Cooling fan?
I have a 2008 328xi and have noticed over the past couple of days the cooling fan coming on a lot and rather loud. I've only been driving short distances and it's fall where I am so temps are around 40-50. No warning lights have come on. Anything to be concerned over? Normal? Anyone had this happen?
Best Answers
Mr_Shiftright
Member Posts: 64,481
If the coolant level isn't low, then I would suggest scanning the car for trouble codes to see if some sensor malfunction shows up.5 -
Mr_Shiftright
You may still have air in the cooling system, which might account for no heat. I don't see how adding coolant can make the car run rougher or noisier, so there must be a number of issues going on here at the same time.
Coolant has to be filled very gradually with engine running, to allow the system to "burp".5
Answers
