f150 RWD
  • rhinestonefuserhinestonefuse Member Posts: 76
    No
    You mean it starts off in 2nd gear or do you mean it stays in 1st only a very brief time?
    If you just had it rebuilt, why not just take it back to the shop that did the rebuild.
    They should warranty it for a period.
  • thecardoc3thecardoc3 Member Posts: 5,861
    The problem doesn't have to be inside the transmission. Are there any codes setting in the PCM?
    yes, there are codes I will borrow my buddy's code reader and get back with you. thanks
