Right To Repair - A Hot Issue or Big Problem?
18910111214»
    No one is going to repair them I don't think. They will either be repaired by wi-fi or satellite, remotely, by geeks in India, or they will be pro-rated for use, and returned to the factory.
    How easily they overlook the biggest issue with these cars. Who is going to repair them? http://www.cbsnews.com/news/self-driving-cars-google-mercedes-benz-60-minutes/#comments
  • thecardoc3thecardoc3 Member Posts: 5,859
    The Washington Post left out some details on the ruling. Here is what they said about "land vehicles". Note the section that I highlighted.
    Based on the record, the Register recommended granting an exemption. The
    Register concluded that reproducing and altering the computer programs on ECUs for
    purposes of facilitating diagnosis, repair and modification of vehicles may constitute a
    noninfringing activity as a matter of fair use and/or under the exception set forth in
    section 117 of the Copyright Act, which permits the owner of a copy of a computer
    program to make certain copies and adaptations of the program. The Register also
    concluded that owners of vehicles and agricultural machinery are adversely impacted as a
    result of TPMs that protect the copyrighted computer programs on the ECUs that control
    the functioning of their vehicles. The Register further found that while two of the
    statutory factors weighed in favor of the exemption (availability for use of copyrighted
    works and impact on criticism, comment, news reporting, teaching, scholarship or
    research), and two of the factors were neutral (availability for use for nonprofit archival,
    preservation and educational purposes and the effect on the market for or value of
    copyrighted works), the fifth factor—under which commenting parties and federal
    agencies raised serious safety and environmental concerns—tended to weigh against an
    exemption.
    Overall, the Register concluded that while from a copyright perspective
    proponents had made the case for an exemption, based on the record, the exemption
    needed to be carefully tailored to address a number of concerns. Accordingly, the
    recommended exemption excludes computer programs in ECUs that are chiefly designed
    to operate vehicle entertainment and telematics systems due to insufficient evidence
    demonstrating a need to access such ECUs, and out of concern that such circumvention
    might enable unauthorized access to creative or proprietary content. The exemption also
    43
    excludes circumvention “on behalf of” vehicle owners, as a broader exception allowing
    third parties to engage in circumvention activities on behalf of others is in tension with
    the anti-trafficking provisions of section 1201(a)(2) and (b). Moreover, by passing the
    Unlocking Act—which amended section 1201 to allow unlocking of cellphones and other
    devices to be carried out by third parties “at the direction of” device owners—Congress
    indicated its view that extending the reach of an exemption to cover third-party actors
    requires a legislative amendment. The exemption also expressly excludes acts of
    circumvention that would violate any other law, including regulations promulgated by
    DOT or EPA.
    Finally, in light of the significant concerns raised by DOT and EPA, the
    recommended exemption will become operative twelve months from the effective date of
    the new regulation to provide these and other potentially interested agencies an
    opportunity to consider and prepare for the lifting of the DMCA prohibition.
    Acknowledging the views of the NTIA, the Register determined that a twelve-month
    delay was the shortest period that would reasonably permit other agencies to consider
    appropriate action.
    edited October 2015
    Yeah, that's going to fly. The eBayers will be changing their identies often, unless they're off-shore and won't care. EBay probably won't care either so long as they get their fees. Psst, buddy, wanna chip? How 'bout a Tornado? H2O mason jar? Garmin maps? 30,000 lines of code for only $10....
    The tweaking to zap the DRM on music and video exception - something tells me that that's not going to fly in the real world either. If you can see or hear it, you can steal it. Can't wait until the MPAA starts sleeping in your dashboard.
    In other news, the new Apple car can't be repaired except by geniuses (that'll make you want to go to the bar) and parts will not be available once a new model hits the showroom.
    Apple wants to kill a bill that could make it easier for you to fix your iPhone
    (Washington Post)
    I've met some of these "geniuses" and I suspect the word has lost a bit of its original meaning. If you can play the piano when you are 8 years old, you are "clever". If you can write a symphony like Mozart at that age, then you're a genius.
    Certainly any intelligent person can be taught to fix quite a few things on their modern cars, but the question which nobody seems to address is----do they want to spend their time doing that?
