While in park, if you rev the engine, to around the same RPM when you hear this noise, do you hear the same rattle?
If so, this is the known Nissan V6 engine issue with the nylon guides for the timing chain wearing out. You can fix it, by a partial engine rebuild, or let it go until the chain breaks destroying the engine (which is many many miles down the road from initially hearing it). This effects all Nissan VQ35DE V6 engines of the early to mid 2000 MY's.
Have a 97 Villager, and managed to relocate a new knock sensor to the top of the intake manifold. Replacing the factory knock sensor would take 10 hours of shop time. My method took less than an hour. You need to figure out which cable harness and the correct pinout on the harness to run your splice to. The Haynes manual sort of shows where the harness is located at. NOTE: This is for the 97 Villager model. This may work with the 96 - 98 models where the pinouts from the engine control module are supposedly the same. But you may have to confirm this.
I just got a a Nissan quest from auto export and I believe I was scamed ...my first experience was that the vehicle just stoped working after the mechanic concluded it's investigation it was discovered that the brain box was already fried up...U fixed the brain box and later disvcovered that the front exhaust blows heat to the engine ...I removed it ....it happened again ...the brained box was fried again ....u put another one and later discovered that it's the ejector mouth again thsts frying up everything ....it was fixed.......but the still the vehicle hasn't moved ...pls can someone help me an going crazy.....plsssssssss anyone HELP ME
