Help me fix her, please!
Okay, so I have a 1996 GMC Jimmy a couple of weeks ago I had what I thought was a starter issue. It turned out that the ignition fried and burnt up the starter. Those were repaired. Put her back on the road immediately sporadic starting issues. Took her back to mechanic he said he looked couldn't find anything told me to take her home. I tried to start at shop, wouldn't went back and ask him if he could show me how to start my own truck? He couldn't, left her there turned out relay on fire wall burnt up as well. Took her home back to some time she starts and sometimes she doesn't. I'm female and haven't any mechanical background. I do have power, the dash lights up but no crank, no noise. Any ideas would be greatly appreciated.
Do you know how to use a voltmeter or a test light? Do you have either a voltmeter or test light? If not now would be a time to buy at least a test light. Here is a little video on how to use one.
There is a 10 amp fuse, socket #20, in the instrument panel fuse block. Get your owners manual and it will show you the exact location. It should have power (on both sides) when the key is turned to the crank position only.
If you have an automatic then the following checks would help identify the area of the trouble, a manual is slightly different.
The relay that you mentioned on the firewall, it should have a yellow wire going to it. There should be power at that yellow wire when the key is turned to the crank position too. Fuse #20 is in-between the ignition switch and the neutral safety switch on the transmission and the relay is after the neutral safety switch and controls the power to the starter. If you had power at fuse #20 when the key is in the crank position but not at the yellow wire for the relay then there is a problem with the neutral safety switch or the wiring in-between those points.
There are two black wires at the relay, one of them has power all of the time the other is grounded. There is a purple wire at the relay, it is the wire that connects to the starter solenoid. Using a test light, and jumping from the black wire that has power to the purple wire it should light up.
If you use a piece of wire and jump power from the black wire to the yellow one, the engine should crank with the relay in place. Jumping power from the black wire to the purple should directly cause the starter to crank the engine.
Depending on what is found with these checks, the next step in the diagnostics can be chosen.
