Broken overhead console and Airbag light
km_2828km_2828 Member Posts: 2
edited September 2015 in Kia
Few weeks ago I purchased a 2009 Sedona with 118k miles.
We accidentally broke the overhead console, and, as a result, the interior lights and the power sliding door buttons no longer work (doors open/close only with key FOB). Additionally, the Air Bag light came on. I am really concerned about the airbag light, but I am not sure if these could be related to the broken console. Any help/advice will be highly appreciated.
Thank you in advance
  • thecardoc3thecardoc3 Member Posts: 5,862
    Looking at service information the relationship isn't clear. This is where the trouble codes would help get a sense of direction, but the possibility of a communication failure between some of the modules is pretty high. You need to get codes form all of the modules that will communicate and post them, then I can look further.
  • MickeyDrivesAKiaMickeyDrivesAKia Member Posts: 1
    I am now having EXACLTY the same issue - ALL symptoms are identical and there are no other issues.
    km_2828, please let me know what the solution was for this.
    I think cardoc (above your post) gave you a hint as to the next step. Since so many modules communicate with each other through the BUS, your diagnosis has to center on what might be interfering with what.
    I presume you've done due diligence and checked all your fuses, grounds and fusible links?
