Services--How often, and what to do?
as far as the antenna mast, wouldn't you feel dumb if it came flying off and you had to replace it when a simple act of giving it a quick check with your hand every whatever interval would have stopped it from happening?
you want to vent about bad dealers/shops? fine. we've all run into them, and some of them are worth venting about. but don't give people the impression that just because "you can't trust anyone" that they shouldn't do PM on their cars.
-Chris
The recommended maintenance tasks outlined by the automaker are necessary to keep your machine in good working order. Not allowing yourself to be gouged by a dealer for it doesn't mean avoiding it altogether. If you DIY, or get a local mechanic that you 'trust', this should be the same as going to any dealer as long as prescribe tasks are done.
As for checking power antennae mast, you'll be surprised how much dirt and gunk gets into the sections. A little wipe and lube will keep it in good order, and not burn out the antennae motor or strip the retraction cable.
as far as the antenna thing... probably it would survive without it being cleaned... but since it would take probably 30 seconds to do it, it'd be a drag to have to spend the money to get it replaced because some kinda gunk built up in there that you could have cleaned out...
-Chris
One thing I'm learning from owning Hondas is that the manufacturer holds the dealers accountable financially for customer service. The two Honda dealers I've dealt with literally bend over backwards for customer service.
In exchange for this Honda builds reliable popular vehicles, but not enough of them to meet demand allowing dealers to get close to MSRP and sometimes higher. Honda also (IMHO) recommends many maintenance items that can easily be done yourself. I'm still tickled pink by the "check antenna mast" one.
ZHS
good luck.
-Chris
ZHS
zhs. you are welcome. one more thing. i'd avoid the quick lube places if i were you. 99% of the time you'll be ok there. but...
-Chris
I am kinda confused with this one, I know they will check alot of things like belts, fluids etc.... now, my problem is that, I have some aftermarket stuff in and on my engine, what happens then? ie I have K&N filter for the air intake, redline tranny and rear diff, modified a/c and power steering belts due to lightweight pulley. Basically, there's nothing much they can change or maintain. So will they still charge me a bundle? Will I lose my warranty if I don't do that service? thanks.
Touring Around,
Kristina
Welcome to the Maintenance & Repair Conference. Glad to have you drop by.
For others - md_tech is the new co-host in Our Turn. She has been in the automotive field for several years now, is a Maryland State Inspector and is working on her ASE certification.
I imagine if she has time to hang out over here from time to time, she'll be quite helpful!
Pat
(editor's note: i am not a mechanic). having said that, you have two choices (obviously). you can get it done before the trip and have peace of mind during the trip. or, you can do what so many others do on a regular basis and get away with it - put it off. well no kidding, glad we got the landmark comments out of the way.
anyways, here's what i would do. is the car running well? do you consider it to be reliable? has it ever let you down in the past? if you can answer these questions yes, yes, and no, i would drive it the 2k miles and THEN get the service done. why? because you're getting the most out of your old(er) parts and fluids. then, after wearing them out...you get them changed. if you didn't answer yes, yes, and no, then i would get it serviced before the trip. remember, part of that 15k service is prob'ly going to be an oil/filter change and lube job. these should happen every 3-7.5k miles you drive anyways, depending on your driving habits. i'm guessing you're prob'ly in the 6-7.5k range with that kind of car. now, if you get that service done before your trip, you're looking at another service shortly thereafter. if you wait till you get there, you get it done and it's done for the next 3 months or so. call me cheap...i don't think you'll hurt a thing by waiting till you finish the trip. others will tell you it's $200-$300 worth of peace of mind (or cheap insurance). i say, $20 is cheap insurance...you have to make the call...
kyle
early service is ALWAYS better than late, and that applies to everything in life, not just cars...
-Chris
Some of my friends who have big Bimmers/MBs etc claim they go to almost 10K before their oil change lights light up (and then the dealer comes to their house to do it!).
Several years ago I was driving in England in a Jetta, the owners manual says no change till 10K (miles not km). My brother had the same year US model and the recommended change was the usual 3K type thing. I don't know for a fact that the engine is different but why the big difference? Someone told me once that the DoD did a study on vehicles concerning frequent oil changes and 3K changes were totally unnecessary. I don't mind paying 20 bucks every few months for peace of mind but that must be an awful lot of oil used in this country which is wasted! If nothing else, bringing it in sometimes allows other problems to be noticed early (like my cracked CV boots!).
