Highlander Whining Noise
Purchased a 2010 AWD Highlander, There is a whining noise coming from the rear end, possibly the differential. Is this normal in all Highlanders? If not can someone tell me what can be done to solve the problem.
Best Answer
Mr_Shiftright
Member Posts: 64,481
Could be some wear to the ring and pinion set---and if this occurs on acceleration rather than deceleration, it probably means your gear set is out of alignment and/or has some rough gear surfaces.
You might check the differential fluid level, and even change it out for perhaps a Redline synthetic.
http://www.redlineoil.com/Products.aspx?pcid=4
It's possible this condition could stabilize for quite a long time. Draining the fluid might also tell you if something really serious is happening in there (metallic debris in the oil).
There is no quick cure for this, you just have to live with it and monitor it
5
Answers
Thanks for the response.
