Auto Repair Manuals (Haynes, Chilton, etc) - which are better?
I have a 1998 Nissan Altima SE that I would like
to learn more about (and perhaps work on - once I'm
out of warranty protection in case I mess anything
up!). I'm looking to see if anyone has any
opinion on whose manuals are better - Chilton or
Haynes. Or, if there's another publisher I'm
forgetting, tell me about them. Thanks for the
help!
help!
Ask what all the service manuals are available for your car. If you are only interested in the electricals, they probably publish one just for that, and saves you some $$$.
Guys, are factory manuals pretty complete on tools needed for each job?
One of my biggest pet peeves about manuals, and you'll find this in most manuals, manufacturer or non-, is the phrase "installation is the reverse of the removal." This phrase usually comes after a long, multi-step description of how to remove something like a timing chain or cylinder head!
I just know that if you do any kind of electrical troubleshooting, installing an alarm, GET THE FACTORY WIRING DIAGRAMS. At least with my toyota, it shows the exact location of all junctions and components, wire colors, specific by year, the pin assignment on all connectors & plugs and what they looks like by shape. Best usd$30 I ever spent.
Step 1: Support vehicle securely
Step 2: Remove front wheels
Step 3: Remove transmission and change clutch
Step 4: Reinstall in reverse order
(I am exagerating a little here)
I am not a mechanic but I have always done all the work and maintenance I my cars and have used both the Haynes and the shop manual together. The Haynes manual provides a high level description of what you're getting into and usually provides general tips and tricks. For example, the shop manual will say to machine the flywheel when replacing the clutch. The Haynes manual will have a short paragraph that explains why a flywheel needs to be machined and what could happen if it's not done.
If you are new to factory manuals, suggest that you first spend 2-3 hours reading and learning how the cross-references work; particularly if you are doing electrical/electronic repair. This reading is more interesting than you might expect.
best.haynes&chilton will combine several years and come up with universal diagrams that will drive you up a tree.
This CD-ROM set is free, no charge for shipping.
The user interface is a bit of a pain, but you can't complain for free. Although most of us don't have a computer in the garage, you can at least print out relevant sections.
Its great... Complete scematics, details, etc etc... Though if I ever meet the person that programmed the interface, I'll shoot them on the spot... I only say this, because as a Software Engineer myself, I make interfaces and such all the time...
For those that aren't lucky enough to have access to it, sorry..
Anyways, STAY AWAY from non-factory shop manuals.. Sometimes they are so vague.. I've seen some chiltons/haynes manuals with such stupid lines like.. Step 1, remove caliper assembly... Well, duh... Of course you have to remove caliper assembly, but how?
Anyways, factory manuals give you the exact locations of everything, tools required, concise step-by-step removals, (note that I said removals, not installations... ;p )
Anyways, whatever price the factory manuals are, I'm 100% positive it'll be worth your money... All I know that my CD's are the best $0.00 I ever spent... heh heh heh
Seriously though, I've heard praises from people who spent $120 for their manuals...
#0 of 2: Which one is better? (vac23) Tue 07 Dec '99 (09:45 AM)
I am looking for a couple of service manuels. Can
anyone recommend which is the best to
get-Manufacturer, Haynes, chiton etc?
#1 of 2: vac23 (bobs5) Tue 07 Dec '99 (09:53 AM)
By my own ovbservation.
Helm (factory)is the best.
They are expensive
though.
Haynes would be second.
Chilton would be third.
Bonnie Rick
Town Hall Community Manager, Edmunds.com
I asked her to have a technician check the sensors, they did and found the wires shorting out on the heated oxygen sensor. You see, there was never a code in the computer, the reason for that is there is no code for shorted wires. The problem here is that technicians don't know what to do if there is no code in the computer. In my day (60 years old), auto mechanics relyed on their experience and know-how to diagnose problems. Technicians today are not able to use their brain enough, all they know is how to repair stuff, not to diagnose anything. If I have a minor problem during the warrantee period, I am afraid to take it into the shop, because they will just replace stuff and tear stuff apart without fixing the actual problem. I only take it in if I have a good idea what the problem is, and I ask that they only check out that component.
The factory shop manuals are best.
PRICES ARE REASONABLE.PURCHASE OVER THE INTERNET
DELIVERED RIGHT TO YOU DOOR BY UPS
ED
Go with Helm. A little more money than Chilton or Haynes, but worth the extra investment.
I read about different sorts of manuals, both factory manuals and others. Can anyone confirm if factory manuals are available from GM, at least in the States? If yes, how could I get them, or can anyone give a hint as to item numbers to ask my dealer here?
Any clues & hints on how to contact manual publishers or bookstores which could sell by mail will be specially useful. Which are the best among the non-OEM manuals?
http:www.motor.com
http://www.helminc.com
http://www.haynes.com
0patience: have you (or anyone else) had any experience with the MOTOR manuals at www.motor.com?
This is an amazing thing to have available. It's a shame to keep it secret.
where ? -thanks
http://www.labortimes.com/prod01.htm
No matter how you go about it,the flat rate info is expensive.If you need info on the flat rate stuff and don't want to buy any of the manuals or programs,ask these guys and I'm sure they will post the times for you.
http://forum.onecenter.com/bat
Hope this helps.
Someone needs to write a manual for the backyard mechanic that takes what I call "baby steps" rather than assuming everyone knows everything. I had to write a manual for a software program at work, and my intent was to produce one that anyone could read and use without asking anyone anything. That required taking everything possible into consideration and writing it in a manner no one could misunderstand what was being said. When finished, I took it to a new lady in the office, gave her some scenarios, pulled her up in the test mode, told her to use nothing but the manual to carry out the tasks I had written down for her, and make notes of any problems she had. When she came back and told me she had put everything in, I checked her work, it was perfect, so I published the manual. Worked like a charm.
also have found factory parts books,these can be
helpful,they go anywhere from $5.00 to $70.00
At least for GM and Ford, don't know about Crysler, Helms is the PUBLISHER for the 'original' shop manuals.
In other words, Ford and GM write the manuals, and ALL MANUALS, even the ones in the service bay of your dealship, are printed and sold by Helms.
Look in your owner's manual, they have the address and price for the various manuals available for you car - from Helms.
Repair manuals,electrical and body manuals provided by the manufacturer are published by Helm. The european vehicels are the only ones I know of that do not use Helm.
Thanks for any responses.
http://www.bentleypublishers.com/
They are the publishing companies for most manufacturers.
also check
http://www.motor.com/
http://www.mitchellrepair.com
But no one has the 2000 manuals for that vehicle out yet.
Here is the closest I could come to what you need.
http://www.tmcpubl.com/Daewoo.html
Worth a check anyway.