Regarding long term warrenty's on replacement brakes, mufflers, etc. It is all "hipe", unless you are going to drive that car forever. They know the average person keeps their car for seven years, And if you go back for that free second muffler, etc there are always extras the will find to charge you for. There is no free lunch. :-)
Norm
Somebody might be able to answer your question here, but if you want to look through that topic while you are waiting, you can click on that highlighted link to see it. (The archived part of the discussion will be linked in post 0 if you want to go back even further.)
Pat
As a Minnesotan, 5w 30 was routine in winter for most cars even if 10w 30 was specified. Most garages here recommend 5 30 for winter. It performs better than 10 30 at low temps as there is less friction when you start which is when you really need oil!
-Chris
Just like with legal and medical stuff, the pros know the best things to use.
on my 96 honda accord ex (it is a manual trans)?
what else should i be thinking of doing at the
90k interval? i bought the car with 45k on it,
and haven't done much besides oil changes/tire
rotations/etc.
He goes by auburn63. You can just click on that highlighted link to go to that topic.
Pat
What's a good truck plug? I tried to contact GM, but they said that my local dealer would be able to tell me. A lot of good that did. If I can't get it from the horse's mouth, where do I go?
Happy Motoring. ;-)
Pocahontas,
Edmunds.com/Roving Host
But if your car's oil is just as black at 3,000 miles and at 5,000 miles its engineers did not do a good job of keeping air away from the oil. Engine oil is oxidized by oxygen when hot. Well-designed engines of the last 20-30 years do not blacken their oil for 5,000 to 10,000 miles; that is why some mfgrs. recommend changes as little as every 10,000 miles. Perhaps you car has an air leak into the crankcase. The worst engines for oil blackening I ever noticed were a 1964 BMW 1800ti, which blackened oil in 1,500 miles; and a 1971 Dodge Dart 6-cyl, ditto. The best have been SAAB engines.
Unless you are doing a lot of short trips or racing you can use the mfgrs. recommended change intervals. There are probably conservative by a factor of 2 since the mfgr. does not care now much it costs you or the environment to change the oil; but would not take a chance on providing a free engine replacement by recommending too long an interval.
GM parts....
Regards
Andy
I call my system Proper Maintenance. It is the best mix of breakdown, scheduled, and predictive maintenance and yields the best economy, reliability, and safety from your second largest investment: your vehicle.
You don't have to have expensive tools or extensive training to master Proper Maintenance. I have no formal automotive training myself.
I always follow the Origninal Equipment Manufacturer's (OEM) "severe" schedule, regardless of the type of driving that you do. Remember that the OEM's motivation is to prevent repairs during the 36/36 warranty period, but keep a steady supply of folks needing new cars.
Even those schedules are guidelines and there are cases (Chrysler transmissions come to mind) where one should exceed the OEM guidelines.
Changing oil without changing the oil filter is like mowing the lawn in August, showering, and then puting your dirty clothes back on. You are going to pollute the new oil.
You can't properly evaluate oil condition with the Ol' Mark I eyeball.
Considering the cost of engine repairs or replacement, oil changes are insignificant.
I do spectrographic oil analysis twice a year (every other oil change) on my engines and at least once per year on my transmissions. This tells you if you have excessive wear metals, contaminants, etc. in the oil. This is the type of evaluation you should use if you are seriously considering extending oil change intervals (outside the warranty period of course).
The tests cost $7.50 each - the catch is that you have to buy them a 6-pack at a time. Get the tollfree number for Schaeffer Manufacturing at their website www.schaefferoil.com if you are interested. They UPS the kits to your door for $45 plus tax. They are good for any petroleum based lubricant (engine oil, manual tranny, AT, etc.)
If anyone would like a free copy of my Proper Maintenance checklists, email me at hooferpm@cs.com
I'm working on a website so that they can be downloaded for the future, but I am happy to email them now. The only "cost" is that you give me feedback on their ease of use, effectiveness, suggestions for improvement, etc.
best of luck
