The mechanic replaced the four injector wires, which had "broken locks & were not fully seated".
The Check Engine Light sensor was reset. Approximately 40 miles later, a puff of gas was smelled, and the Check Engine Light came back on.
Now they say we need a Powertrain Control Module (expensive). Should the module have been replaced first? Does this sound logical?
Thank you!!
http://www.troublecodes.net/OBD2/Pcodes.shtml#1000
P0190 - fuel rail pressure sensor circuit malfunction
P0193 - fuel rail pressure sensor circuit high input.
These things occured after the timing belt was not properly installed.
2.0L Engines
Properly relieve the fuel system pressure.
Disconnect the negative battery cable.
Disconnect the vacuum hose from the fuel pressure regulator.
Unfasten the two fuel pressure regulator retaining bolts.
Remove the fuel pressure regulator and the O-rings. Discard the O-rings.
To install:
Lubricate the new O-rings with a light engine oil.
Position new O-rings onto the fuel pressure regulator.
Place the fuel pressure regulator into position and install the retainers. Tighten the retainers to 27-40 inch lbs. (3-4 Nm).
Connect the vacuum line to the fuel pressure regulator.
Connect the negative battery cable.
Run the engine at idle for 2 minutes, then turn the engine OFF and check for fuel leaks and proper operation.
Are you saying that the regulator should be replaced and not the sensor?
TP
Do I have to have it checked out and if needed fixed immediately.
I own a Ford Escort LX 1996 2Door 1.9L engine manual shift car.
It has a salvaged title and the true mileage is not known.
I have had it for the past 1-year/8,000 miles. The previous owner had had it for 3.5 years/25,000 miles.
I estimate the true mileage to be around 75-80,000 miles. So, I decided to change the timing belt last weekend. The mechanic also advised me to change the radiator as there was some coolant leak and the hoses were getting soft(?). I agreed. Including an oil change I spent about 540$.
Less than 1-day/50 miles after I got the works done, the "Check Engine" light on my car OBD (On-Board Diagnostic) is glowing.
I took it back to the mechanic. He plugged it in to the computer and said I need to change the "Evap ..." stuff. He said that these are electrical parts costing about $55.95 and $25.95 each and that he can fix them without billing me any labor charge. Still he couldn't guarantee that that was the real problem. He says, "That is what the computer says. After we fix the 'Evap..', the computer might find fault with some other thing. I can't guarantee anything."
He also turned off the OBD light and said, "I have turned it off, but it is sure to come back on in a couple of days". And it did come back on the next day itself.
I don't know if there could be something wrong with the timing belt replacement, or the radiator replacement, or really the "Evap..." parts. I feel so sorry that a preventive maintenance has lead to so much problems.
Do you people have any advice on how to handle this problem?
Thanks in advance.
The 99 escorts do not have a regulator, instead they have a fuel pressure sensor, which maintains fuel pressure based on intake manifold vacuum (from autozone repair guide). No auto parts store seems to sell this except ford dealers. The autozone repair guide only mentions about the replacement of the O-rings, not the whole sensor.
TP
Fuel Pressure Regulator Part # F4TZ9C968B or F4SZ-9C968-A is specified for 1999 Ford Escort L4-122 2.0L SOHC VIN P SFI
While some catalogs do refer to it as a fuel pressure sensor, it is still listed by Ford as the regulator.
All in all, they are the same thing.
Autozone may call it a fuel pressure sensor, but Alldata and Ford still list it as the fuel pressure regulator.
Also, Standard lists it as a fuel pressure regulator Part # PR162 F4SZ-A and it is $40-$60
NAPA lists it as Echlin Fuel System Fuel Pressure Regulator Part # CRB219617 for $68
I'm not going to get into an argument with you about it. Think what you want. All I am doing is providing the info as it is supplied form the manufacturer.
If the standard number is wrong, then so be it, but the Ford number is right and it is called a regulator by them.
A sensor senses only the pressure, bu does nothing to adjust the pressure, while an electronic fuel pressure regulator will regulate the fuel pressure.
I'm not going to sit here and debate thte issue.
First, without having it scanned and having the trouble codes, any guess would be just that, a guess.
Swing by Autozone or another parts store that will scan the vehicle for free. Then let us know what the trouble codes are. DO NOT replace anything, until you have done the diagnosis.
Thanks anyway.
Out of autozone repair guide:
Fuel Pressure Sensor
Ford Escort/Tracer 1991-1999 Repair Guide
REMOVAL & INSTALLATION
1998-99 2.0L Engines
See Figure 1
1998-99 models do not utilize a conventional fuel pressure regulator. Instead, they contain a fuel pressure sensor, which maintains fuel pressure based on intake manifold vacuum.
1.Properly relieve the fuel system pressure.
2.Disconnect the negative battery cable.
3.Remove air cleaner outlet tube.
4.Unplug the sensor electrical connection.
5. Disconnect the vacuum hose from the sensor.
6. Unfasten the sensor retaining screws and remove the sensor.
7. Inspect the sensor O-rings and replace them as necessary.
To install:
8. Lubricate the new O-rings with a light engine oil
9. Install the O-rings on the sensor and place the sensor into position.
10. Install the sensor retaining screws and tighten them to 27-40 inch lbs. (3-4 Nm).
11. Connect the vacuum hose to the sensor.
12. Attach the sensor electrical connection.
13. Connect the negative battery cable.
14. Run the engine at idle for 2 minutes, then turn the engine OFF and check for fuel leaks and proper operation.
Fig. 1: The fuel pressure sensor is located on the right-hand side of the fuel supply manifold (fuel rail)-1998-99 2.0L engines
I have to tell you, it is funny. Alldata says one thing, AutoZone says another.
