Can I replace alternator myself?
Any motor heads out there that would comment on replacing the alternator by oneself? Any one with the experience of having done this? I have a 1996 Subaru Impreza and the alternator is definitely going. All the warning signs, - flickering dash lights and headlights. I am mechanically handy and have done other things myself. Have new battery and new starter, just hard right now to squeeze out the $$ for another major repair cost.
Best Answers
Mr_Shiftright
Member Posts: 64,481
Sure, it's pretty easy. Here are two videos and between the two it should cover any variations you might come up against. Be SURE to disconnect the battery. If your radio requires a code, be sure you have it before you disconnect the battery. You can also buy a simple battery "substitute" device that plugs into your cigarette lighter.
VIDEO 1 ('95 Legacy)
VIDEO 2
Diagnosing Alternator Problems5 -
Mr_Shiftright
The video pretty much guide you through it step by step, and the Video #2 gives you ways to diagnose the alternator, so that you don't replace it unnecessarily.5
Answers
I listed my car in case someone out there has the same, has done this job and can make an intelligent comment to guide a first timer. I have looked at video's and will look at Mr. Shiftright's video's.