AutoZone owns Alldata and Alldata uses the information directly from the manufacturer.
Let me ask you, do you have access to Ford's OASIS information system? I do.
Do you have Alldata's information system or Mitchell's information system? Again, I do.
How long have you been a mechanic?
How much training have you had on these systems?
No need for me to answer the last 2.
Hmm, well not really. We'll agree to disagree and leave it at that. ; )
But since the pressure voltage is the same as the reference voltage and it does not change together with the pressure, can I conclude that it safe to conclude that the device regulates the fuel pressure properly but the part that measures the pressure is not working?
In order to confirm that it is the sensor portion of the regulator, you will need to hook up a scantool to see what values it is giving.
Also, in order to properly check the sensor, you will also need to disconnect the regulator electrical connector and jumper it and see what the scantool refrance voltage is.
This is where you need a manual that will give you the specific flowcharts for the P0190 & P0193.
I can tell you right now though, your fuel pressure is low, it should be 35-55 psi with the key on, engine off.
You need the flow charts to go step by step. If you replace the regulator sensor without doing the proper diagnosis, you are guessing and you could be wasting money on something that may not solve the problem. Then again, it might.
Because the fuel pressure is low, you either have a problem with the sensor portion of the regulator or the vacuum portion. The sensor should go from 5.0V to 0.2-0.5v throught the PCM and it requires a scantool to check it.
If the sensor isn't changing, then the vacuum portion may not be working properly.
Again, you need the diganostic/flow charts for the P codes to determine the problem.
Thanks to everyone.
inspected & failed the emissions because of the
engine light is on. The p1870 code showed up
and I took it to the transmission techs and told
me that just to take it apart to see what's
wrong will coast $385.00 YIKES!!!!
I was planning on taking the car back to the
dealer to drive something more recent & wasn't
looking to spend alot of money. I was wondering
is there a certain way to fiddle with one of the
cables to get the freakin light turned off so
I can pass inspection??????
Descriptions do no good for diagnostics. We need the trouble code number.
Also, codes do not tell that a sensor is bad, so consider the source. They want to sell you parts.
Let us know what the trouble code number is and we can go from there.
Once we know what the trouble code NUMBERS are, we can start to help you figure out what to test.
Also, if the platinums are not the OEM plugs, then pull them, pitch them and put the correct OEM plugs in. All the aftermarket plugs will do is cause you headaches.
Let us know what trouble codes you get.
Clearing the DTC
The DTCs and freeze frame data will be erased by disconnecting the battery terminals or EFI fuse.
Understand that the Toyota is a rarity, most vehicles 95 & newer, it doesn't clear the trouble codes.
But you realize that the light will come back on if the problem isn't fixed?
BTW, there are 36 different trouble codes relating to oxygen sensor circuits. None of them say to replace the sensor, they say there's a problem in the circuit. Mioght be the sensor, wiring, connections, fuse, etc, etc.
alex
The O2 sensor for the left bank has been sending a signal back to the PCM that it's bank is running lean. The PCM has added fuel to it's limit to try to compensate, then set a trouble code. The code does NOT say that the O2 sensor is defective. Start by looking for any vacuum hoses cracked or disconnected. Also check fuel pressure.
I have a 95 Sebring LXI and the "check engine" light comes one once a day on the interstate after about five minutes of driving. I've changed the EGR valve & Selonoid, plugs, plug wires, fuel filter, basically a full tune-up. I've checked and the EGR does get a vacuum. And the electrical leads, from what I can tell seem fine. The car runs great, I just can't keep the light off.
Fault code 32 reads as such: Short or open in the EGR solenoid circuit. Check for loose, broken, or shorted wire in the EGR valve wiring and connectors. Possible air fuel ratio imbalance not detected during diagnosis.
Any help is much appreciated.
I have a 98 honda civic. The check engine line is on. I went to autozone and a code of p0505 signifying a idle system malfunction. when my car is in park the rpm goes up and down from 500-2000 rpm constatntly. If anyone can help thank you!
Possible Causes
IAC valve mechanical malfunction
Throttle body clogged port, improper adjustment
Intake manifold gasket leakage
Intake air hose loose leakage
Vacuum leak
ECT sensor incorrect output
Throttle Position sensor incorrect output*1 *1 '96 models only.
My check engine light comes on and I am getting the following codes:
P1275 - Accelerator Pedal Position (APP) Sensor 1 Circuit
P0171 - Fuel Trim System Lean Bank 1
P0172 - Fuel Trim System Rich Bank 1
P0174 - Fuel Trim System Lean Bank 2
P0175 - Fuel Trim System Rich Bank 2
When it is started cold it revs high then slows down and stalls. When I try to restart it stalls immediately unless I apply the accelerator. Everything seems to be OK when I am driving but when I let up on the accelerator and slow down it stalls. The Accelerator Pedal Position sensor and PCV valve have been replaced but have had no effect. When driving slowly after driving at high speeds I've noticed that the engine sometimes revs. What could be the problem? O2 sensors? Thanks.
